Dropped my 2015 high country with 28500 miles off at the dealership yesterday. They road force balanced the tires and said that helped, but still vibrates. They kept it overnight so they can put it on a machine and see if they can pinpoint the issue.
So I'm needing a little input here.. I previously had a 2014 Chevy Silverado that hat a little bit of the shake that this thread refers to and I traded it off on a Ram 1500. Now that the new 2017 are out I'm thinking about going back to the Silverado. Nothing wrong with the Ram, just liking some of the new stuff on the Silverado. Is it still hit or miss about getting a new Silverado that shakes? Should I just keep the Ram?
Keep your Ram. Take another look when the 2019 drops.
Keep your Ram untill 2018 model, there is the new 10 speed tranny, as well as a new frame, that will possibly help solve these vibrations!
I too am holding off untill they solve this issue....not gonna drive a vibrator...no way!
Just picked my truck up from the dealership. Road force balance and balanced my drive shaft. Did a pico test and everything came under .02g. It's better, but I feel it could be smoother. Service techs words were "it's as good as it's going to get".
Skip the idea for now. I drove 7 (Seven!) different 2017 models between service loaners and new potential replacements. Each one shook in it's own special way (albeit to a lesser degree than my own). GM has a law suit coming its way from my attorney. Really a let down as I am not interested in the other Makes.
The Torque Converter was replaced due to some shudder in V4 switching to V6 under light throttle. I was excited hoping that some of the other random vibes were shudder also, they were not.
Still vibrating.
I took the truck to a Sierra dealership and just sat down with a service analyst....
They have 4 trucks that they are currently working to fix. They are swapping parts out one by one according to GM's direction. Run the PICO, GM analyzes and provides repair options. Wheels, tires, axles, axle housings, transmission, torque converters, driveshafts, front drive shafts ..... all replaced on a customer's vehicle with no solution to the vibrations.
Confirmed some 2014, 2015, 2016, 2017 have this problem.
Confirmed GM has no idea what the problem or a solution is
Still vibrating.
I can confirm 15 and 17 :)
If I had the budget, time, and the tools Gm engineers have, these vibration issues would be sorted by now!
However if they exist in the engine (v4-v8 mode) switch, transmission (shudder) from torque converter being locked up early for mileage claims, and possible a wierd transfer driveline imbalance.
They will not redesign internal hard parts at or nearing the end of model year run.
A successful company always, continuesly keeps improving their products. GM however is selling these trucks with full knowledge of these mechanical, and vibration problems.
I personally believe their is a stacking problem of critical rotating parts not machined correctly, add that to a high tensile frame, which allows frame beaming to occur and transfers all this energy to the cabin and passengers.
Thxs
Well if GM don't know what is causing it now then who is to say next generation may be more of the same .
The Next generation will have revised Cab Mounts! They are fully aware of the problem.....mitigating the small disturbances that are transcended through the Frame and cab structure is all they can do....It's not a safety issue and trucks do ride rougher than cars.
Everybody laughs but I did a cheap ass non-scientific experiment and I am fairly certain it's the problem. Isolating the engine like the older "W" bodies with cradles would have cost more but significantly reduced the new powertrain VIBES! It ruins the on road steering feel but the isolation was needed for these powertrains and the Electric steering ruined the feel anyways.......
Last I heard from a birdie they were looking at both for new Generation mainly the "Cab Mounts" It will ultimately be a money thing in the end........
Edited by mookdoc6
My guess is GM engineers know what the cause is and what the fix is. Guess also the fix is expensive. Maybe too expensive for GM to step up and make it right. Fuk you GM for selling me a $45K truck that you knew had issues.
Pretty Much! Ford is selling the Ecoboost with same intentions/ thought process! Pick your poison?
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
