So I get a text from the dealer late yesterday saying the truck is repaired and is smooth on the highway. I said "So the Michelins did the trick"? He said YES. I said great, I'll see you tomorrow afternoon when I get off work.
But going back in time and knowing the amount of tires they put on the truck including the original set, the set of tires and OEM rims I bought, a set from a brand new truck on the dealers lot, and a brand new set of Bridgestone's that were perfectly balanced to 7 LBS each per the SM it makes me wonder if in fact it was the recently installed and balanced driveshaft that was the fix and the tires are a cover up? As much as I appreciate the Michelins, (Great tires) when he told me the driveshaft was "slightly out of balance" and that they swapped tires from another new truck and it repaired it, I stared to wonder because the timing is what is questionable.
Wondering now when I pick it up what the paperwork will actually show completed after a month and 1/2 in the shop.
One things for sure, Chevy needs to change their motto from "LIKE A ROCK" to "MORE SENSITIVE THAN A WOMAN".
“Hallelujah! Holy sh*t! Where's the Tylenol?” (Chevy Chase)
GMCJOE17: please report back about your personal "feelings" about the vibrations, I hear too many times GM says they are fixed until the owner test drives and feels anything different.
On 11/1/2018 at 12:41 PM, GMCJOE17 said:
Got a call from the Service manager at the dealer. He said they got the driveshaft back and he said the driveshaft company said it was slightly out of balance. They put the driveshaft back on and it still vibrates. He said he took another set of tires off another truck and put them on mine (AGAIN) and the vibration went away.
He told me he is going to order a brand new set of Michelin tires for it, the best tires for this truck under warranty and he said of that does not correct it then its the rims. I said you would figure the rims would have shown any imbalance on the balancer. He said the machine will not show where the tires bolt to the truck. I said I find it strange that the original rims did it, the set I bought did it, the set you already swapped from a NEW truck did it, and now you changed them with another truck and it went away?
Sitting here SMH and fed up with the entire thing.
Get Michelin Defenders....
So I got to the dealer after work today and the SM told me to go ahead and take it on the highway and come back to make sure I was satisfied. Jumped in and all seems good @ 70 only truck normal bounce.. @ 75 same and @ 80 mph all good. Got back to the dealer and did a once around and did notice a door ding right in the middle of my drivers door. He got me some touch up so I will have to do a little sanding in the spot first. Other than that, one of my nice tire caps was missing but he threw a new one on and even had a porter fill the tank up for me which was nice. (but they did rip through what I had in it)
I am happy it rides like a normal truck but am a tad worried that this issue could return as the tires wear or the truck gets more miles on it. Time will tell on both. I am thinking of throwing some Bilstein's on the back to control the 8 ft bed a little better on the highway. The dealer did give me some sand bags (same bags GM made them buy in troubleshooting the truck). He didn't have the paperwork ready but he said he will email it to me when its done. I imagine 5+ weeks of this thing clocked up some hefty GM billable hours. He did tell me that GM wouldn't approve the Michelin's so the dealer ate them. (Which means they ripped them off another truck on the lot and threw the Bridgestone's on it)
My poor rims have been through road force balance hell with the multiple sets of tires on and off of them in the last few weeks.
More to come when I get the paperwork, glad to have the truck back after this long too.
Joe
On 11/3/2018 at 1:14 PM, GMCJOE17 said:
That's what they put on!
My 2015  2500HD. 4x4 with 8 ft. bed came with Michilen tires and has been smooth as glass since
new.
47 minutes ago, GMCJOE17 said:
I drove it 150 miles last night and it was smooth the entire time!
So what do you think it was? Driveshaft or tires?
Also, what specifically did they do to your driveshaft? Balance? New from factory?
I know, I am about to schedule another appointment and don't know if I should let them decide on the plan of action or try and persuade them down a specific route first versus another. Now the more I have read all the issues with shake/vibration it might be a multiple factor which some people may have some more factors than others. Should the plan of attack start with tires or other parts (driveshaft/axle) route.
Bill,
I think it was a mix of the Driveshaft balancing (it was reported as out of balance but I never got to see the data on how much) and the better class of tires. Its like night and day on the highway now.. smooth as silk!
