The first picture is my door trim and the second is the floor console trim. It is silver. Smooth finish. The console is black. I would say it is the same as what you have.trim wish
  • Thanks 1
So here's everything I think I need. What part number are the front mounting bolts? I think those are the last thing I need and I'll be good to go!
That would be 11609982  you only need 2 of them. Don't forget to get ahold of Phil for the PnP cable.
Edited by Frank Jr
  • Thanks 1
Appreciate all the help Frank!
No problem at all. Thank Phil he was a very big help to me. His video made it happen. Plus the cable did wonders. With out it I would be scratching my head finding what wire went were.
FINALLY found time to fully install my center console. I have a 14 w the other connection, but Phil was nice enough to source my harness out my jumpseat to make my harness works. Even responded to all my texts promptly and figuratively held my hand during the install.7c872e6a0ef4ba3633108c688967ea34.jpge6800c33dc6a52fdd6a76e64ff81ce9f.jpg
Sent from my SM-G955U using Tapatalk
Anxiously awaiting my harness, Phil is very helpful.
Sent from my SM-G920V using Tapatalk
Was that Q meant for me?
Yeah it got a few scratches on side.
Curious to see if they'll come out.
Yup I’m new to this haha
I have the same exact scratches very annoying
I believe they are from hooking up seat belt. I just put in a new one and there was no scratches at all. Yesterday My son was the first person to sit on passenger  side  since install. well he is a little handicap. Has hard time putting on seat belt. Now I have pretty much the same scratches on the passenger side. I'm going to try amoral wipes.
Update on my center console, 2014 Chevy Silverado ltz, purchased the 23 pin varient harness from Phil Gambo, which worked great, I now have everything operational on my center console, connected green port on my hmi to brown connector on center console to power interior USB, aux, and sd card, thanks for all your help pgamboa!!
Quick question will a center console out of a 15/16 Silverado. Fit into a 2018 Silverado?
It should. There hasn’t been any physical change between the years.
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
