3 hours ago, AcVynom06 said:
Where can I order this pnp harness
https://harnessdr.com/product-category/jump-seat-to-center-console-conversion/
You may contact @pgamboa through his website (which is above) as he may have some validating to due and he's a very busy guy and get's a lot of PMs.  He also may be able to get you a brand new console set up too if you haven't already bought one.
If your truck is a 2016-2018, you can order here.
https://harnessdr.com/product/16-pin-center-console-conversion-harness/
If your truck is a 2014-2015, you can order this one. But PM me or email me at [email protected] before you order so we can be sure.
https://harnessdr.com/product/23-pin-center-console-conversion-harness/
Lead time is about 2-3 weeks to ship.
Thanks!
You may contact [mention=159655]pgamboa[/mention] through his website (which is above) as he may have some validating to due and he's a very busy guy and get's a lot of PMs.  He also may be able to get you a brand new console set up too if you haven't already bought one.
Thanks!
Another successful swap! Never got many photo's as I was time pressed. This console came from a 2015,  so I had to swap the USB hubs out to work with my 2018, and I do not have the wireless charging lid. But I'm not really worried about it. For the USB cables I went with the generic cables from Amazon and trimmed them (works surprisingly well.) Every function works as it should!  All in all Phil's harness is top notch, and if you never knew any better you would swear it's OEM. Another thumbs up here, Thanks Phil!?
Just as a heads up for any Canadians browsing this thread,  im from NL, Canada! Any Canadians looking into doing this swap, shipping the harness with Phil is no problem... Tracking down a console in Canada for a reasonable price is the tricky part it seems.
Edited by Crisby
Another successful swap! Never got many photo's as I was time pressed. This console came from a 2015,  so I had do swap the USB hubs out to work with my 2018, and I do not have the wireless charging lid. But I'm not really worried about it. For the USB cables I went with the generic cables from Amazon and trimmed them (works surprisingly well.) Every function works as it should!  All in all Phil's harness is top notch, and if you never knew any better you would swear it's OEM. Another thumbs up here, Thanks Phil![emoji106]
Just as a heads up for any Canadians browsing this thread,  im from NL, Canada! Any Canadians looking into doing this swap shipping the harness with Phil is no problem... Tracking down a console in Canada for a reasonable price is the tricky part it seems.
Looks great! Thanks for sharing. If you get a chance, I would love your review on my site :)
Thanks again!
On 12/13/2017 at 10:35 PM, pgamboa said:
Jump Seat to Full Center Console Retrofit
Plug and Play Harness by PGAMBOA
For those of you looking to swap your Jump Seat to a Full Center Console, I now have a Plug and Play Harness for this upgrade!  This long awaited - PnP Harness will allow you to EASILY perform this upgrade.  NO cutting or splicing needed!
Center Console - Plug and Play Harness is $150 Shipped anywhere in the US. For Canada, please add $24.95.
Since there are several versions and configurations of center consoles and truck trim levels, I feel that I have covered a majority of the configurations that are out there.  There will be several assumptions on the ability to perform this upgrade and I’ll try to be as detailed and comprehensive as possible.
Please see the different USB Cable configuration diagrams at the end.
Assumptions:
- 2014-2015 Center Consoles will have different USB Cable requirements than 2016-2017 AND will have different USB Hubs.  The PnP Harness should be compatible, but you MUST verify the connector under the passenger AND the front of the console!  Since this is a custom product, there will be NO REFUNDS on it.
- Center Console MUST have its factory harness intact and not modified.
- Connection under the Passenger Seat AND Front of Center Console must look exactly like the diagram.  There is a variant X314 Connector under the seat, so yours MUST match in order for this harness to adapt.
- Additional GM USB Cables must be purchased separately (based on your console year) to get USB Hubs functional.
- Wireless Charging - Wireless Charging became available on 2016 and 2017 consoles.  If you are looking at adding a Wireless Charging Lid to a 2014-2015 Console, please PM me for requirements.  Also, there are known issues with 2016/2017 Consoles with the Wireless Lid and charging iPhone 8 and iPhone X Phones.  There are workarounds for this that require some form of modification to the charging module.  You can also swap the module for a 2018 Module that DOES charge iPhone 8 and iPhone X phones.  Please PM me for questions on specifics.
- Your truck MUST have an existing 110V AC Outlet AND (1) - 12V DC Cigarette Lighter Plug as you will be reusing those.  My PnP Harness DOES NOT add the 110V AC Outlet if you don’t already have it.  However, I CAN add an additional 12V DC Outlet connection if needed.
- USB Cable connections will come from your HMI (Behind the Glove Box).  You MUST verify that you have the USB Ports available, otherwise, your USB Hubs will not work correctly.
- This PnP harness DOES NOT add any Car Play, Apple Play, or Android Play functionality.  If your truck did not already come with it, you will not gain it.
With this PnP Harness, you ***should*** have ALL the components in your console functional.
Those options include:
Front of the Console:
  • Front - Left USB Hub (Dual USB - 2016/2017or Triple USB Hub 2014/2015 - Uses my Plug and Harness AND a USB Cable from the HMI
  • Front - Left 12V DC Cigarette Lighter Outlet - Uses existing connections (truck must be equipped.  If not, I can custom add this if needed)
  • Front - Right 12V DC Cigarette Lighter Outlet -  Uses my Plug and Play Harness
  • Front - Right 110V AC Outlet - Uses existing connections (truck must be equipped)
Inside Storage Compartment:
  • Inside - Left 12V DC Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Inside - Right USB Hub - Uses my Plug and Play Harness plugged in the front main 42-Way Connector and USB Cable
  • Inside - LED Lamp - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Wireless Charging Lid (2016-2017 only) - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
Rear of the Console:
  • 12V DC - Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
THERE IS A LOT TO CONSUME HERE, SO PLEASE PM IF YOU HAVE QUESTIONS ON THIS.  I WANT ENSURE THAT YOU UNDERSTAND ALL THE REQUIREMENT FOR THIS RETROFIT BEFORE PURCHASING.
16-Pin - Plug and Play Harness
23-Pin - Plug and Play Harness
3 hours ago, vic Vega said:
I need a 16 pin adapter for my 2014 Silverado can u get back to me to 9563324421 am really interested it in on
Most all 2014 trucks don't have a 16-pin connector.  Have you checked it?
Here are links to order. Please note, if you do have the 23-pin version (which is likely you do), you need to order the 23-pin and send your jump seat harness in for be to rebuild.
http://harnessdr.com/product/16-pin-center-console-conversion-harness/
http://harnessdr.com/product/23-pin-center-console-conversion-harness/
Please note, we will be closed from 10/30 - 11/9 and will resume operations on 11/10. We will fulfill as many orders as we can before we close and will resume where we left off when we return.  Orders will be fulfilled in the order they came in.
Just realized I have a older style console with only one plug neighboring the 16-pin. It’s going into a 2018 w/o a 120v. Does that mean I’ll have to trim a USB cable and lead it from brown to black on the HMI?
If you can't get a factory USB cable, yes. You'll also need to replace the USB hubs to the ones from a 2018 to retain  Apple car play/Android auto if you truck has this.
Do you have an HMI behind your upper glove box? If so, that usb cable terminates into the black port if the HMI. You also have a green port that can be used but will be deleting the glove box port.
Morning fellas.
under my glove box looks like this. Where do I go from here?
Just started working. No HMI! Do I have to route through the radio?
This means your USB route goes behind the radio. What usb cables are you using? GM factory ones or amazon generic ones? If GM cables, which color cables?
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
