Removed the front air dam, not interested in plowing snow with my truck this winter. I'd take a picture but.. Well, we all know what an air dam looks like.
  • Haha 1
The full oem air dam is a bit much. I never cared for it but needed it because of the front plate. However, I did learn that it is actually a 2 piece. Quite a while back, I removed the bottom piece and think it looks tremendously better and provides more clearance for the reason you mentioned...
You do know that has a function right?
  • Haha 2
I had heard that after removing the dam that snow and salt was all over the guy's engine and he couldn't keep it clean.
  • Haha 2
Dam it!!!
  • Haha 1
26 minutes ago, 6.2Midnight said:
Helps direct airflow to the radiator, helps with aero as well.
I removed the lower part when I lifted my truck.
Never noticed any difference.
  • Like 4
Wow, well that backfired. I guess pictures are needed.
I only removed the lower air dam. In the summer I put it back on. You can get severe overstear with high speed cornering, and overall driveability is affected.
Yes, I am aware of what it does. It ensures a low pressure area under the vehicle so that hot air is drawn down and out. In turn this pulls air through the radiator.
Cooling isn't as efficient with the lower air dam removed but it still functions. If you have larger tires with a level/lift your likely not to notice or need be concerned about the handling differences.
*edit*
I forgot to add that the reason for the difference in handling is because the front air dam creates down force.
I actually get slightly better fuel economy with it off. Truck feels lighter.
But I could also blow the tires off if I floored going when going 100 kmph (on cooler days).
Edited by M1ck3y
No pictures, but
* Got Denali cluster back from WAMS and installed
* Ebay blue CAI
* Steering wheel controls functioning, Stinger Heigh10+PAC kit configuration finalised
And confirmed a bunch of what I speculated as far as exactly how the steering wheel controls work.
The cluster uses a dedicated LIN network (between cluster and steering wheel controls only). Audio controls are then passed from the cluster to the media system via the MOST network. Two separate incompatible networks, with the cluster acting as a man-in-the-middle translator. A WT mono colour screen cluster does not have this LIN network, and the harness to the cluster does not have this wire populated.
The PAC came with a T harness to connect to the clockspring, to connect to the LIN wire of the steering wheel controls. However, just tapping into the steering wheel controls alone was not enough. The reason is because the cluster sends a message to the steering wheel controls via LIN to wake them up. Most devices that use LIN in the GM world, need to be told to wake up. It appears the GM51 PAC module fails to send this wake up message. I had no functionality of controls with the Heigh10. Since I still had a WT cluster, it was not until I installed my Denali cluster and connected the steering controls to the LIN on pin 20 of the new cluster, that I got them working with my Heigh10 through the GM51 module.
Looking at another thread here on GM-Trucks, it seems other brands of interface kits have the same issue.
3 mods to check off, many more to go :)
I got my bow tie installed finally with the help of my little guy. 🤣 I bought it used, and it didn’t have the harness. I made my own with some waterproof connectors in case I have to remove it.
  • Like 6
Nice 66 degrees today and sunny!
Gave the truck a bath and a shine! :)
  • Like 5
Do you want to drive out here and do mine next?
    • I was the GM of a Lincoln Mercury dealership back in the 80's. The service lot was always full with "broken" ones. Plenty of transmissions, power windows and a/c repairs. The only one I'd consider owning would be the Marauder at this point and it certainly wouldn't be a daily driver.  My 2025 GMC Sierra 1500 Denali Ultimate is my "Lincoln Town Car" in my retirement. I want all the "stuff". Big infotainment screens, one touch power windows, Supercruise (I won't buy another vehicle without it), hands free pretty much everything. I'm going to swap my current truck for a 2027 Yukon Denali Ultimate so I can have the air suspension and surround vision recording along with all the other "stuff".
    • Yep mine is on backorder also.
    • The Denali Ultimate's grille is tinted, but the "regular' Denali has a bright chrome grille like the current models.
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
