Radio Reception Issues
ace ventura
How do you know the radio reception in the 17 will be any better? the sour part about this is gm will turn around and resell your 15 to the next Joe and just pass the problem on to someone else
I've test driven a bunch, but I don't know for sure I suppose. as for reselling, my truck didn't just have a radio problem. I had them confirm what happens with my truck. GM comes and takes it and brings it to michigan for their "Repurchased Auction" dealers are required to disclose what the problems were, and the purchaser is required to sign a document stating that he was informed and accepts the problems as is.
  • Replies 1.4k
Well at least the next guy will know what he is getting no then. I keep trying to work up the motivation to go back to the dealer again to try and resolve the issues I have. First oil change coming up so that will be my 4th attempt to fix radio, exhaust squeak, and now the transmission clunk that is getting louder... Glad you got resolution.
good luck with it, its not easy
So if the radio in the 17 is better, I wonder if it's swappable to the 16?
its possible. I'm not saying the radio is great, but its better than the one in my current truck. and the vibration isn't as bad
Got Sirius radio for a year on both trucks. Wonder if their will be a fix by then?
Yes, my FM radio sucks with standard speakers. I believe the Bose speakers exhibit the problem more because they have better high frequency performance and all the "noise" is high frequency.
Again, radio reception sensitivity is within bounds but there is little or no FM noise reduction so you hear all the multipath "swiching" and fade noise like a $5 radio. I believe the GM engineers blew it when they wrote specifications for the radios by other manufacturers than Delco or Delphi. The radio in my 2016 is an LG.
Cant swap a BOSE truck over to non-BOSE like that, the head unit and or programming is different plus BOSe speakers have AMPs at every speaker location where the standard system uses 1 amp for everything.
My 2016 truck is noticeably better than my 2014 was, my only issue now is that the static makes the screen distort out and the screen randomly turns off and then back on. Just need to get some time to take it into the dealer to have them reprogram it.
I've never heard a Bose system, just speculating. The static, is this the swishing type while you're moving and listening to a weaker station or is it something else?
My 2016 I consider satisfactory now after the reprogram for the Android mobile app. They inferred that it would possibly fix some radio problems. I was ready to add an aftermarket radio for FM but determined that it is not worth it for the small improvement.
Well, my Infotainment system gave up the ghost today on my 2016 Sierra. Music was playing loudly in the background, volume knob wouldn't turn it down and screen as totally blank. Tried to reset the radio by pulling the fuse, no change. I am guessing the HMI module died or another module died. System has never worked right since they flashed the Android Auto update to it. Waiting to see if dealer can fix it today or if it is going to be out of service for a bit.
2014 Sierra radio was bad and annoying, 2016 Silverado much better
Hello TJay74,
We regret to hear that you have these concerns with the Infotainment System in your Sierra, and understand your desires to have a reliable radio. We recognize that you are just updating the other forum members on your experiences, but would be more than happy to offer our support while you are working with your dealership. If this is something that interests you, please send us a private message.
All the best,
Julianne M.
GM Customer Care
Hello TJay74,
All the best,
Julianne M.
GM Customer Care
Like GM doesn't know this is an issue!!!! Support would be to make it right for everyone!!!! Mine is a JOKE....And I'm looking at a new 17' why?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
