     I put the Bilstein's on before the new wheels and tires. My stock Ranchos were beat up pretty bad, so going from those to the 5100s was a huge improvement. Can't comment much on towing anything just yet. All I've had behind it so far is a 22' bay boat. Haven't gotten the horse trailer behind it yet.
    With the new tires and wheels, I can't tell any differences between 275/55r20 or 33x12.5r20 riding on the bilsteins.
Awesome. Thanks for the reply.
I've actually got my Bilstein's in hand and going to have them installed on Monday along with switching out of the factory blocks for 2" blocks in the rear.  I have the rims on order and once they get here I will have them ceramic coated like the truck and then I will get the tires that I haven't decided on yet (going back and forth between the Nitto Ridge Grappler 305/55R20 or Toyo AT2 295/55R20's) installed. I will also try and take some measurements before and after.
Interested to hear how your tires fit, as I just did the same level setup.  Which rear blocks did you go with? With a lot of highway commuter miles, I haven't been in a hurry to size up, but will probably end up just going 275/60 or 285/55 when I do.  I see you've got the Airaid MIT in your signature....any feedback on that? Worth it?
Edited by djriv11
So, riding on stock ranchos.. This thread is saying 5100's are a major improvement but if I can wait for the 6112 to get those instead? Any idea when they will be available?
I'd like to do a level kit, fine with a 1-2" all around but not really looking for a lift.
any input? Thanks!
I just did 5100's all around on mine last weekend. I had the stock black shocks that come with the max tow package. So far im really happy, truck rides better than it ever did. My originals were smoked at 65k, 3 out of 4 were leaking and the one on the right rear had like an inch of up and down slop in it and i had developed a nice little shake on the freeway, that is gone now.
Just had 5100s installed all 4.  Wow what a difference!!!!!   i had the black shocks and at 50,000 miles they were toast!  I had the 2 inch Rough Country spacer on also......It was riding terrible!!   What an absolute difference I really am impressed.  Thing is though the shop installed the Blisteins at the stock setting and kept the spacer on, however it rides so good i think i will just keep it as is.  It rides better than it ever did.
Sorry for the late response. The front end of my truck sits a half-inch lower than the rear. Enjoy your new shocks!
I'm about ready to order the 4600's because I don't plan on lifting my truck. I'm just waiting for the weather to warm up a bit.
Get then 5100s and set them at stock height, you'll thank yourself.
If anyone's interested in a good deal, I have my set of 5100's for sale right now.  3700mi on them.  Took off because GM is repurchasing the truck and I had to put it back to stock.
Have my Toyo AT2's (same miles) also up for sale.  Was a GREAT combo.
At highest position, the shocks + 33" tire put me at 39" fender height.  Stock was 36" (with 50k on original tires).
What are all the specific heights of each settings on the 5100s?
NVM
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
What size are the Toyos?
Message sent.
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
