Hi all,
1500 high country 20 inch chrome rims peeling around valve stem. 3 out of 4 are doing that. 20,000 kms on truck. GM said they would cover only 2 of them... Saw on forum that a guy w a GMC truck got all 4 replaced... Your thoughts?
I had all 4 of my 20" silverado wheels replaced.  Machined aluminum finish.
Hi Sean403,
Just getting clarification.  The rims on the Silverado are Machined aluminum? Is that why they are peeling? Not real chrome if I understood correctly.
Thanks again
PEB, now that it’s almost 2 years since you had this issue with your wheels peeling do you still have them and have they gotten worse?
i was interested in getting these because I want to downsize from the 22s that we’re on my HC when I got it used.
Thanks
Hi Young Buck,
To be honest, I haven't paid to much attention to them since as everytime I'd look at them, it really upset me.  I will look at all 4 of them tonight and let you know.  Its so frustrating to pay so much and have to fight non-stop for something that should simply be honored.  Very disappointed but non the less, will let you know. I would love to get some 22's.
Thanks man I appreciate it! Also sorry for reminding you about them because that is annoying.
I don’t want to keep bringing up negative things but I really like your set up and I’m just trying to prepare myself. Did you notice any difference in handling, accelerating, braking or fuel mileage when you leveled and got your BFGs?
I want a higher profile sidewall on my tires because these low profiles seem a little harsh for a stock suspension. Also BFG all terrain are my favorite and they don’t make them for 22s.
  • 3 months later...
Mine are peeling horribly on my 2014 high country. And the air conditioner has been an issue several times then include the navigation system going nuts
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
