06 Silverado 2500hd 6.0
My Silverado is getting really hot while towing up hill, to the point that the "Engine Coolant Hot" light is coming on. (Which I stop and let it cool down). This has gradually gotten worse. Truck does not get hot while towing on flat terrain. Any ideas?
could be a problem with the thermostat, or radiator fins aren't clean, or you've put some bling up front that reduces airflow through the rad, or some of the ducting up front is missing (that directs air to the radiators), or water pump isn't pushing enough water (problem with the impeller in the pump)
Flush the cooling system. Remove the T stat housing and really flush it out. If you tow a lot, you can use a 160 T-stat, which works well, and engine still runs in closed loop.
I would also upgrade the stock transmission cooler to one twice the size ( easy with grill off)
As talked about above, make sure the radiator is clean. If you are towing in areas with high altitude, you need all the air you can get. Confirm the thermostat is fully opening, and check water pump pressure and radiator cap. If the cap is failing you will not maintain a properly cooling system.
Thanks for the responses. No bling added to my truck, its as stock as can be. It doesn't have and issue with temperature unless towing uphill. I took my grill off about a month ago and cleaned off the radiator and condenser with compressed air... didn't make a difference though. I'm having to pull over sooner and sooner to let it cool off. I've reached in and tried spinning the fan and it seems really tight and barely spins. I will test some of the above mentioned and see if that helps.
You need to check the fan clutch while hot. You tube has several videos. Basically at idle, take a rolled up newspaper and slowly advance it into the fan. It should resist stopping. I've seen clutches seem to perform correctly until this test
Ok. I will test it out tomorrow. Thanks
I took the truck for a drive and let it heat up to operating temperature. I did the test and had no change in fan speed. The newspaper didn't effect it.
  • 7 months later...
In the process of replacing radiator, fan clutch, water pump etc. Here is the fan-side of the radiator. Quite a bit of smashed fins. Do you think that is enough to cause my overheating issue? The pics don't really do it justice either.  I'm replacing it anyways, just wanted some reassurance that I'm heading down the right path.
Sure can.  Probably wore out inside too.  Same with condenser.
Mine has the same issue. Plugged radiator...use of wrong coolant will cause it to gel up inside, thus clogging it up.
I took the stack apart last spring> I noticed the air "holes" in the intercooler are larger the the radiator. This causes debris to pass through the intercooler and get caught in front of the radiator.
After cleaning radiator of gunk and dead bugs, I noticed the transmission a lot cooler when towing a 7,000 pound trailer all the way to Key West in early July.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
