All I can say is that after installing my TRS 55W kit I'm super impressed. The amount of light output is unbelievable.
I was worried that I would still need to do the FXR upgrade but I'm thinking that I don't need to worry about that for now.
Thanks for the all tips on this thread.
Confirmed.
Ultra HID w/ CAN-bus from DDM work without a harness. Super easyon the 2014 Silverado LTZ too!
Are u running a relay harness or literally just the kit?
Just the kit, no harness. You don't even need to ground it although I did. This truck doesn't send a pulsing ground signal.
I have a question that hopefully someone can help with. I plan on getting me the oe style projector headlights but run LED pods as the high beams but got a question for what to run as the low beams. Should I go HID or LED bulbs? I know some have mixed reviews of both but too LED bulbs now have heat sink ribbon type thing instead of the fans now too but which is the best option? I don't plan on retrofitting. Just looking for a simple plug and play
Hid. Leds are bright but just don't give off as much light.
Sent from my SM-N920V using Tapatalk
I recently installed TRS's Morimoto kit for my 2014 Silverado with projector headlights. The lights are super bright, but the pattern seems off. Does anyone else's light pattern look like this with the stock projectors? I did order the H11b lights, and they are seated completely in the housing from what I can tell...
Your bulbs are upside down. Flip them over and you'll be good.
Some fxr action and switchback boards.
Check out @poopypaul on IG to see his sick setup.
More info on this mod please, didn't realize the strips on the top and bottom can be replaced with a better setup.
I finally got a chance this weekend to look at the lights in more detail to figure out the problem. It turned out that the bulbs weren't upside down, but they were turned slightly so that the wire was facing between 7 o'clock and 8 o'clock. I turned the bulbs so that the wire was facing directly to 6 o'clock and now I have a nice cutoff line with no shadows in the beam. Also, the problem of the light pattern wiggling is now gone. I figure the light pattern wiggling was due to the wire vibrating and I was seeing the movement from it in the shadow.
I hope that helps someone who doesn't have that clean cutoff line or a light pattern with shadows in it.
It's Diode Dynamics direct replacement boards. Direct PNP swap but you will need to open the headlights to do it.
- Mike
IG: @BlackPearl_Edition
Man been a while since I've been to the forums. Having a problem with my HID's again.. Intermittently the passenger side will not come on immediately, I have to turn them off and on a couple times to get it to come on. It did it about a month ago and I swapped the ballast to see if the problem would follow and no luck. I moved some wires around and chocked it up to a pinched wire. Well now the problem is back. I'm displaced right now too with all the flooding in Texas so I don't have a lot of time to take it apart and look at it. Just seeing if anyone else had a similar experience..
My first guess would be to check the grounds. I developed a loud buzzing on a very humid evening here in SC. I opened up the hood and began reworking my ground at the radiator support. So far no problems.
Anyone go from factory standard lights like on my Silverado LT Z71 to Projection or put the mean looking 2015/16 headlamp assy in a 2014. Looks like they will fit with the factory hood. I can be reached directly at [email protected]
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
