Hey Phil, great video!!! Just wanted to know the part number for the latest 2018 center console because I really want the wireless charging feature. And the part number for that mounting bracket toward the front.
Harness works like a champ in the 16 Duramax. Thanks again.
Very glad to hear! Thanks for the feedback!
Hey Phil, I like the harness. I’m looking to do this on my truck it’s a 2014 Silverado, do you happen to have a list of the specific parts for the console if I do not have one yet? Maybe it’s just me but I haven’t really found a lot or anyone selling a console. I’m definitely open to advice on where to find the console if anyone on here has any suggestions.
Great Video !!!!  Just what I was looking for.  I just bought a 2017 Z71 LTZ  and have the same center console. I order a floor model console Should have all parts little high dollar. Where do I sign up for your plugs. I'm sure I will need them.
Frank
I bought mine of eBay so I don’t know/have a parts list. Someone did post one on another thread. I’ll see if I can find it and will edit the thread if I do.
Frank
Send me a PM and I’ll get ya payment instructions to move forward.
I got my floor console from gmpartsonline.com  cheapest new. But you would need the last 8 digits from a vin that has the floor console. This way you get the whole unit. don't try buying what they show on web sites. you need to give them vin and let them look it up. If you look it up you would be buying a lot of parts. So find a truck that is same year as yours with the floor console and use there last 8 vin numbers/ letters. You would have to buy side panels. Console does not come with it
here is two I found don't know if the first one will fit yours .  second one is up there but cheaper new.
https://www.ebay.com/itm/Chev-Silverado-2013-Center-Console-Sierra-Tahoe-Yukon-Suburban/253301980145?hash=item3af9f97bf1:g:kxEAAOSwAHtaKvKg
https://www.ebay.com/itm/Chevy-Truck-Silverado-2015-Black-Plastic-Center-Charging-Console/253235999082?hash=item3af60ab16a:g:NTwAAOSw4nhZ-NMX
Edited by Frank Jr
9 minutes ago, Frank Jr said:
I got my floor console from gmpartsonline.com  cheapest new. But you would need the last 8 digits from a vin that has the floor console. This way you get the whole unit. don't try buying what they show on web sites. you need to give them vin and let them look it up. If you look it up you would be buying a lot of parts. So find a truck that is same year as yours and use there last 8 vin numbers/ letters.
Thanks Frank, I’ll give that a shot!
Make sure it's the floor console you like. they have different trims. So what ever vin you give them will be the trim that came with that truck. They will give you part numbers and you will order what you need. There was a couple other items I had to order for this console so make sure you ask them if you need anything else. I paid $839.66 for everything new. But I have a 2017. When ordering parts do not put in your vin number. leave blank
Edited by Frank Jr
Frank, do you have any pictures of the finished install of the console in your 2017? Thanks for the help I think I’ve found one that will work!
No not yet. I'm still waiting for my new floor console to come in. I will post as soon as I have it install. It should look just like the one in Phil video. I should have my console sometime next week. The site had to order a couple parts that they were out of stock.
Hey guys - So I’ve had one member already who had fitment issues with my harness. He had the variant 23-pin X314 connector instead of the 16-pin X314 Connector like shown in the beginning of this thread.
I do not have provisions right now to support this version, so it is very important to know which connector you have under your seat.
This is the variant 23-Pin connector that my harness does NOT support at this time.
Jump Seat to Full Center Console Retrofit
Plug and Play Harness by PGAMBOA
For those of you looking to swap your Jump Seat to a Full Center Console, I now have a Plug and Play Harness for this upgrade!  This long awaited - PnP Harness will allow you to EASILY perform this upgrade.  NO cutting or splicing needed!
Center Console - Plug and Play Harness is $125 Shipped to lower 48.  For Alaska, Hawaii, and Canada, please PM me for a quote.
Since there are several versions and configurations of center consoles and truck trim levels, I feel that I have covered a majority of the configurations that are out there.  There will be several assumptions on the ability to perform this upgrade and I’ll try to be as detailed and comprehensive as possible.
Please see the different USB Cable configuration diagrams at the end.
Assumptions:
- 2014-2015 Center Consoles will have different USB Cable requirements than 2016-2017 AND will have different USB Hubs.  The PnP Harness should be compatible, but you MUST verify the connector under the passenger AND the front of the console!  Since this is a custom product, there will be NO REFUNDS on it.
- Center Console MUST have its factory harness intact and not modified.
- Connection under the Passenger Seat AND Front of Center Console must look exactly like the diagram.  There is a variant X314 Connector under the seat, so yours MUST match in order for this harness to adapt.
- Additional GM USB Cables must be purchased separately (based on your console year) to get USB Hubs functional.
- Wireless Charging - Wireless Charging became available on 2016 and 2017 consoles.  If you are looking at adding a Wireless Charging Lid to a 2014-2015 Console, please PM me for requirements.  Also, there are known issues with 2016/2017 Consoles with the Wireless Lid and charging iPhone 8 and iPhone X Phones.  There are workarounds for this that require some form of modification to the charging module.  You can also swap the module for a 2018 Module that DOES charge iPhone 8 and iPhone X phones.  Please PM me for questions on specifics.
- Your truck MUST have an existing 110V AC Outlet AND (1) - 12V DC Cigarette Lighter Plug as you will be reusing those.  My PnP Harness DOES NOT add the 110V AC Outlet if you don’t already have it.  However, I CAN add an additional 12V DC Outlet connection if needed.
- USB Cable connections will come from your HMI (Behind the Glove Box).  You MUST verify that you have the USB Ports available, otherwise, your USB Hubs will not work correctly.
- This PnP harness DOES NOT add any Car Play, Apple Play, or Android Play functionality.  If your truck did not already come with it, you will not gain it.
With this PnP Harness, you ***should*** have ALL the components in your console functional.
Those options include:
Front of the Console:
  • Front - Left USB Hub (Dual USB - 2016/2017or Triple USB Hub 2014/2015 - Uses my Plug and Harness AND a USB Cable from the HMI
  • Front - Left 12V DC Cigarette Lighter Outlet - Uses existing connections (truck must be equipped.  If not, I can custom add this if needed)
  • Front - Right 12V DC Cigarette Lighter Outlet -  Uses my Plug and Play Harness
  • Front - Right 110V AC Outlet - Uses existing connections (truck must be equipped)
Inside Storage Compartment:
  • Inside - Left 12V DC Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Inside - Right USB Hub - Uses my Plug and Play Harness plugged in the front main 42-Way Connector and USB Cable
  • Inside - LED Lamp - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Wireless Charging Lid (2016-2017 only) - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
Rear of the Console:
  • 12V DC - Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
THERE IS A LOT TO CONSUME HERE, SO PLEASE PM IF YOU HAVE QUESTIONS ON THIS.  I WANT ENSURE THAT YOU UNDERSTAND ALL THE REQUIREMENT FOR THIS RETROFIT BEFORE PURCHASING.
I'm interested in purchasing a pnp kit for a center console swap, 2014 Chevy Silverado
Thanks
Sent from my SM-G920V using Tapatalk
This is SWEET!  I guess I need to find a center console and go from there.  This will be wicked in a regular cab!
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
