Update: The Goodyear LS-2s were taken off and swapped for Michelins yesterday...I had time to run the truck today up on the highway. What a difference!! The truck runs nice, smooth and quiet....until you take it over 70MPH!!!! ITS STILL SHAKING :dunno: ........I talked to the dealer and let them know the vibrations are still present...in a weird way I actually feel bad for the dealer in that GM left them holding a leaky bag with SOME of these trucks. The dealer told me they did a traditional balance because they do not have the road force balancer.
Based upon my latest vibration test, I am convinced its something related to wheel speed however not necessarily the tires. (See the red spike on the attached pic in the 800 RPM range at 75mph.) That spike is on the X-Axis meaning it is a shake from left to right, (driver side to passenger side).
I may pop the wheels off and check the runout on the hubs and rotors with a dial indicator. Can anyone think of anything else that spins at wheel speed that I could easily check while I have it apart? I am open for suggestions!!
I think your on the right track by using a dial indicator, however I would check run out on the wheels first then the hubs. Check your driveshaft run out too if you can rig some kind of fixture. I bought a new Ford F150 in 1984, it had a nagging vibration, dealer was no help, I suspected the driveshaft, had a driveline shop inspect, it was bent and the balance weights were 180 degrees off, $100 took care of it. Only other issue I can think of would be a torque converter out of balance.......best of luck.
Edited by beetle
I have a friend that has the driveshaft balanced on each new car he gets. I do such if the new tires, true and balance and new shocks do not result in a good smooth vibration free ride.
I know it came up in this thread that there were possibly a batch of bad wheels or driveshafts. I forgot to mention that I did check the runout on the driveshaft and wheels and they were all spinning true. Obviously I wasn't able to check the balance on the driveshaft at home, but since my tires have been replaced all is well! I got a chance to get out the past few days and put some miles on the truck with the new tires and rebalance....its still good no vibrations!
Glad you found the solution.
My local dealer fixed a vibrating truck by replacing the front right cv joint.(I think that what they are still called) Unfortunately that wasn't the case with my truck, but may be with those of you who feel the vibration in the steering wheel.
Well, my truck is still in the shop for the vibration. Guess they will do software update on while its there. News said that there has been 8 fires so far.'mostly while ideling in frigid temps.
But back to the shake. The loaner I have has 20" continentals on it. Vibe hasn't been bad at all till this morning on my way to work. About 75 mph it was shakin pretty bad. Put it in neutral. That didn't change anything. Shop foreman at the dealer told me last week that the tires get flat spotted sitting overnight and have to get heated up. My 2010 didn't vibe in the mornings. Someone please edumicate on this
That's bs... My mustang with soft drag radials in summer don't get flat spots sitting for a month
Sent from my HTC6500LVW using Tapatalk
Trucks in shop now. First oil change tire rotation.. Fixing alignment
Do you have vibration probs? Do you have vibration probs?
Yuuppp
72mph.
This definitely happens. Not so much in the summer but definitely the winter. Should stop after a couple miles...
Sent from my SCH-I535 using Tapatalk 2
My dealer gave me a bunch of shit today about having to test ride the truck and it won't be looked at till Thursday or later because of my vibration... And get this, they said mine was the first to come in for this reason... yea...
I ended up going straight to Goodyear and they force balanced the tires and found one wasn't able to be balanced at all. Plus 3 out of the 4 were WAY off. Tire will be in tomorrow and replaced under warranty without going through the dealers crap. The tire machine said the tire was balanced, but then they ran it they told me to watch because it was so bad. The machine was literally shaking laterally side to side and the machine said the tire was good at the same time... Even with the 1 tire still terrible, my vibration is almost gone, and tolerable how it is. In and out in 30 minutes and I hope this solves my problem.
Take your trucks to Goodyear direct and you will be taken care of immediately and then you can almost rule out the tires if your still having problems.
My vibration was between 72-85 mph
Edited by 20Bowtie14
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
