I had the 15304 recall done. Seems to be some minor mods to the shift patterns. Holding gears a tad longer maybe. Just feels better shifting. While there I test drove a 2015 DBL V8, what is this with the steering wheel vibration / resonance? The rear did not vibrate but the steering wheel just lacked any dampening at all. It seems like it all just travels up the shaft - noise / tire resonance. The salesman was great and explained that it was just flat spots on the tires and that will go away. lol
Finally test drove a 2014 with the vibrations.
The salesman thought I was nuts for demanding a drive on the turnpike, but he headed back inside and grabbed a dealer license plate for the highway.
Once at 75 MPH, sure enough I said 'well, there it is... I'm sorry, but this is a non-sale."
To which he replied "Yeah, I feel it."
Damn, this thing was the right price and the right year/engine, and ran like a raped ape. But I ain't gonna buy no shaker unless they dropped the price unusually low. Like $16,500 out-the-door for a 2014 used truck.
They'll find some ghetto fool that will drive it around at 45 MPH, like it, and buy it I'm sure.
Sad but true
Picked up a 2015 Silverado LS Dbl Cab 4.3L 2wd two weeks ago. Rides good up to 75 where there is an obvious (not terrible) shake in the rear. Center console shakes, and I can feel it in the seat. I have access to a wheel balancer at work so I'll have the rears checked tomorrow. The one issue I'm concerned about is very slight, rapid vibration that lasts 1 to 2 seconds, which I can feel in the gas pedal & steering wheel. It only occurs at a constant speed between 40 to 50 mph, and happens about every 10 seconds. At the same time the vibration occurs, the tach jumps a 100 or so rpm & settles back down at the same instant the vibration ceases. Doesn't do it when I'm accelerating or de-accelerating. At first I thought it might be the AC clutch engaging, but it does it with the AC off also. Any of you folks run into something like this before?
Thanks
I will say this - and this may hurt some feelings here...
I have been shopping for trucks for two months now. I assure you guys that I've spent some serious time driving a bunch of them. My test drives often go for 15 to 24 miles. Even without the shakes in the odd model of Chevy (but another new 2015 Silverado 1500 that I drove all day, and a GMC Sierra that I test drove didn't have the shakes), all models of the 1500 GM platform gave the worst ride quality out of GM, Ford and Ram. Every time.
I was told when I drove a loaner Chevy 2015 Black-Out Silverado that this was just due to the suspension being new. I drove that thing all day (so approximately 100 miles on it that day) since this was the current loaner my boss had since his 2015 Silverado has the severe vibration issues (fifth new loaner vehicle I've seen him in). But I also drove a 54,000 mile 2014 Silverado. It was much later that night, like at 10:30 PM, that I realized that the ride quality of 2014/2015 GM 1500 trucks was just shit compared to their competition.
Still, if I get one for a low price and without the vibrations I will buy one. But it would have to be a lower price than Ram or Fords go for, for sure.
Your not hurting any feelings, at least not mine anyway. The K platform trucks do ride very stiff and are sensitive to anything in the road, especially if you rode one with the Rancho shocks. I also test drove every truck and to me if you are looking for a "car" ride then go with Ram.
I noticed something about my vibration today. I was cruising at 77. Flat stretch. The vibration seemed to be non-existent but gradually built up to a console shaker over a half mile stretch. No throttle or steering input.
It also seems to be much worse on sweeping highway turns or when cresting a hill at highway speed.
Edited by 14silverado4.3
That's the weird thing about it. Mine almost felt like it would subside some and then come back worse... It's definitely not consistent, but it never goes away completely.
BTW, mine has now had shocks, tires, and a new rear axle assembly. None of which fixed the problem and supposedly, the local field engineer was going to be working with the tech today on mine. We'll see what happens next. This is the 3rd visit, and I'm going on 9 days for this trip in.
This does not make me hopeful at all.
