23 hours ago, bhales said:
perfect stance, good looking truck!!
17 hours ago, navyguy357 said:
Thats a good stance.
Sent from my SM-G955U1 using Tapatalk
23 hours ago, jwtero said:
Purchased my 2014 Sierra 4WD a month ago, was already leveled unknown kit. The oem Ranchos were garbage and worn. I installed the Bilstein B8 5100s after reading this thread. Set at highest setting, removed the lower level and kept the top of strut level piece installed. Upgraded to 2” rear blocks and measures dead level 40.5” all around. Installed the shocks on the rear bolts down with the sticker reading correctly. Rides great and planted. Also put on 285/55/22 Nitto Ridge Grapplers.
Perfect stance? It looks nose high like Cali style trucks. It may measure level but many people on here know that when you do that it doesn't look it...
I'd remove the top spacer and just run the Bilstein's at the top setting. This way it retains some rake as a truck should, doesn't look nose high and will wear less on the front end since stacking leveling kits and running that high is never good for the truck. Did you adjust your headlights down after all of this?
Tyler
I'm scared to see what your CV angles look like. Truck looks good, but I wouldn't leave it like that if you don't want your suspension components wearing out quickly
Tyler
I think the problem is that the top of the hood near the windshield sits higher than rear of truck which gives it that rear sagging height. That’s why trucks with a tad of rake look better (and level) because the hood angle and height is the same as the bed angle and height.
I agree that 3rd or 4th setting on the 5100’s is probably ideal for ride comfort, level look, and component longevity.
Been watching and reading this thread for a VERY long time now.
Finally bit the bullet and ordered everything.
2014 Sierra 1500 AT Extended Cab w/ 87k miles
Last piece of the puzzle is tires.
I will get everything installed and see what I actually have to work with.
Right now I am thinking 275/65/20's
What I ended up getting -
Camburg UCA's
6112's in the front
5160's in the rear
5160 mounting brackets
All new mounting hardware
Edited by mbatzel14
I have 3000k on the 5100 Bilstein rear shocks.
First impression is that they are firm and very similar to the procomp ones but seem to be more able to adjust the damping better. I have no dought they will perform well Towing. But next time I will get adjustable ones for the halfton ride that I bought the truck for. Coming down from a 3/4 ton.
On 7/21/2019 at 2:32 AM, Yondu said:
So nobody has swapped from 5100s to 6112s yet?
I was debating it...also debating unloading my truck for an F150.  :smash:
[emoji2961][emoji2961][emoji2961][emoji2961][emoji2961][emoji2961][emoji2961][emoji2961][emoji2961][emoji2961][emoji2961]
I'm at 100k miles. Stock suspension all around. Anyone tow heavy (9-10k) and do 6112 and 5160?
Also doing the z36 brakes + stainless brake lines at the same time.
I can verify that the part # you have is correct. I have a 2017 Silverado 1500 High Country with the 6.2L motor. Motor doesn't impact part #. BSN-47-273702 is the 6112 part # for 2014-2018 Silverado 1500's.
Part # for the 5100 series monotube = BSN-33-238319.
The 5100 does not come with Coils. I used the part # above for the rear.
Order eibach springs for your 5100's you'll be happy.
Sent from my SM-T580 using Tapatalk
I just received my 4600 bilsteins in the mail today from shock warehouse.  I was surprised that the front ones came in brown boxes.  Is this normal or can someone tell me if they're supposed to come in a different box?  Just seemed a little too "generic" for the packaging.
I have a small toy hauler that maxes out at 10k but is more like 8k when I tow it with a car inside - light car. I have the 6112 and 5160s but unfortunately haven't had the chance to install them yet. Hoping to get them on soon.
I have a '15 Sierra 6.2 Max Tow with 42k miles.
Anyone have a squeaky Bilstein strut? Ive got a squeak up front, passenger side. if I stand on the running board and rock the truck, squeak squeak squeak. Everything seems tight that I can tell.
EDIT...so it was the main top strut nut. Wasnt totally loose, but enough that it would allow movement and the squeak.
Replaced the sway bar bushing chasing the squeak and managed to snap one of the bolts. YAY
Edited by Roscopcoletrain
I had a squeak like this and it turned out to be a loose antenna. Sorry about your experience.
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
    • And overpriced. I was in the Oshawa Truck Plant when they were being built. Very few. I could count on one hand how many I've seen since
