Here's The Nine Ways You'll Be Able To Order Your 2019 Silverado
Zane Merva
Executive Editor, GM-Trucks.com
4/25/2018
Or at least during the start up of production. GM-Trucks.com has learned exclusive details surrounding the production start up of the 2019 Chevrolet Silverado after obtaining pages from the model's "Dealer Ordering Playbook"
Earlier this morning we reported on the start up timing of the 2019 GMC Sierra. The Sierra will only be available in two trim levels at SOP, Denali and SLT.
The Silverado seems to be a different story. Dealers will appear to have a choice of nine pre-configured models to choose from.
The dealer playbook makes a note that..
At launch, we will provide nine specific ordering configurations for the five available trim levels to ensure launch excellence. These configurations align with requests from the Dealer Pilot Order process. Orders outside the nine configurations could result in constraints being added and possible order cancellation.
The First Five Models Available Are
  • LT
  • RST
  • LT Trail Boss
  • LTZ
  • High Country
The Nine Configurations Dealers Should Order Are
  1. LT All-Star
  2. LT All-Star Z71
  3. RST All-Star
  4. RST All-Star Z71
  5. LT Trail Boss
  6. LTZ Plus
  7. LTZ Z71
  8. High Country
  9. High Country Deluxe
Standard Equipment For The Five Trims
So what do you think? Do any of those nine configurations sound like something you'd order?
I saw on the internet Sierra At4 that you can option a 6.2L..it doesnt appear this is the case with the LT Trail boss?  I'm on the fence about the trail boss..will have to test drive it and see how the 8spd is and the mileage figures etc.
Any pricing details?
Looks like a custom order if you want the max trailering package.  It isn't listed. If it like current production. You can't get the max trailering package with the Z71 package. Hopefully you can configure a little more of what you want.  If not then GM didn't listen to the 7,000 people they interviewed in wanting more flexibility on ordering a truck.  Still stuck getting an upper trim model just to get certain items.
Also looks like the diesel engine isn't going to be available until late fall if they haven't released any info on it yet.
Noticed it stated hp and torque for 5.3 and it says the same numbers as now. also noticed under exceptions included as you step up the model grades it notes 2 speed transfer case . Are some models not going to have a hi-lo transfer case ?
probably not,  most Tahoes  already have the transfer case with no 4 low. I'm guessing the pickups will be the same way now.
51 minutes ago, Lilcanadian said:
So I guess the 6.2 won’t be available in RST trim??
No, the 6.2 will be available in LTZ or High Country trim only just like the current trucks.
Nick, you won't be able to get both the NHT max-trailering package and Z71 package together, each package has their own unique shocks and springs,so it makes getting both impossible (Its always been like that since the NHT package came out in '06)
Also I can tell you that the NHT package won't be available at the start of production, nor will the 3.0 diesel engine.
One would think that GM would at least get the diesel out sooner than later since Ram and Ford will have and have theirs out.
Total b.s. GM
Sent from my SM-G930W8 using Tapatalk
Well I guess because the Tahoe RST can get the 6.2 I thought the Silverado RST might have a chance of getting it too, that’s too bad.
Make mine an RST I guess... Maybe an LTZ I dunno... Won't be buying a 19 anyways... Probably hold off for a 2021... 40k miles on my 2016 now and if I keep putting 25k a year on it I'll probably try to trade in before 150k miles rolls around...
On ‎4‎/‎25‎/‎2018 at 12:13 PM, Zane said:
Zane Merva
4/25/2018
  • LT
  • RST
  • LT Trail Boss
  • LTZ
  • High Country
  1. LT All-Star
  2. LT All-Star Z71
  3. RST All-Star
  4. RST All-Star Z71
  5. LT Trail Boss
  6. LTZ Plus
  7. LTZ Z71
  8. High Country
Can there be options added to one of the configurations you has chosen? I'm interested in the LT Trailboss all the options listed in the configuration I wanted,  But a sunroof isn't in the configuration shown, But it is option for the lt trailboss on the order guide with optional leather package and convenience II package.
From what I can discern, dealers can make orders that are outside of the nine recommended configurations but have been warned they might not be built quickly and/or the order might be outright canceled by GM.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