Me either lol. My vibes are terrible right at 79mph, where I set my cruise for the highway most of the time
Thanks
The RPM jumping up certainly sounds like a transmission issue, could be torque converter or valve body problem?
Well, having driven my new Sierra for about 1000 miles now I can say that I do not feel any vibrations thru the seat, console or gas pedal but I can certainly feel the road thru the steering wheel. I have owned a few chev and gmc trucks, the last being a 2008 3500 dually....all had a regular differential in the front not this new independent suspension. My thoughts are that between the Rancho shocks and the new suspension combined with the electric steering , 20" cheap Goodyears and sharp angles of the steering shaft all contribute to the rough feeling in the wheel. I live on a gravel road and I can feel every pebble I drive over....but it's a truck, does not ride as well as the last dually but I can live with it..
Most likely the '14 GM took back of my as it only had 1,300 miles on it
I'm on my 2nd visit & friday will make a month total
    • I just started having AC issues with my 2012 Sierra. The symptom is blowing warm air on all vents.  Here is what I have checked so far. Compressor clutch appears to be engaging and cycling  I checked all fuses and relay, no issues. The only thing I have notices is the short line that comes from the firewall is very cold / frosted. This line is approximately 12 inches long. The coldness stops when it hits the first line connector. As far as AC compressor - At first start the clutch engages, runs continually, Short AC line frosts up. After idling for several minutes the AC line thaws out some but is still cool and the compressor clutch starts cycling on and off every 5 seconds.  Any suggestions on what to look at next would be appreciated.
    • Unless you are using a bypass filer system with a Beta of 1000 at 2 micron the commercial filters we have access to, even the very best of them, are poor at the 5 to 10 micron range the typical UOA test can 'see'. Point is there are some truly awful filters being sold A 45 micron Beta 75 filter is what Dyson used to call a screen door on a submarine. That leaves wear metals disconnected from filtration unless particulates are larger than the test can 'see' and yet captured by the filter...which is its job. If that is true then you have a major issue screaming at you.    The graph isn't mine. It belongs to GM and their study on this area. I looked up those studies and provided those SAE tech paper addresses multiple times. Machinery Lubrication displayed it and confirmed it. So if you have doubts about the study you'll have to take it up with GM Engineering. Just like you would have to take up a difference in opinion about the meaning a word with Webster or the length of on inch with the National Institute of Standards and Technology.      Most manuals have two schedules. "Normal Service" and "Severe Service". On it's face it tells you that oil in severe service is more highly stressed and doesn't "Last as Long". The item to bore in on is LAST...what does that mean?    It's the same question one asks about how long to toast bread. What are the inputs? Bread type? Wattage of the toaster? Distance from the elements? What is your preferred level of done?    So lets paint this with a broader brush. Oil is made up of the base and the additive package. The first is altered by heat and oxygen and later is sacrificial with a finite life subject to inputs toward that end. Resistance and supply.    It is the reason an OEM's OCI's are determined by 1.) the specifications of the recommended lubricant and 2.) risk management toward the bottom line. Those lubricants are also subject to cost effectiveness for the OEM.    There is a tendency for most people to believe that the OEM recommended oil rest on the top shelf and that anything other is lesser than. Truth is there are more oils on higher shelves than those on the lower shelf below the OEM's. They make that choice on COST TO THE OEM. Testing is incidental to the margin.    GM makes MONEY, the car/truck is a TOOL to leverage MONEY. Insert whatever car brand you like. Until you forking over a million plus COST not quality is the driver. Thus it is by DESIGN the recommended OCI's and oils fall well short of 'best practice protections'. Proof isn't hard to find. GM Ecotec I-4 2400 breather system and cold start PCM tuning has killed more motors and resulted in more litigation for those that used the 'recommended' practice than GM could bear. What was their response? SHORTEN THE OCI. TWICE.    I don't know how long to leave oil in an I don't know how the oil will respond to MY circumstances and because I don't and can't blanket statement or anecdotal evidence my way out of it.....I TEST and FIND the right OCI for the oil I CHOOSE. There is no shortcut but there is blind allegiance. I don't blindly trust anything.    People hear the word 'detergent' and believe that in the context of oil it means the same thing as laundry soap... Only in the most rudimentary way. It's the first additive to give up on you and they are putting less and less with each new API standard. Solvency can be used but it cost. Some unique undisclosed chemistries can be used. Valvoline R & P in example. OEM's haven't an interest in anything they see as limiting market participation. Whatever.
