so i went out to do my install. i searched and searched and could not find the 3 mounting bolts on the drivers side. i figured i would look at that side first because i didn't have to move the airbox lol. i could only find 1. i said hell with this, took it to the local garage i use. he did the install and recharge for $450. when i picked it up he told me why i couldn't find the 3 bolts. they weren't there! there was only 1 bolt on each side holding the radiator support in. he said he found 2 more laying down in there, but 2 were missing. and also another bracket was left unbolted. so either the cadillac/gmc dealer just half ass put it back together when i told them i wasn't getting the repair done there, or the chevy dealer that did the initial repair a year and a half ago didn't bolt everything back up. anyway, a/c is fixed and blowing ice cold now!
CLASSIC!!!!!!
Wow! I'd be livid. Rejection isn't an excuse for poor craftsmanship, do the job right or don't do it at all. Hope you don't go back to who looked at it the first time.
Just did this job a few weeks ago.  Got a new condenser from Performance Radiator (they are national) for $125 and comes with a lifetime warranty and the two gaskets included plus a new stud for the trans cooler fitting. Went to Oreillys for 1 large bottle of synthetic refrigerant and one small bottle (both have the oil in them).  I also rented the vacuum pump and manifold set to draw down the vacuum and remove water (this is why you need to run the vac pump for about an hour...the water in the lines will kill your compressor).  The rental is free if you return the pump within 48 hours.  Worked like a charm and no BS welds on the condenser like the GM OE.  There are some great videos that show you how to do this step by step.  Total out of pocket around $225 and 3.5 hours to do the entire job.
You can literally do this job in less than an hour.
Here is the video on how to do it.
If you are doing it in less than an hour, you are not vacuuming the system down and let it sit to make sure it holds.
Edited by Michael Box
Have there been any issues on the condensers for the trucks that use R1234yb?  I think this is only in the 2017 and 2018 models.
Ok. So I just did mine this morning. The 2 tiny gaskets at the stealer were $21. For 2 tiny friggin gaskets.. Install was a piece of cake even though it took a tiny bit longer because I have an S&B cold air intake and a second battery. They were both directly in the way of getting the crossbar out. I put 2 12oz cans of freon. Its actually 11 oz plus 1 oz of oil. Seems cold but this is the first time its been on since last season.  Total out the door is right at $200. Thats the freon, condenser, and gaskets.  The truck showed 80 degrees outside. And the engine was hot.
What gaskets are these? Ill be tackling this soon. Any other hard parts you needed like that.
Edit: Should have read, just did the AC ones for peace of mind. Ill probably reuse those.
Edited by jrob56
If you diy couple things (i didn't have to do my truck as it's under warr but just replaced the condenser on the kid hauler).
Local stores may only have 134a in leak proof  cans they seal off when the tap is removed, your traditional tap needs an adaptor, the one i had was irritating like eco gas cans. While i like the idea needs better execution, maybe there are better ones. Those stunk. The dupont freon only ones i got off amazon were easy to flow out of the can with traditional tap (night and day difference).
1 hour vac leak down test may or may not show a slow leak. It's testing under a vacuum but not pressure. I had to refill twice, my gauge wouldn't move in a couple hours even, it was only after a few months it went hot again that i thought to check the condenser (i had added dye) and saw the leak.
Lots of youtube videos on this, but the leakproof or whatever you call them cans add complexity to making sure you purge the line, it's really easy to get confused as it's another knob to turn, another possible leak point (and the cheap plastic adaptor is that cheap) and closing the tap does not close the adaptor and can. If you buy a typical cheap gauge set off amazon,etc calibrate the gauge, don't over tighten the hoses to the manifold (if your gauge goes to full retard when pulling a vacuum that's likely what you did). When pulling a vac if you want to be sure your lines are clear to the ac valve connects and you're pulling vac there, just remove the hose and push in and make sure it's pulling air at that point (it's noticeable from a change in pitch of the vac pump)
Somewhere in docs will be a recommendation to if you replace the consider to add an oz or so of pag oil.
Anyways no idea on the truck but the kid hauler was easy 30 minutes to flip it out tops and then pull a vac for an hour, wait an hour, then recharge.
Hardest part is the small cans are tough to weigh and that's the correct way, but whatever the truck takes hopefully works out pretty even adding in a bit of loss left in the can and small amount for purging the yellow line when you put a new can on (but the dupont cans went out really easy! i couldn't get those leak cans to flow out for squat without a bit of warming).
Does this condition eventually happen to all 2014's ? I have one with 53,000 miles and AC seems fine just wondering if I am on borrowed time. Is there anything to do on a preventative side to stop or slow down the cracking of the condenser ?
Thanks,
Yotaman
There is nothing you can do. I have 91,000 on mine and it was the original unit. Ive read where some were brand new and replaced again after 6 months.. So I think I was lucky.
Thanks,
Yotaman
I thought I was lucky, but got a leak in the same spot as everyone else, weld from dryer to condenser. Cross your fingers and deal with it one day unfortunately. 2014 75k miles
I saw one post where this was exaggerated,  but no confirmed owner doing it that soon. I may go aftermarket though, given the volume of issues with GM condensers. Think many DIY's are going this route.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
    • I read through that and I won't lie, my eyes rolled at some of the quirks about how it can turn off the trailer braking for example but I can see how it could help control or even up the torque applied to the ground with each wheel in a boat ramp scenario. But of course what it can't do is increase the torque to the wheels if the need is there as it ends up being like driving the four wheel drive version of a two wheel drive ( high range that is ). So far the neighbor that ended up with the 3.0 duramax with the max tow package which meant the 3.73 gears and high range only, I think its been doing ok for what he has been towing but doubt he ventures off into the soft stuff with his holiday trailer. He may have towed his dads river boat locally with it ( he always used his 6.6 duramax before ), I'll have to ask him sometime if he got into a lack of power to the wheels situation as after all that engine produces a lot of torque at low speed once the turbo winds out a bit and I think it has the 10 speed and if so they have a pretty good first gear ratio at 4.70 I see which is vastly better than the 3 or four speed overdrive models of years ago.
    • I did shorter OCI"s for many years without an issue, fights sludge and wear IMO. Recently started using Amsoil, will not do the recommended/advertised miles between changes.
    • It definitely seems quite evident that emissions and fuel economy targets rule above the best case scenario of what the engines best health and life could be otherwise. Items like DI and turbo DI engines with their LSPI issues as well as cats being reduced in life if the proper levels of certain additives were allowed to be utilized and so something has to be compromised and as you point out that is the engine protection from sludge, acid and wear which isn't in the manufactures best interest regardless to worry about in this race to profits from higher sales and so if the engines wear out sooner the next sale is closer at hand.    I am hearing that its likely the two new 2027 GM half ton truck engines will call for a 0W-30 oil, now if that is an existing oil I would have to think so but we will see in the coming months. Sadly as you've pointed out to me, over the last number of years the push has been on to reduce the actual operating temperature viscosity within each designated viscosity grade so that 11.5 to 12 range for a 30 weight for example is more in that just above 10 range at 100c along with that temporary viscosity sheer dropping it even further down as per that "energy conserving" designation, not to mention how some oils are not as sheer stable as would be ideal and that mixed with a long OCI paints a picture with a little too much glitter shall we say !.    All that and the warranty gods scaring the vehicle owner into sticking with that watery wine or risk loosing their warranty coverage if they go and use an oil that is of a higher viscosity even if it meets the emissions and LSPI requirements and would never damage the engine but may very well allow for an engines longer life depending on engine use scenarios ... high ambient temps, towing etc that push oils to their limits.
