I'm in the same boat. I think the gm twins are the best looking trucks out there but I would love to test drive a tundra. My only concern with the Tundra is that they are due for a model update and I would hate to buy one only to have it look outdated in a couple of years. But I guess that's what happened with GM when they decided to facelift the 2016s and make my 2 yr old truck look outdated haha
Tundra could get a refresh in 2017 with a possible diesel and will be redesigned in 2019.
Back to the shop one more time. They changed the ring and pinion and said the truck was within specs. Doesn't shake like it did but it has a vibration that comes and goes, enough to shake my coke out of the bottle. I am at the end of my rope on this truck.
Anybody have chrome plastic clad wheels that this is happening to? Steel wheels? Anybody tried slamming their truck or extending the air dam down? Perhaps it is air velocity related? I don't have it but am interested in what people have tried. Things i've seen so far: Drive shafts, ring gears, differentials, wheels, tires, body mounts,motor mounts, tranny mounts. Things i have not seen: transfer cases, cv shafts, transfer case drive shaft, bearing hubs. not much left after these components is there? My condolences to those with this issue.
Don't count your blessings yet, many of them develop the vibration issues after 1500 to 2000 miles.
Well i am sad to say I have to add my name to this list.
Just purchased a new 2015 double cab LT 5.3 2wd. I have owned several GM trucks and bought this one without a test drive.(stupid me)
2200 miles, 2 dealers, and 3 dealer visits already and still 75mph shake. The selling dealer is incompetent and has dropped the ball several times and is not taking my situation serious enough for me. I am contacting GM customer service to hopeful get someone to take this issue as a priority for me. So unhappy with new purchase because of this situation, and I love GM truck and want to give them the benefit of the doubt.
Tried a few things, got the shakes still.
-clamped leafs 6-7" behind axle
-torqued u-bolts to 78ft/lbs
-retorqued body mounts to 120ft/lbs, front 2 to 60ft/lbs
Time to take it to the dealership and have them tell me all is within spec, again. Can't wait.
So what do you suggest? A 3000 mile test drive before you buy?
Sorry to hear it, but just a heads up gm customer service isn't worth a shit. They might help set up an appointment but they are low level and pretty much useless, just like the rest of the company from the top down.
Try clamping in front of the axle 6". Just curious I have read somewhere before that it helps with the driveline clunk, never know might work. I was planning on trying it but haven't got any clamps yet. I have tighten the u-bolts and loosened the body mounts and retighten. It seemed to have helped hasn't shook as bad since its very slight now and only sometimes.
Edited by southern_sierra
When the diehards figure it out and solve these problems for everyone if this is the worst thing that happens in 100000 miles I will continue to purchase gm products. 6 people at work have gm products and don't have this issue
The reason I ask is due to content laws maybe the Canadian built parts for these trucks here aren't having the same issues. Just spitballing here guys
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
