6 hours ago, Joe R said:
Do you guys know if the 2019 Silverado LD/Classic has the steel UCA's? I'm sure the topic has been beat to death, but I'm going to be doing a leveling kit on my 2WD 2019 LD.
Thanks
Most likely has the stamped steel control arms.
Awesome, worst comes to worst I'll call Chevy to confirm. Thanks
  • 1 month later...
On 6/15/2018 at 2:13 PM, Robopie said:
I have 35" tires and they don't rub.   285/65r20 BFG ATs.  They measure to be exactly 34.5"x11.5" on stock wheels.
All I had to do was pull back the fenders, and they don't rub.   Your desired size of 33x11.5 will fit no problem with stock wheels.
Sorry I know this thread was from 2 years ago but I was curious what set up you have in this picture. It looks nice. I have a 2017 GMC 4x4 on factory 20x9 machined  aluminum wheels I was wondering what I could do to give it a face lift. I came across this and definitely like how it looks, so please help if you can thanks!
Edited by TexasOffRoad
  • 3 months later...
I have a 2017 Silverado with 33x12.5 x20 with a -25 offset and mine rub the plastic up by the bumper and backside of the front fender on both drive and passenger side right and left turn, with a 3" leveling kit
Edited by Jrod1
Add words
  • 6 months later...
May have gotten to you too late, but here’s my setup on my 2016 Silverado, with the same wheels as you -
2.5” front
1” rear
295/55/20 Toyo MT (33x12.2) brand new
20x9 GMC AT wheels
I have stamped steel UCAs, and the tires did rub them a good bit. I added 1.5” bora wheel spacers, and that fixed the issue, however I do get a little fender rubbing at full lock now.
Edited by Travis1024
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
