On 8/21/2019 at 4:49 PM, Frank4202 said:
My tick was coming from the interior window trim which meets the headliner. I stuffed some foam in and havent heard the noise since. Good luck.
Do you have a picture of this area where you stuffed the foam in ?
I found this picture online. Its a piece of trim thats black in color. I was able to use a plastic trim tool and insert foam. Luckily, that solved my nose. Hope this helps.
My b pillar was ticking like crazy this morning - almost on every groove in the road.  (and of course my passenger seat was clicking and ticking like crazy too )
I saw something about finding the "b pillar pass through connector" and spraying expanding foam near it where two pieces of sheet metal are wedged together on a post about someone with a Chevy Colorado.  Does anyone know what that is ?  I'm assuming its where the wiring harness boot attaches to the pillar but I'm just taking a wild guess.
I don't have concrete proof of this, but I'm going to venture to say that isn't going to solve our issue.  The Colorado and Canyons ended up with a TSB that recommended set screws inserted above the pass through connector (about half way up the b pillar).  The pass through connector is where the wiring harness goes from the door into the b pillar.  It's a rectangular cut out a few inches tall by an inch or two wide.  Our issue is clearly coming from something in the base of the b pillar/the metal under the truck above the pinch welds.  I've had the dealer pad the hell out of my pass through connector and it hasn't done a whole lot to change my situation.
I actually captured a video under the truck this morning of my ticking noise.  I'll upload it to youtube and edit this post so it can be viewed.
Edited by davidsp101
Update
I can definitely hear it in that video, and that's pretty much what mine sounds like.
I wonder if its originating in that area where you have the camera pointed or "traveling" down the pillar into that area.  If we can hear it by our ears in the upper part of the pillar, maybe the source is also making the noise travel down as well.
When it happens it drives me bonkers...
Mine has gotten substantially worse this year.  I bought the truck in July 2018 and the ticking went away whenever the temperature was above 85 or below about 65.  This morning, it was 55 in SC and the thing did what I captured in the video above.  On the bright side, the dealer might actually be able to hear what I've been bitching about for a year.  On the other hand, if I have to listen to this all throughout the winter, I'll be in the market for another vehicle.
Yeah if I’m hearing this all year long during cooler weather too I’ll be seriously considering trading it in.
Funny I was thinking today about both my 2001 and 2004 Sierras I owned both brand new.  I don’t remember having these kinds of ticks and rattles in those trucks. But I honestly don’t know if that’s because I was apt to play music louder when I was young (or just play music more often as opposed to news or something like my boring self now). I can’t help but think that those trucks just didn’t have rattles like this one.
So I decided to buy some WD-40 brand White Lithium grease this weekend.  I put some on the passenger seat rails, the torx bolts that hold the seat rails down to the cab of the truck, and finally the bolts that hinge the back of the seat to the bottom of the seat, and it seems to have completely stopped the rattling noises in the passenger seat.  if this is all it takes I"ll be sooooo happy.  The grease was $8 at Lowes
For the B pillar noise I also decided to spray it on the rear door hinges where they connect to the b pillar as well as the door striker (for the front driver side door) that's connected to the b pillar.  I also sprayed it on the bolts and brackets that hold on my running boards underneath the truck.
I've driven the truck around for a couple of days as well as to work this morning.  I haven't heard any noises from either the seat or the b pillar.  I'm remaining cautiously optimistic that perhaps it was just the metal contact points needing some grease or lube to take care of these noises. I'm remaining hopeful and keeping my fingers crossed that hopefully this is all that's needed.  If it starts coming back I'll definitely post something here again.
Have you taken it back to the dealer lately since the weather is cooler?
 I was hearing mine on bumps again this morning (78 degrees when I was hearing it).  Its interesting, sometimes it'll tick only once but if its a strong enough jolt or bump it seems like it'll keep ticking for a second or two , like a fast Morse code.  Then it goes away until the next bump.
I haven't found a cool day in central SC when I had time to go to the dealer.  I'm already setting my work calendar for October and November so I can spend multiple mornings at the dealer.
Have an appointment to take mine in for the seat tomorrow. Driving me insane
I may mention the b pillar and see if they can spray foam in the pass through connector - although I don't have any faith they can fix any of it.
Toying with actually taking the truck to a stereo shop or something and seeing if they can take that pillar trim panel off and professionally put Dynamat and foam in there to stop it.  I'm sure getting the dealership to do it would be nearly impossible.
Edited by Bob Miller
How's your B pillar rattle been lately?  Mine was ticking and clicking like crazy this morning (still in the high 70s here in the mornings) - since its a Saturday I"m thinking about taking it apart and having a look inside there again...
Mine has been really bad.  Any temp between 65-85 and I’m screwed unless the sun is beating down on the truck.  It’s going to the dealer again Monday.
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