    • For some unexplained reason my father wanted a salvage yard. As we were getting the family business off the ground one brother ran the salvage yard. We gathered there when rained out working on pipelines in the eighties to pull parts. Perfectly good running vehicles would come to us simply because they wouldn’t pass emissions inspection. We were able to swap parts and sell some of them. I got a clean old nova with a bad engine. I pulled a perfectly good small block out a Camaro. A father and son project with a rebuilt engine. The son couldn’t get the engine running right. The problem was the spark plugs weren’t gapped. The 90s vehicles probably widened the gap of shade tree do it yourself engine repair. My do it yourself hot rod repair stopped at the 70s. After that my trusted mechanic kept them in running shape.
    • I have an old dental chair in my shop. Something I got for free and apparently it has more than scrap value? People collect them although mine isn't restored or anything. It's visually interesting (1930's Ritter) which is why I like it. And it IS decently comfortable if you kick back.   When a good buddy of mine saw it he said, let me guess, Atlas. It's a conversation piece? As in, you ask the questions, they do the talking?   Where do you hide the jar of teeth?   I would never.
    • Are we talking about the same thing, though? The 7 versus 3 wear metals was from Lakespeed's 3.0-specific oil brand comparison test between AcDelco oil and Mobil ESP. The filter remains a constant so whatever excess particles the AcDelco oil is producing aren't being filtered out.   I'm assuming there's a parallel comparison to be made; IF the filter can filter down those particles, engine life increases, and your graph makes the case that a better filter (lower micron rating) can increase engine life. Introducing fewer particles AND filtering those particles with higher efficiency is the best of all worlds. Good oil, good filter.   Where we may disagree is the "baseline relative engine life". I'm more apt to believe the base engine life value is 200k+ on very average oil and filters, "bulk oil of unknown brand and white-label generic fleet-grade filter, Jiffy Lube"   Going from a 10 micron filter to a 5 micron filter should boost a base 200k to 275k in a vacuum as a single factor alone.   Here's the whatabout: How does regularly changing the oil and filter ahead of recommended schedule influence baseline engine life? Most people aren't going to science the heck out of this stuff or ask about Micron ratings, HTHS, or wear comparison tests at Jiffy Lube. Most of the Jiffy lube techs would say they need to call their tech support line to even try to get an answer.   --   Because we love anecdotes here, when I was fishing for 4.3 parts at a local yard this weekend, ALL of the 4.3 vehicles had well over 200k. I love looking at odometers of junked vehicles. How far did THIS go before landing at the crusher? The ones that still had engines weren't seized. None of them were vehicles I'd consider were Amsoil queens, in fact most of them had some kind of service cling-sticker in the corner of the windshield indicating it probably had very average maintenance services. Even the fresh parts rigs- I'm not sure taking an S/T series to 400k has much value considering the running value of those vehicles was probably somewhere around $1,000. 25+ years is a good run on time alone.   The intake manifold I salvaged had clean and bright pool areas. As expected, I found the fuel lines in the manifold rubbed through, just like mine. I'm guessing the lines on that donor truck started leaking, the truck started running rough, and its owner said that's enough I'm unwilling or can't take it out of service for several days, or spend $1000+ to repair it at a shop, it's simply time for a newer more reliable vehicle (or, more than likely, this is the 2nd, 3rd time this has happened in the truck's lifetime). While I don't count on my Blazer for reliability, the thought of giving it away for parts at certain points during my adventure, and being mentally free from its needs has has crossed my mind. I'd be losing $1500 or so, but I can only make more money; not time.
