Noisy K&N intake, anyone else?
Hey guys,
I threw a K&N cold air kit on my 5.3 today, and holy Moses does it ROAR in the cab when I get on the accelerator. I've never had one this noisy before. I also have a Flo Pro muffler, still too cheap for cat back exhaust. It doesn't really bother me that much, but it seems abnormally loud. Maybe it's just because the truck was so quiet before. I checked everything after taking it for a test drive and it was all still connected firmly. It's probably normal, but I figured I'd see what others have experienced.
You just have decide if a few hp are worth the noise. Its not for me.
You are experiencing 99.99% of the gains of a "cold air intake". Just like a cat back, the only real gains are sound.
I tried 2 different CAI kits ..... couldn't stand the noise. I settled on just the stock air box with a KN filter...
You're hearing all the noise the Helmholtz resonators cancel out.
Nah. That's the sound $300 makes getting sucked into your engine.
:rollin:
If I had known it would make this much noise I wouldn't have bothered. The throttle response is better though at least
Lol, I have spent $1700+ CAD including labour and 3 year warranty....... $400 - 500 gets sucked in, the rest gets pushed out :rollin:
K&N intake and Magnaflow exhaust :')
I'll take the better acceleration over the noise any day. The Airaid is just fine under normal driving and normal acceleration.
I't only goes when I punch it. There can be some growl if your going up a slight grade in the road. More so in V4 mode.
Yeah that is pretty much what mine is like. I'm getting used to it, and kind of like it now. It actually sounds like a truck not a minivan.
Has anyone compared the K&N and Airaid? I wouldn't mind o little more sound and throttle response, but don't want it obnoxiously loud. I had the K&N CAI on a 99 and thought it sounded great.
More of the 'you wasted your money, CAI do nothing" people chiming in again. Been proven time and time again that the decent CAI that do the R&D do actually produce and provide gains in HP and fuel mileage increases. I seriously doubt K&N/Airaid and any of the other reputable CAI companies would risk market share and their names by making a product that does nothing.
I wish I still had my dyno runs from my 2008 Corvette, I did runs with the stock setup, the Z06 airbox and a Airaid CAI kit. The Z06 system alone added 5rwhp over the stock LS3 system, the Airaid produced 7-8rwhp gains over the stock system and also smoothed out the A/F ratios as well. To get 7-8rwhp gains means you are getting almost 10hp at the motor gains.
10hp here and 10hp there in mods sure does start adding up in the long run.
OP if you don't like the noise of the K&N (the Airaid has it as well, as said once you remove the resonator the throttle noise is more pronounced) then I would suggest getting the Airaid MIT kit and a drop in low restriction filter for the stock airbox. Then mod the airbox as someone posted recently to allow more airflow into it and you will get some decent gains.
    • First time it really happened to me was when I was 69 yrs old and I was called "Old Timer" by a complete stranger. Then in rapid succession came the aforementioned "Old Man" and my favorite of all "Pops".
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
