Someone needs to remove the tires from the wheels, put the wheel on a hub-centred mandrel, and measure the radial and lateral runout with a proper dial indicator, not the measurements that May or may not be done on the Hunter RF machine. I don't trust that stupid little arm that the Hunter machine uses. And when we see that every tire vibrates on these trucks, including totally different make/model of tire, I can't believe every tire manufactured is defective. It's too preposterous to believe. Gotta be the wheels. Or the hubs. Or the hub-centric fit is too loose.
Has anyone put aftermarket wheels on? Hub-centric or lug-centric? Result?
my 75mpg vibration didnt start until I added aftermarket wheels. my factor 20's with factory rubber no vibration. aftermarket 20's with factory rubber vibrates
Sounds like a case of bad wheel balance.
I finally had enough of my vibration and 2 different dealers not wanting to fix it or even attempted to fix it. Always got the whole "it drives like its intended too" so I traded it in on a new truck.. Sad day it was because I really like the truck a lot!
What did you get?
I really hate to say this, but as an update as of tonight, my truck is fixed. It just sat at the dealership for a week, and they finally called me and told me to come pick out any set of wheels/tires off any other truck on the lot and they would swap them for me. I hate saying this because I know it's not the fix for most guys here, but my truck rides completely smooth, like you're on glass up to about 95mph, even with cruise set. I stuck with 22" wheels, but ended up picking a set of the black ones that look like this:
They look good, and I guess they work a lot better than the chrome ones I had.
I also had these on my 2014 rally edition (we had the dueler ATs - maybe that's the difference) and GM bought that truck back. The truck was smooth until first tire rotation and that truck turned into a nightmare. I second rotating the tires just for the heck of it. I'm glad to hear you have no vibrations for now though - I wish I could say I've felt that :/
That's pretty shitty. My dealer offered me a month's payment for all the trouble I'd been through to date, and they felt it was fixed. Didn't accept anything yet though, since mine still vibrates after 4 attempts. What also sucks is that if you do get a new truck, the maintenance is cut in half and the warranty is now only 60k instead of 100k.
Yeah - we did not accept anything and told them we don't need help paying our truck otherwise we would have never bought it. We want it fixed or bought back. I'm not taking a third truck from them. This is it.
My other wheels had the ATs too...
I got a 2015 Ram Laramie. So far I love it! Specially that it has no vibration..
Lucky you! Im close to a buy back with GM, then I will be looking into the F150 or Ram. Would love a Tundra but they are a bit pricey!
A few days ago when I got upto about 76mph the vib started and got worst at about 82 on a new smooth paved road about 70 miles from where I live. Was going today to have the tires balanced and decided to do some testing before I went. Got on a smooth got upto 70 and on upto 90 and no vibs. I tried it many times could not get it to vibrate. The outside temp today is 60 was 78 when it had the vib. Who knows I still wonder why the crew cabs don't have a swing bearing on the drive shaft I know ford and toyota have one.
Michelin LTX M/S 2 275/55/20
Edited by southern_sierra
Congrats ! I think your going to love it as I'm loving mine I also traded my 14 Viberado in for 15 Ram 4x4 Hemi .
Absolutely love this truck and I keep loving it more everyday unlike with my GM it got to the point I Hated driving it and was frustrated every time I drove it . It's a shame because it was a beautiful truck but that vibration killed it .
This Ram is like riding on glass and this Hemi is impressive on power and mpg . I'm actually getting just under 20mpg in town but I did put a Magnalow exhaust on it .
Anyway congrats again and don't worry your going to love it !
It's like coming out of a abusive relationship and your guard is high so just relax and enjoy it .
I remember when I first got my Ram I was on vibration alert after being tormented for a year in my Silverado .
This Ram is like a breath of fresh air and look forward to driving it everyday !
Edited by TheFactor
How did you make out on the trade in ????
LoL well it's like I told my X you can't put a price on happiness
Trading in my X and my Viberado was probably 2 of the best decisions I ever made .
I actually got a great deal on my Ram didn't even feel the hit on the trade .
I feel for you guys that are still in the process of trying to get rid of there GM truck because most other dealers/manufactures know about the vibrating issue that 2014 and up GM trucks have and there going to make you pay dearly the longer you wait because are going to be aware. It's pretty sad GM won't recognize the issue but other manufactures /dealers are sure aware of it . Very very sad for all the loyal GM truck owners !!!!
Edited by TheFactor
It looks like GM is not working hard to find the problem,all we have to do is sit and wait for a solution. I think im goin to trade my silverado with a f150.
The service manager keeps telling me 'they are waiting on a good rear end'. I am not sure exactly what that means.
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
