Rattle/Rumble/Rolling-Ball Sound?
Gaucho Wino
Hi All, been reading all of the great posts on this forum. I have a 1500 Sierra SLT All Terain with 2,000 miles...unfortunately my first post is to ask about a sound I've heard on two different occassions from my truck. Strangely outside of these two recent occurances, it hasn't happened again so I'm not sure if this is a problem that is lurking to resurface later or something else.
The first time it happened was around noon on Monday of this past week. I had driven the truck 10 minutes to work with no issues. I left it parked outside until lunchtime, and then while driving it from the parking lot, I noticed what sounded like a softball or something rolling/bouncing around in the back of the truck when I accelerated. It actually reminded me of a rattle my dad's old 72 chevy had that was caused by a gas cap he cut off and part of it fell into the tank causing a rattle noise when he would make turns and the cap would move around the tank. Incidently, my gas tank level was very low that day, no idea if there is any correlation there, but wanted to offer as much info as possible.
The second time it happened was now after the tank was very full (again no idea of the correlation), but still would get this strange rattle coming from the back of the truck when I would accelerate. Unfortunately or fortunately, outside of those two instances, it hasn't happened again this week. I don't want to take the truck in to be looked at until it was something that I could reliably point out, but obviously don't want this problem hanging over my head for the next two years either.
Any thoughts on what it might be? I would guess somethign with the drivetrain, but it's strange that it didn't happen the rest of the week. I'm out in CA so temperatures have been warm, no extreme cold issues that I know others have faced with their trucks.
Thanks for any ideas/suggestions.
Mine does this and Ive been wondering the same. I heard it just once or twice as you say, then it has been steadily getting worse.... When I am going 15-25 or so , if I let it coast for a minute , it will make the noise, and if I ease on the gas, such as with a rolling start at the 15/25 speed, it does it predominantly.
Sounds like a noise that you would get from a couple of marbles in a plastic bottle, and said plastic bottle is attached to the driveshaft lol
are you guys in v4 mode when its making the noise?
Yes I have been watching for that to see, could it be the flutter valve piece in the exhaust?
Hmm...not sure, but I don't think so because it seemed to happen as I was accelerating from stop or at low speed and speeding up. I can't say for certain so I'll try and check the next time it happens.
NORMAL! The sounds are consistent with built-in quality.
Can you explain what you mean? I find it strange that the sound doesn't happen all the time if it is a normal sound, no? I don't know what's causing it, but it did not sound "normal" to me.
Mine did something similar a couple of times. Hasn't done it since I removed and replaced all exhaust from the cat back.
Yes I have been watching for that to see, could it be the flutter valve piece in the exhaust? Sent from my iPhone using Tapatalk
Yes, I would almost bet it's the flapper valve in the exhaust system. It sounds just like my performance exhaust guy was telling me about. He said he had removed several from late model Camaros for that noise and elimated it. If you don't want to eliminate the valve on a guess, just safety wire it in the open position for a few weeks and see it that stops it. If so, then go to your nearest exhaust shop and have it cut out. That would be my suggestion. I had my entire factory exhaust system, from the cats back cut off and trashed less than 24 hours after taking delivery. In my opinion, the smartest thing I have done to my truck, except maybe the tune and the Airaid CAI system. Good luck, hope that's what it turns out to be, because that's a simple fix.
Hey Gaucho Wino,
Bummer to hear that you are hearing this noise with your new truck! When you are ready to take it into the dealership, let us know and we would be happy to assist you along the way. We can be reached via PM here on the site.
I look forward to hearing back,
Jonathan A.
GM Customer Care
I have yet to hear this flapper valve on my truck. But most of my driving is with the windows up (its winter...)
I'll have to keep my ears peeled when it starts warming up to hear this thing.
  • 2 months later...
I have a 2014 GMC Sierra with the V6 and 3K miles now. It rattled quite often with the same noise everyone is describing (marbles in a can) and coming from the rear exhaust.... almost the same sound a shattered catalytic converter makes (but mine was good of course). Turns out it is the GMC Adaptive Valve that is welded at the end of the muffler. My truck would rattle off and on during acceleration and usually at low speeds. I bought a stainless steel hose clamp and rotated the valve 90 degree to full open position and slipped the hose clamp onto the adaptive valve "box" arm (there is an internal spring in this box to default the valve to closed), keeping it in the open position. My exhaust is slightly louder and deeper now (Ok by me) and the noise is gone completely under all acceleration conditions. What a dumb design by GMC. On a side bar, the dealer said they have not heard of any complaints yet, as it is a new vehicle with a new valve....nor are they familiar yet with this valve. My guess is there will be a lot of complaints over time and an improved design that doesn’t flutter / rattle.
