My 2014 Sierra - Finally Lowered with Wheels
  • Replies 61
I actually really like it with the chrome for some reason! I usually don't like the chrome.
I realize it will be impossible for you to leave it as is, but I vote for that!
Looks really good! I lowered my 14 but it's a little too low. I scrape just about everywhere the road isn't flat. Where in AZ are you from BTW?
Here's mine: http://www.gm-trucks.com/forums/topic/163774-just-lowered-my-14-silverado/
Nice truck! I don't find that my truck is too low at all. I was thinking it was going to be worse that it actually is. What size tires you running?
Oh, I live in Peoria, AZ. How about you?
Ah still love me a clean, properl lowered truck without tons of shit on it. Nicely done. I need to find me someone to trade my chrome handles and mirror caps for their white ones...
Looks great! Any idea what it will be like for towing/hauling? I have a '14 silverado double cab 2 wheel drive, I want to lower mine the same, but I also haul a 24' enclosed car trailer so not sure if I can get away with this drop.
could you do it with an air bag system?
  • 9 months later...
Finally got my wheels on last night! Was excited to take some before and after pictures when I got home from work today.
Mods so far:
- Belltech 4/7 drop (measured out to be closer to a 3.5/6.5 drop)
- CK375 22x9 wheels with Nitto 285/40s all the way around
- Full Debadge
I want to do some color matching next....chrome painted white???
Let me know what you think!
Quick before & after shot:
15410751758_9782f3d6a3_b.jpg2014 Sierra Before & After by Jim Boomer Photography, on Flickr
The rest:
15594653411_13bb22e232_b.jpgSierra Lowered & Wheels (1 of 9) by Jim Boomer Photography, on Flickr
15597319735_e658834405_b.jpgSierra Lowered & Wheels (5 of 9) by Jim Boomer Photography, on Flickr
15411214418_f8a5bea8a4_b.jpgSierra Lowered & Wheels (6 of 9) by Jim Boomer Photography, on Flickr
14976589094_8a7bfa0337_b.jpgSierra Lowered & Wheels (7 of 9) by Jim Boomer Photography, on Flickr
14976589694_fb26ea7fed_b.jpgSierra Lowered & Wheels (3 of 9) by Jim Boomer Photography, on Flickr
15573641306_abd74a8507_b.jpgSierra Lowered & Wheels (4 of 9) by Jim Boomer Photography, on Flickr
15573640626_8ed09d9edf_b.jpgSierra Lowered & Wheels (2 of 9) by Jim Boomer Photography, on Flickr
15594652841_d9c0491b08_b.jpgSierra Lowered & Wheels (8 of 9) by Jim Boomer Photography, on Flickr
15597317915_de66d20c80_b.jpgSierra Lowered & Wheels (9 of 9) by Jim Boomer Photography, on Flickr
THAT IS BEAUTIFUL!!!! I'm partial to red vehicles but I love the color of your new wheels. [emoji4]
Sent from my iPhone 6
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
