On 12/13/2017 at 11:12 PM, pgamboa said:
What this comes down to is:
  • My Plug and Play Harness
  • (2) USB Cables - based on the console year your purchased
Thanks guys!  I'll be filling orders on my waitlist, then everyone else on a first come, first serve basis.
I need the pnp just like the one you show in your YouTube video. It is a 2016 model and the console came out of a 2016.
Let me know how to pay and get you shipping info.
[email protected]
[email protected]
Curtis, send this to me in an email please. Email me at [email protected]
Thanks,
Phil
So this tool just pulls it all out from the front without taking anything else apart?
I think so.
On 12/13/2017 at 9:35 PM, pgamboa said:
Jump Seat to Full Center Console Retrofit
Plug and Play Harness by PGAMBOA
For those of you looking to swap your Jump Seat to a Full Center Console, I now have a Plug and Play Harness for this upgrade!  This long awaited - PnP Harness will allow you to EASILY perform this upgrade.  NO cutting or splicing needed!
Center Console - Plug and Play Harness is $150 Shipped anywhere in the US. For Canada, please add $24.95.
Since there are several versions and configurations of center consoles and truck trim levels, I feel that I have covered a majority of the configurations that are out there.  There will be several assumptions on the ability to perform this upgrade and I’ll try to be as detailed and comprehensive as possible.
Please see the different USB Cable configuration diagrams at the end.
Assumptions:
- 2014-2015 Center Consoles will have different USB Cable requirements than 2016-2017 AND will have different USB Hubs.  The PnP Harness should be compatible, but you MUST verify the connector under the passenger AND the front of the console!  Since this is a custom product, there will be NO REFUNDS on it.
- Center Console MUST have its factory harness intact and not modified.
- Connection under the Passenger Seat AND Front of Center Console must look exactly like the diagram.  There is a variant X314 Connector under the seat, so yours MUST match in order for this harness to adapt.
- Additional GM USB Cables must be purchased separately (based on your console year) to get USB Hubs functional.
- Wireless Charging - Wireless Charging became available on 2016 and 2017 consoles.  If you are looking at adding a Wireless Charging Lid to a 2014-2015 Console, please PM me for requirements.  Also, there are known issues with 2016/2017 Consoles with the Wireless Lid and charging iPhone 8 and iPhone X Phones.  There are workarounds for this that require some form of modification to the charging module.  You can also swap the module for a 2018 Module that DOES charge iPhone 8 and iPhone X phones.  Please PM me for questions on specifics.
- Your truck MUST have an existing 110V AC Outlet AND (1) - 12V DC Cigarette Lighter Plug as you will be reusing those.  My PnP Harness DOES NOT add the 110V AC Outlet if you don’t already have it.  However, I CAN add an additional 12V DC Outlet connection if needed.
- USB Cable connections will come from your HMI (Behind the Glove Box).  You MUST verify that you have the USB Ports available, otherwise, your USB Hubs will not work correctly.
- This PnP harness DOES NOT add any Car Play, Apple Play, or Android Play functionality.  If your truck did not already come with it, you will not gain it.
With this PnP Harness, you ***should*** have ALL the components in your console functional.
Those options include:
Front of the Console:
  • Front - Left USB Hub (Dual USB - 2016/2017or Triple USB Hub 2014/2015 - Uses my Plug and Harness AND a USB Cable from the HMI
  • Front - Left 12V DC Cigarette Lighter Outlet - Uses existing connections (truck must be equipped.  If not, I can custom add this if needed)
  • Front - Right 12V DC Cigarette Lighter Outlet -  Uses my Plug and Play Harness
  • Front - Right 110V AC Outlet - Uses existing connections (truck must be equipped)
Inside Storage Compartment:
  • Inside - Left 12V DC Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Inside - Right USB Hub - Uses my Plug and Play Harness plugged in the front main 42-Way Connector and USB Cable
  • Inside - LED Lamp - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Wireless Charging Lid (2016-2017 only) - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
Rear of the Console:
  • 12V DC - Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
THERE IS A LOT TO CONSUME HERE, SO PLEASE PM IF YOU HAVE QUESTIONS ON THIS.  I WANT ENSURE THAT YOU UNDERSTAND ALL THE REQUIREMENT FOR THIS RETROFIT BEFORE PURCHASING.
16-Pin - Plug and Play Harness
23-Pin - Plug and Play Harness
I would like a harness for ‘18 GMC Sierra
I am having no luck finding a center consol for my 18
email Phil (pgamboa) [email protected] he will hook you up in no time.
I got mine from him,installed it a couple weeks ago
Edited by WNYK2
Please send email to [email protected]
I need this setup and been trying to get a hold of you.
Email sent.
Could you put together a “body wiring harness” for my 2016 with the back powered sliding window/sunroof option? It comes out of the fuse box located next to the driver’s side door.
A little late getting to this, but I finished my console swap two weeks ago. pgamboa can add another check mark to his success stories here. The ordering process was quick and painless (except for the hit to my wallet ?), but this was definitely worth every penny and much easier than sourcing everything yourself. All the parts arrived ahead of pgamboa's estimated time of arrival, his harness is very impressive and well constructed. I wouldn't be surprised if someone told me it was an OEM part without knowing anything about it. The console itself came packaged very securely with tons of packing material and a sturdy box, no damage or defects at all. It took a buddy and I about 2 hours to get it installed. All USB ports, the 110v Outlet, 12v outlets, and wireless charger are working, the only thing that doesn't seem to be working is the AUX port inside the console. But, my phone does not have a headphone jack so I'm not sure it would be used anyway. I was also able to retain glove box USB functionality as well.
Before:
Shipping Box:
Console and Bracket:
Finished:
Phil,
I am doing a center console upgrade in my 2015 Tahoe and need the part number for the mounting brackets that it bolts up to under the dash.
Thanks for your assistance
On 9/6/2019 at 8:15 AM, Neal Lanham said:
Hello can you send me some information on how to order the harness for the console swap?
Neal, thanks for your order!  I will have it shipped in the coming weeks.
I don't think I can build this.  From what I know, the power for the overhead console switch has been present in almost every truck I've observed attempted this rear sliding window install along with the sunroof.  All that wiring in the overhead console was present.
The wiring for the sliding motor part lives on the back wall along with the rear window defrost.  That wiring goes forward...But I haven't had a request to build these...
Before:
Shipping Box:
Finished:
Thanks for sharing!  Truck looks great!  Thanks for your business and support! #ModON!
9 hours ago, ashtondm said:
Phil,
You'll want to reach out to @cmatt for this.  He should be able to take care of you.
34 minutes ago, Scott68 said:
I wish to purchase your plug & play cable ..
Please email me at [email protected] to validate your build and get you ordering instructions.  When emailing, please provide me the year of your truck and pic of the front dash showing the radio/screen
Phil,
do you have any advice or instructions on upgrading the radio in a 2015 Tahoe PPV running IO3 to the IO6 8'inch screen apple and android play  I know that I need to replace the HMI to HMI2.5, radio and navigation module.   I was told that I pretty much will have to rewire the entire dash but I have seen systems that say 90%plug and play.
Aso since I am upgrading my pump seat to a center console will I need to also order your plug and play harness and will yours work on a US tahoe PPV as well.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