Joe
10 minutes ago, GMCJOE17 said:
Bill,
Joe
That's great! All the way up past 80mph? Also, how much does a dealership charge for a driveshaft rebalance? Or was it covered under warranty?
Edited by Bill Reinhardt
Dearmosd,
The dealers are at the mercy of GM for all warranty work. It has to be approved for them to get paid for warranty labor and parts. Luckily I had a really good service manager who made the world of difference in my case and I also shared the information with him on what I read on line on this site and others. If I were you I would start with the service manager, if you feel you are getting a run around then turn up some heat by placing a complaint with the BBB (https://www.bbb.org/). They will then contact GM who will assign your truck a case number and contact the dealer directly. When doing so, you will need to upfront state your case on what you are looking for whether it be a lemon law case or reimbursement for any out of pocket costs you spent on getting the problem corrected. The dealer will then have 14 days to correct the problem or report to GM that they can not repair it and then the lemon law will come into play. In my case I bought my truck used so I didn't qualify for the lemon law but I pushed for arbitration and they settled before it went.
Good luck and I'll follow your posts for sure!
Joe
All warranty Bill, and yes I took it to 90 and it was perfect. The crappy thing about GM is they covered the Bridgestones under warranty but refused the Michelin's. The dealer told me they ate the tires on this one (which they got the set of Bridgestones so they came out ok).
    • Looking up on the web you can the information that would seem obvious. You asked engine components to do more. You get more wear. The answer is they can last just as long but required more maintenance. Apparently having to change lifters, cam and associated components are maintenance or repairs. In some research the normal life span of valve train components are 80-100 miles with 3-5K miles oil change. So the next logical conclusion would be cost per mile. I use that analogy with my wife all the time with vehicles. My Odyssey is approaching 170K. The cost per mile will go up at 200K with maintenance. Looking at a low cost car. A K-4 with a 10-10 warranty. Selling my Ridgeline that’s about to hit the same maintenance milestone. My argument becomes not only I get worry free driving. But at no cost increases. Because I take the money from my Ridgeline and maintenance savings and other potential savings. I’m driving for free. So tying it with a bow. It makes you wonder. Is this a grand conspiracy by the auto makers? Raise the potential maintenance high enough. Buyers by extended warranty to 100K miles. Do the minimum maintenance required. Trade in at the warranty end. How long should they last? That question is what keeps people up at night. The answer is much more complicated than it used to be.
    • Could you cite your source on this?  I cannot find any reference to the US secretly taking the oil.  I find references that the US helped oil tankers move through the Strait of Hormuz, but nothing about what you're stating.
    • Same thought, also the everything doesn't have the details real photos do (talking about the noise in the photo)
    • Since the media YOU and your buddies are programmed to watch failed to mention this, I'll fill you in.   Trump admitted today that we've grabbed 150 MILLION barrels of oil from the Iranian tankers locked in the Strait by our Navy. We turned off their transponders, took them out to sea in the dark of night since they have zero radar capabilities anymore, offloaded every drop onto another vessel, and put them back by morning so no one was the wiser. That oil has been en-route THROUGHOUT the entire conflict.   Main reason he admitted this is to let even guys on our own side who joined leftists in complaining about the prices that he hears us all, and has taken steps to make sure this didn't spiral into a BAD situation ... just like the mainstream media has been PRAYING would happen, just so they could gloat. Amazes me how these people are rooting for the destruction of THEIR OWN HOME, just to make a President they don't agree with or like look bad! That's next level TDS!   I know your not capable of giving our President the benefit of the doubt, again due to your deep programming, but THIS is why oil never hit $150 a barrel as predicted by your programmers, AND the reason oil continues falling. Like I said before, Trump's got a plan, and this is proof of it. By the end of his term, we're going to be in GREAT shape for a change!   Since I just spent $3,000 this week on #2 heating oil and gasoline, the war most certainly is ending! 🤣   https://mxmnews.com/article/ba359ac9-2711-4851-92de-187f2400f2dd?breaking-trump-cancels-iran-strikes-deal-now-approved-by-all-parties
    • No leaks. Replaced the condenser 3 years ago. Problem was found to be caused by the A/C blend door actuator. Just replaced it and it's blowing out the cold air it used to when I bought it.
