I have heard of a number of front end problems where they simply forgot to put fluid in the front diffs from factory, at least from a relative's new 14' sierra. But such a vibration led to an unmistakable whining then clunking then grinding shortly after....followed by a new front diff.
GM bought back my 2014 Sierra due to the "unfixable" vibration. Prior to buying it back they had swapped out tires,wheels, rf balanced numerous times, and changed out the driveshaft. I gave them my 2014 back in December of 2014, when my 2015 Sierra came in. Was in the dealer yesterday for unrelated service issue on my 2015 Sierra and I got to talking with my service advisor who told me they "fixed" by 2014 Sierra. He told me GM sent them some sort of new vibration analysis tool and that it showed the vibrations coming from the front end. They ended up replacing the front axles and he said it is now smooth as butter. I had a vibration at 40-45 then anything over 68 MPH.
He also told me that they had 2 2014's in for service for the vibration issues last week. One was fixed by a driveshaft swap, the other needed 4 new tires.
My 2015 has been very smooth with no issues.
There has been a new escalade at my dealer for about 3 weeks with the front diff out it. It has 26,000 miles and the customer complained about a vibration/noise in the front at 78mph. Its taken about 3 weeks to get a new one ordered in for it. The service advisor also said that the person has been driving it around most of the time in auto 4wd
Edited by Silverado 6.2
I'm curious.. Did they refund ur $ or give u another truck? Also, did you have to get a lawyer? I'm in conversations with GM now about wanting out of my vibrator. Any suggestions?? Thanks!!
"High strength steel" is a very generic term. Could be any number of steel specs, and I don't know which one GM uses. And, I don't know what grade of steel "standard" frames and body parts have been made of, but I'm sure that has evolved over the years. That said, I would be surprised if the automotive industry uses A36 for frames. A36 is a structural steel spec for standard rolled beams and other standard structural shapes. Frames are typically formed by the automaker, likely from some plate or bar material. But I wouldn't presume they use A36. There might even be an SAE spec that they use.
I have seen A36 steel specified for hydroformed pickup truck frames before, I just do not remember whether it was for Ford or GM pickups. This was about two years ago.
I have a 14 sierra , had a vibration issue with 13 miles on it .. they replaced 2 "defective" tires on it . vibration still there . they said to drive it and let the truck "break in" truck is now in the shop for the same issue with 7,800 miles on it . . dealer says my "aftermarket exhaust" is causing the issue and it wont be warrantied because of the modifications . whats funny is the truck has only had the exhaust on it for maybe 2,500 miles . they have rotated and balanced the tires and checked everything else . what I find funny is my 2015 sierra loaner truck vibrates worse then my own truck...
dealer just called and requested that i return the loaner truck and pick mine up . GM has denied the warranty claim due to the modified exhaust and drop shackles being installed on the truck , shackles were done by a local shop that does lift kits and drop kits for this dealership and said it wouldnt cause any warranty issues . GM says they have not denied anything and its the dealership refusing to work on the truck ..Amazing what kind of different stories you can receive between 2 different people . i guess a BBB complaint and Lemon law action will push them a little ?
I stand corrected! Thanks.
Take it to another dealer. It is obvious that this dealership is using these excuses not to work on your truck because they have no idea how to fix the problem.
Edited by pm26
I will have to take it to another dealer as to im not "allowed" back at this dealer . will be removing lowering shackles and exhaust and taking it back and let them see that my "modifications" were not the issue . its not my fault that GM cant produce a good driving truck
I have relied once, and have been following this discussion for months now.
My 2014 vibrator is no longer an issue as I traded it on a lightly used 2015 Yota 4Runner Trail Premium.
Last Friday, the regional service msnager was in town and did the picoscope test and said my truck didn't have an issue. It had the low and high speed vib.
Picked it up friday afternoon and as soon as I got up to 40 the vibe was still there and at 72 and up.
Of course, since the GM rep declared the truck trouble free, GM would not reimburse the dealership for any claims associated with the vibration.
So, rather than keep the vibrator and waste my time dealing with GM and the lemon law process, I took it in the shorts to get out of it.
I will not be purchasing any GM products for the foreseeable future,
The truck had 11 different tires, 7 RF attempts, and the fatass regional rep can drop dead.
On another note, my dad has a friend that had a Chevy Silverado get a new rear end due to a whine from an improperly machined race, and now he has the vibe from the brand new rear end, which was supposedly hand certified by the rear end manufacturer. So much for the 2014 truck of the year.
I loved the interior, the tech package and the looks of my Sierra (2914 SLT Double Cab) but hated driving it.
But as I said, it's not my problem any more, and GM can deal with it with the next owner. Boy will they be pissed if they take it in for the vib and find out GM won't touch it!!
GM is screwing their dealerships with this POS, and I hope they get sued by someone with deep pockets.
wow, that sounds similar to my story. Dealer pretty said that they don't have a fix and that they would call me if a fix came up. This was my 3rd GM truck and my last. I traded mine yesterday for a f150. Not that they are perfect, but at least they have fixes for their issues.
Hate you had the luck you did. Mine was a vibrator too luckly tires fixed it. I traded from a toyota tundra best truck I have ever had only reason I went to gm was for fuel mileage the tundra sucked there.I believe I would have hit the gm rep in his fat mouth. Hope it all goes good for you.
It makes you wonder what else they forgot. :rolleyes:
There is nothing like great quality control to produce a good truck.
Edited by pm26
So I'm a still a big GM fan, and have been on the fence about buying a new truck because of some of the threads on this forum.
Today I went by my local GM dealership to look at some new trucks. Of the 4 that I test drove, 3 of them had a serious, serious vibration at highway speeds. I test drove different trucks since they didn't have one that had the combination of all of the options I wanted. They told me that the vibration was from the tires flat spotting from sitting too long. This wasn't the first time I've test driven a new vehicle so I rolled my eyes at that comment as that didn't seem to be an issue problem for the 4th truck. I figured that this thread was a very small snapshot of the over owner experience, but test driving 3 duds like that back to back has put a seriously sour taste in my mouth.
The biggest concern for me is that because of the options I want, fire red, crew cab, SLT, 6.2L, 8 speed, NHT, no moonroof, that I definitely have to factory order the truck I want. Waiting a few months just to potentially end with a truck that will be a warranty nightmare is not sitting well with me. Especially since we don't have lemon law protection up here in Canada.
C'mon GM, get your shit together. I feel like I'm in denial trying to defend an abusive relationship.
Edited by DanMan_S
Today I went by my local GM dealership to look at some new trucks. Of the 4 that I test drove, 3 of them had a serious, serious vibration on highway speeds. I test drove different trucks since they didn't have one that had the combination of all of the options I wanted. They told me that the vibration was from the tires flat spotting from sitting too long. This wasn't the first time I've test driven a new vehicle so I rolled my eyes at that comment as that didn't seem to be an issue problem for the 4th truck. I figured that this thread was a very small snapshot of the over owner experience, but test driving 3 duds like that back to back has put a seriously sour taste in my mouth.
Canada does have what is called CAMVAP which is like an arbitration process. Bought my 2014 Sierra 4x4 CC Z71 back in August and the dealer has had it for a combined 11 weeks . New rear end, tires and various other parts and RF balance and it still vibrates. Dealer has been very cooperative and is aware if not fixed next try CAMVAP will become involved.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