I have a 2014 GMC Sierra with the V6. It rattled quite often with the same noise (marbles in a can) coming from the rear exhaust.... almost the same sound a shattered catalytic converter makes (but mine was good of course). Turns out it is the GMC Adaptive Valve that is welded at the end of the muffler. My truck would rattle off and on during acceleration and usually at low speeds. I bought a stainless steel hose clamp and rotated the valve 90 degree to full open positoin and slipped the hose clamp onto the adaptive valve "box" arm, keeping it in the open position. My exhaust is slightly louder and deeper now (Ok by me) and the noise is gone completely under all accelleration condtions. What a dumb design by GMC. On a side bar, the dealer said they have not heard of any complaints yet, as it is a new vehicle with a new valve....nor are they familiar yet with this valve. My guess is there will be a lot of complaints over time and an improved design that doesn’t flutter / rattle.
  • 3 years later...
I have a 2014 Silverado 4wd rally, since I purchased this truck, there has been a rattling, pinging, from under my truck, the dealership replaced the muffler like 2 years ago and the noise is still present. Seems like when I am going up hill, any hill at 30-35. Service center has me pay for ride alongs with a def technician who looks under the hood and changes the report and they throw there hands up and say we cant do anything if we can't duplicate my concerns. This has gone on since I've owned this truck, as a busy dad and contractor its difficult to get there. But I hear the same noise from under my truck for sure.
Put your truck in manual mode at the second to highest gear, (L5 on a 6 speed) and drive around to see if you can hear this sound. If not then it is the flapper valve. You can turn off the afm many different ways covered many different times on this forum.
    • It's the Middle East conflict that raised prices, not AI. But nice distraction.
    • Lauren Fix Is AI quietly deciding what you pay at the gas pump? How the algorithm picks drivers' pockets.   Every time tensions flare somewhere in the world, gasoline prices seem to jump overnight. Drivers expect it. The news blames geopolitics, oil traders blame uncertainty, and politicians blame each other. But here's the question almost nobody is asking: If computers can raise prices within hours, why do they suddenly become so patient when it's time to lower them? Americans have lived with this frustration for decades. The price of crude oil climbs, and gas stations respond almost immediately. Crude oil falls sharply, and suddenly we're told to be patient. Refiners need time. Distributors need time. Retailers need time. Somehow, that urgency only seems to work in one direction. Regulators have already gone after algorithmic pricing in apartment rentals, and they're looking at hotel rooms, airline tickets, and online retail. Now a new California lawsuit and a federal push to investigate gasoline pricing suggest there may be another piece of the story that deserves far more attention. It isn't simply about oil markets anymore. It's about artificial intelligence, algorithms, and whether software designed to maximize profits is quietly changing how fuel prices are set across America.   If that sounds like something out of a science fiction movie, think again. Kalibrating the market? Kalibrate is a real pricing platform. The company markets its software as an advanced pricing solution that analyzes competitor prices, wholesale costs, local demand, traffic patterns, and countless other variables before recommending the "optimal" price at the pump. By the company's own marketing, it serves many of America's largest fuel retailers and convenience store chains. Retailers use it because it promises to increase profit margins while staying competitive. There is nothing inherently illegal about any of this. Every major industry now runs on data analytics. The concern begins when pricing software stops simply reacting to the market and starts shaping it. On June 22, three California drivers filed a federal class-action lawsuit in Sacramento — and they didn't just sue the software company. They sued the gas stations. Kalibrate is the lead defendant, but so are Marathon, BP, Circle K, 7-Eleven, Speedway, Walmart, Sam's Club, and Albertsons. According to the complaint, Marathon alone runs more than 1,000 ARCO stations in California and has been letting Kalibrate set prices at them since 2020. Circle K, plaintiffs claim, has more than 400 stations on the software. Albertsons, they allege, has been using it since at least 2009. The complaint alleges that Kalibrate allowed competing retailers to share competitively sensitive information and receive pricing recommendations that discouraged aggressive competition. It describes a "restoration" feature that plaintiffs say lets nearly all the stations in a market raise prices at the same time. It also quotes Kalibrate's marketing, which according to the complaint tells operators that even in the face of "falling oil prices ... it's critical to avoid a race to the bottom," and warns that cutting your price to win customers "could be making a change that triggers a downward spiral." The plaintiffs call the platform the "central nervous system for a conspiracy to extinguish retail price competition among gas stations." Price pumping What does that cost you? Research cited in the complaint found that stations switching to this kind of software raise prices by about 6 cents a gallon on average — and by as much as 30 cents where most of the stations in an area are running it. Plaintiffs point to a real-world example too: They allege that when one California Albertsons turned Kalibrate on, its pump price climbed 3 to 4 cents within days. That sounds small. It isn't. By the complaint's math, a single penny on the statewide average drains $134 million a year from California drivers' wallets. Kalibrate says it disagrees with the allegations, calls its technology lawful, and intends to defend itself. The retail chains have not yet answered the complaint. No court has ruled on any of it. But what happens when thousands of competing businesses begin relying on the same algorithm to determine prices? Price fixing has been illegal in California for more than a century, and the plaintiffs are suing under that old law. What's new is a statute that took effect on January 1 — AB 325, the Preventing Algorithmic Collusion Act — which says plainly that you cannot