well, I got curious about the tires on my 18's, so I pulled out my window sticker and checked it. I paid an extra 350 for all terrain tires and have Wrangler SRA's... looks like I need to go back to my dealer for another issue haha
this is an absolute joke
Yea it isn't right. The SRAs are NOT all terrain tires, and to add to that they are extremely cheap tires. There is nothing about them that warrant a $200 or $350 upcharge. Ridiculous.
Doesn't look like we will have much ground to stand on for this case:
Goodyear
Not sure what that says cause it won't blow up big enough on my phone without it being blurry
I call BS on that. It's like GM decided to make a change, put SRAs on trucks that paid for the all-terrain option, and asked Goodyear to put that little all terrain logo on the website. There's no other website that consider SRAs to be all terrain tires. They are cheap, highway all-season tires.
It even says in the description on their website they are "original equipment". When you pay for the all-terrain upgrade, it says right on the window sticker "Replaces standard tires".
Regardless of if they are or aren't all terrain, my 2014 had these exact SRA tires on it, WITHOUT the $200 all-terrain tire option. Many other trucks do as well, right now, go look on a lot. So what did that $200 get me? Nothing.
Furthermore, tell me what tires WOULD have been on my truck, had I not paid for the $200 option. Probably the same tires...or, Goodyear Eagle LS2 tires, which are the same quality tire, cheap, pretty much the same price as SRA. On TireRack, the Eagles are actually $1 more expensive, lol. Some upgrade these SRAs are...
Edited by mikegmi2
Unless these Eagle ls2 tires are ruled as the fault for my vibration, they have been a pretty good tire. Good street manners and do well in inclimate weather as well. Did pretty decent in my buddies muddy ass field while I was towing a trailer as well. Maybe I'm the only one who's had good luck with them so far.
Now if they're the cause of my vibration then they suck ass lol
My first 14 had ls2 tires and had the shakes. I also drove a HC with ls2 20's and it had the shakes as well.
I have the vibrations as well, just not sure if it's the tires fault or not lol
my dealer already confirmed that the SRA's are not an all-terrain tire, everyone knows that. confirmed by tirerack as previously mentioned, my dealer is looking into getting me real A/T tires, and has told me to urge everyone to contact GM Customer assistance at 1-800-222-1020 regarding EVERY ISSUE WITH THE TRUCKS.... even they are sick of dealing with the complaints
http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Wrangler+SR-A&partnum=665TR8WSRAOWL&autoMake=Chevrolet&autoYear=2015&autoModel=Silverado+1500+4wd&autoModClar=Crew+Cab
Goodyear's website says they are AT so GM is not really cheating anyone even though the SRA's are cheap tires. They are also standard equipment on alot of other 4wd "off road" trucks. If GM put actual LT AT tires then people would raise hell about their gas mileage being below what the window sticker says it should be. If you don't like the tires then don't buy the truck or put on the set you want like everyone else does.
Problem is the manufacturer can market them however they want as I doubt there is a standard for what make an AT tire. And why wouldn't GY try to upsell the product. Typical marketing at work. And GM being stingy. I agree with part of your statement on the LT,s, I wouldn't expect an LT tire to come on the 1500 trucks. In any case I think most agree the GY's are not worth a $200-$300 upcharge and GM could be putting a better AT on with that upcharge. Looks like GM is getting away with it again just like the "normal operation" vibs people feel. Buy still I wonder why some like myself get the Bridgestones then. Is it a 4x4 vs z71 thing? Or an assembled in Mexico vs Fort Wayne thing? Or just a regional thing where final vehicle destination being a southern or northern state determines it.
let us not forget that even those trucks without the "upgrade" have WRANGLER SRA's which my dealer agrees is not an A/T tire, so no matter how you look at it, they owe us a better tire. I'm not paying an extra 350 to for the tire that come stock on the truck anyway.
Edited by Jesse D
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
