Russ
That looks great. I'm going to do the rear entry as well. I just need to find time. BTW I'm in Torrance too.
Sierra Spec Morimoto 4300K kit is now installed and here are my thoughts.
Overall quality of wiring, relays, and ballasts were very good.
I was disappointed in the bulbs.
You'd of thought they might have tested them first on a GMC to make sure they fit properly when screwed in.
My driver's side bulb was out of wack as it pointed down and to the right.
Made several attempts to correct until it was orientated correctly.
I'm happy with the light output vs stock.
Not impressed with the fit of the bulbs as shipped from The Retrofit Source.
I'd say the color match is very good, I can't see a differance from the DRL's. I originally was going to have a shop near me do the work but after a few minutes of explaining to them how to do this retrofit I lost all confidence in them, and they wanted $400 for the labor just for the headlight mod. I still had to get the lights out, back in , and wire it all up.
The hardest part or the retrofit, in my opinion, was keeping debris out of the housing. I learned fast that taping up everything was the way to go. If you are patient and have good jimmy-rigging skills, I'd go for it.
I'm pretty handy. My only worry is I don't want to end up messing up and screwing the $700 headlight. I think I will end up doing it myself. Shop near me wants $550 for parts and labor and a weekend to do it. And just like you, I would still be the one to pull the headlights off and put them back on the truck.
Just wanted to post this for anyone who has a Sierra SLT/ Denali/ AT and wants to do some work to the headlights. These headlights are pretty costly, around $700 a piece I think huh? Well while searching the interwebs I came across this on ebay! Its our Headlight with the LED strips but for only $175. How they are going for so cheap I am not sure, but if you are looking to do some work on you headlights I would probably order one of these and try working on this first. That way if you screw anything up you know that you havent screwed yourself or the headlights on your truck. You could either go this route or you could always just do the work on your driver side headlight first and if anything goes wrong, you could order this headlight.
http://www.ebay.com/itm/Genuine-OEM-2014-2015-GMC-Sierra-LH-Driver-Side-LED-Headlamp-Headlight-/331353610524
Oh man I wish they had the RH one as well and I would totally pick up a set for my SLE, when I bought my truck 3 weeks ago the salesman told me it had the LED headlights and halfway through buying it I noticed it didn't and they looked into putting them in at $800 each and would do nothing for me so I was a little peed as I love the LED DRL look, he said even if I had them put in they had to program something in the truck to change it from the headlight DRL to the LED DRL, a pair of these and some programing would be cheap enough but I see there are no RH ones for sale :(
Chad
Chad
From what I've heard you would also need to change a harness to make it all work right ontop of the programming.
Message the seller! It's possible that they have a set for drift cheap!! Couldn't hurt to ask.
Probably should have just got an SLT or All Terrain lol, I'm sure the harness wouldn't be cheap if I would need to get it from the dealer haha
FWIW, I installed this same Sierra spec kit last night and had no issue with the fitment or orientation of the bulbs at all. I was actually impressed how well that part of the install went, my bulbs twisted into position easily and felt very snug. I took a pic of the stock bulb before removal and noted where the wide and narrow tabs were once I had it out, and used that as a reference to be sure I had the TRS bulb oriented correctly. I did not check to see if it could be installed in an incorrect orientation though. I didn't think that was possible with the 9012 bulbs. The return wires on my bulbs are facing downward, so hopefully that's correct. My light pattern seems consistent with others I've seen here, and so far I'm really happy with the light output. Except for the radio reception issue, I'm very happy with the kit for the price and a few hours labor. Big improvement. Edited by JTWOLD
We installed the bulbs easily as you stated.
However once got to drive at night the light pattern was awful.
After more testing noticed it was the drivers side pointing right and down.
Very distracting since it illuminated sidewalk, curbs, ditches, and the shoulder of the road only.
Reoriented the bulb and they are good now.
Great light output and thankfully no issues with radio reception.
Thanks Chris -- Do you know the position of the wire on the HID bulb as you have them installed? My cutoff looks pretty clean on buildings. The picture was taken very close to the headlight just to capture any bright or dark spots. I have several minor shadows across the beam on the ground in the dark
Red wire is up, blue is down.
For those of you with buzzing ballasts; Double check your ground integrity and your wiring polarity. Because load is highest on bulb start up, any resistance in your ground circuit can cause those issues. Also, some of these systems will function with improper polarity at the ballast input from the vehicle harness. However, the relays will buzz due to current flowing the wrong direction through the relay. Just a couple things to check.
The relays don't buzz for this reason, the BCM sends a pulsed output to the factory bulbs (unknown why) and the capacitor filters this out so the relays stay on constant.
The high frequency ring or whine you hear at the ballast is due to the high voltage AC that is needed to ignite the hid bulbs, once the halide salts evaporate the current draw is less and they quiet down some but they will always make that high frequency sound when in use.
Also the buzzing relays without the capacitor installed only happens when the engine is running.
Is the sierra kit a easier install? What's different about it?
Looks to be the same as the TRS Mopar Low beam kit that has been referenced on here a few times. I'd imagine they just re-listed it under the Sierra name with just the 9012 bulb options available for clarity.
Hi everyone I have been in contact with my dealership and customer care and just a heads up they are getting enuf complaints about the projectors and poor light quality that gm is working on a fix I have seen the e mails from gm customer care also informed me the more complaints the get the faster a fix will happen
Thats great news! Free factory HID kits for everybody!! haha...only in a perfect world.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
