GM Recalls Canadian Silverados and Sierras For Fire Risk
On 2019-07-16 at 4:15 PM, HondaHawkGT said:
I guess there was a 2nd older recall for the K2 truck's rear window because they would where they would shatter. The article I read on another website mentioned the shattering glass but didn't make it clear enough that it was a separate older recall.
Some of the shattered glass victims also had truck fires. The breaking glass I believe was caused by overheating the window element when the circuit had moisture on it. Many reported burned seats and there were a few total loses. It could be two different problems but I believe they are tied together.
Yes, its a shame that USA trucks are not recalled also as many members here from the US have experienced exploding rear sliding windows.
There claiming it's how they are used.  I now picture my fellow Canadians driving around in the rain with the back window open lol
From what I've be able to find it was Transport Canada that has forced GM into the recall.  They usually only follow the US on recalls.
This is unusual lol.
Not taking mine in unless they have a real fix regardless. With my luck they will disable it and then just say oh that's good enough.
Makes me think of all of the GM customers that lost their heated windshield washer systems.  GM took them out then never came up with a replacement or fix.
I keep waiting to see if the fix will be just to replace the slider with a full glass windows.
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