escape a price-fixing charge by routing the conspiracy through software. Using pricing software is still perfectly legal, but using it to coordinate with your competitors is not. AB 325 makes it unlawful to use or distribute a "common pricing algorithm" — software that uses competitor data to recommend, align, or stabilize prices — as part of an agreement to restrain trade. Whatever you think of Sacramento, it closed that loophole first, and this case is the first real test of it. The A-word Washington is applying pressure of its own — though it is worth being precise about what kind. On July 3, the Department of Justice and the Federal Trade Commission sent every state attorney general a letter urging them to investigate whether antitrust violations or price gouging are keeping gas prices artificially high. "Recent volatility in crude oil prices does not suspend either the antitrust laws or state consumer protection laws," they wrote, "and it does not authorize companies to manipulate retail prices or collude with their competitors." The letter followed President Trump's complaint, posted to Truth Social on June 23, that falling crude prices weren't reaching drivers. But read that letter closely and you'll notice something. It never mentions algorithms. Not once. The federal government is going after gas prices with the same tools it has always used, while the argument about the software is being made by three drivers and their lawyers in a Sacramento courtroom. Nobody in Washington has said the word yet. And whether any of these investigations turns up illegal conduct remains to be seen. Anyone who has driven for more than a few years knows the pattern. Prices spike within days of a geopolitical event, then drift down at a painfully slow pace. Economists even have a name for it: the "rockets and feathers" effect, and they have studied it for decades. Researchers point to several reasons, including inventory replacement costs, consumer behavior, and local competition. None of those explanations necessarily involve illegal activity.   Dirty work   But artificial intelligence introduces an entirely new variable. Unlike traditional pricing models, today's software can monitor competitors continuously, process enormous amounts of market data instantly, and recommend price changes faster than any human pricing manager ever could. If dozens or even hundreds of competing retailers rely on similar recommendations generated from comparable market data, the practical result may be less price competition — without anyone ever picking up the phone to coordinate prices. That possibility isn't unique to gasoline. Regulators have already gone after algorithmic pricing in apartment rentals, and they're looking at hotel rooms, airline tickets, and online retail. The Justice Department sued RealPage over the software landlords used to set rents and settled the case last November. The concern in every case is the same: that algorithms may accomplish indirectly what competitors have long been prohibited from doing directly. It's worth being precise about what that settlement did and didn't say. RealPage paid no penalty, and the government made no finding that it broke the law. What the DOJ objected to was the use of nonpublic information from competing landlords — not the software itself. Using an algorithm to price your product isn't illegal. Feeding it your competitors' private numbers is where the trouble starts. That distinction is going to decide the gas station case too. Technology moves faster than regulation. Thin margins This debate also exposes another misconception. When Americans get angry about gas prices, they aim that anger at the oil companies. In reality, what you pay at the pump includes crude oil costs, refining expenses, transportation, taxes, distribution, and retail pricing. Gas stations generally operate on thin per-gallon margins — the National Association of Convenience Stores puts the net at roughly a dime a gallon once credit card fees and operating costs come out — while state taxes and regulatory costs can dramatically affect what you pay locally, particularly in a state like California. If gasoline prices are rising because of global supply disruptions, consumers may not like it, but they can understand it. Markets move. Wars affect energy. Hurricanes interrupt refining. But if pricing software is reducing competition by encouraging retailers to move together instead of competing aggressively for customers, consumers deserve answers. Artificial intelligence is quietly becoming the invisible middleman in countless financial decisions Americans make every day — insurance rates, airline tickets, hotel rooms, online prices, and now what you pay every time you pull up to the pump. Most consumers never know an algorithm was involved; they simply assume that's what the market decided. Algorithms don't care whether you're commuting to work, driving your kids to school, or trying to keep your small business afloat. They don't understand household budgets or family vacations. They optimize. That's what they were built to do. The question was never whether artificial intelligence can set prices more efficiently. It's whether we've quietly allowed machines to redefine what competition means. Because if software can determine the price of something as essential as gasoline today, what will it be deciding tomorrow?   https://www.theblaze.com/lifestyle/is-ai-quietly-deciding-what-you-pay-at-the-gas-pump
    • All valid.   But.  How many people really do this?  Its few and far between.  Most just drop it into D and go.
    • Did you do this after the warranty expired? Or still under warranty? I am guessing the warranty would be void.  I am trying to find a happy middle ground on this by perhaps keeping the cat but removing everything else.
    • Thanks for the responses. Having an issue and not getting support is a real thing and can take the shine of any good product.    I had an issue with my iDash recently and Banks went above and beyond to fix it and that makes me want to deal with them on some other future upgrades so it does benefit any company to support the crap out of their products.   I do like the looks or the VSE parts but can be hesitant if there is a weak back end to support it. I have their CCV and catch can sitting in the cart but haven't pulled the trigger yet. Just want to get feedback and this helps.    @AbzDad have you noticed any change in the amount of build up on the manifold sensors with the reroute?
