Oil change, tire rotation and balance, leveling kit installed, and alignment. I think it turned out good.
  • Like 7
There is a "hidden" abs plastic cover you can buy cheap for the huge pocket in front of the cupholders then buy a good wireless chargers and hardwire it to cigarette port. Mount charger pad to underside of plastic.
Faster charger and charges everything that is wireless and is easy install. I like the phone up front more anyways.
Say bro you got a link to this?
Sent from my LG-G710 using Tapatalk
Many months ago I searched for days for it and couldn't find it. When he was selling them I didnt need it but then I got the Note 9 a d doesnt fit. As I said the 2nd charger mod seems the better choice in the long run anyways.
12 hours ago, Kurtj29 said:
Got my extra grill back from the painter. Planning to put it on tomorrow. Midnight Denali.CC231C8A-797F-432D-A1A9-47BCA514B718.thumb.jpeg.47bf3367213e79b1660289f980167e7d.jpeg
This is my goal!  Just need a grill lol
  • Like 3
Nice! KO2s? What size did you go with?
Thanks! Yep, they’re just the factory size, 275/55/20. Already had them before the level. When it’s time for new tires I’ll go a little bigger
Test fit my new Uniden Bearcat 980SSB CB. Just waiting on my 4' Firestick antennae to arrive. Plan on fitting a piece of plexiglass with carbon fiber vinyl wrap to cover open space below CB.cb2.thumb.JPG.8fc5f4f30427d8d5042cb8a7dfa681fe.JPGcb1.thumb.JPG.a77fd4d37f1a1665cfeb33055700d44f.JPG
  • Like 3
Installed a Ranch Hand grille gaurd I bought used for only $250. Not a bad deal.. Still iffy about that chrome grill hiding behind it though. At least it covered it up some.
It was beautiful on the weekend, I spent some time cleaning up the rig.
  • Like 3
Looks good, even with the red letters.  Thought about blacking out the letters?
Maybe you can buy @Kurtj29's old one, and get it painted like he did to his new one.
Where'd you get the grill guard, and how much?
That's where I had my Uniden PC122XL (CB w/ U/L SSB) & Realistic PRO-2026 Scanner, in my '15 Silverado.  My 4' Firestik Antenna was (on my '15)/is (on my '18) on the right forward stake hole, with super duty barrel spring, but I'm looking at getting a "Sport Bar," roll-bar, and relocating it to the top of that.  Looking at putting them in my '18 in the same spot, but I have to purchase & install a new front end of the full console to do it, cupholder does NOT move on '16+.  :mad:  I'm looking at putting a cover around the radios, keeps trash, fries, etc, from getting down in the hole/cubbie where the radios are.  I may temp locate the radios forward of the cupholder, until I can get a more suitable forward section of the center console.  As for right now, I have the mount bracket, antenna, spring mounted on my '18, seeing how it will hold up, without a tonneau cover helping hold it down, going with a lower profile cover, than I had on my '15.  Attached the album for my '15, haven't posted any pictures lately of my '18, since I got my personal tags.
It’s a Weston HDX Grill Guard. Got it and had it installed at a truck accessory shop. Think it was $675
  • Thanks 1
Got my gauges back from [mention=192145]US Dashworks[/mention]
They look great!
Those look great! How much and what style was this? Thanks for the share.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
