Good morning everyone,
I recently purchased a 2018 GMC Sierra Crew Cab SLT All-Terrain package. I'm personally wanting to install a leveling kit and I believe I've selected one. I've read a lot about leveling kits for 2017-18 trucks and this seems like a great kit. However, there isn't many reviews on this product by ReadyLift. The appeal of this lift is the UCA replacements and the <2" height it allows. I'm wanting to go with 305/55/20 or 285/60/20 tires with my stock AT wheels and I want as much clearance possible. I found maybe 2-3 members on here with this lift and I'll quote them below. My question is, will this work with my All-Terrain package? In the description of the kit it states, "Will not work on Z71 packaged vehicles with factory Rancho® struts." Yet on ReadyLift's website, there is nothing supporting that statement. Does anyone have any information or review for this kit? Thanks!
Edited by JamesAT18
Grammar
On 3/27/2018 at 6:05 PM, MallCrawlZ71 said:
ReadyLift 2.25” with UCA’s on stock wheels and tires for now fbc5260bf218de440b39b8fc7610d875.jpg4e7f8f30be79a7b7e6c583b1391b0217.jpg
On 3/27/2018 at 11:34 AM, TRG said:
  ReadyLift 2.25" leveling kit installed and replaced the the stamped steel UCAs with the ReadyLift tubular UCAs.  Stock block in the back.  Stock wheels/rubber (Bridgestone Dueler A/T 285/45/22s)
23 minutes ago, MallCrawlZ71 said:
Got it on my 17’ Z71 and no issues running 305/55 Toyo’s
Looks great from your stock tires! Thank you for replying, gives me some sign of relief.
I was on the same boat, couldn’t find many with it installed to answer some questions. But worked out, good luck!
Anyone using the Readylift UCA and 2.25 leveling with magniride? Looking to swap my stamped arms on my 18 Denali. My understanding is a relearn is required for magniride unless a relocation bracket is added.
Sent from my BBB100-1 using Tapatalk
your best bet is to use a relocation bracket, and most kits do include it.
Are you rubbing at all with the 305/55/20s?
Tires rub on upper control arms at full lock only
For those interested, Tirerack.com has the ReadyLift 2.25 Upper Control Arm leveling kit for $304. Free shipping.
P/N:66-3086
https://www.tirerack.com/suspension/suspension.jsp?make=ReadyLIFT&model=Leveling+Kit&group=Leveling+Kit&partNum=RL663086LK&autoMake=GMC&autoModel=Sierra+1500+4wd&autoYear=2018&autoModClar=Crew+Cab
Readylift tubular upper control arms and spacers installed. Raised the front end 2.25" Stock rear with stock 285-45/R22 Bridgestones (for now).
Love the new stance and the ride is great.
I had intended to use another company's relocation brackets for the magneride (Readylift doesn't make one) however after installation, the thicker tubular UCA placed the ride sensors right back in the stock position. No relocation bracket needed.  I couldn't be happier with the new setup. 07d6a08f7348f55a3bf1c237745d972c.jpg
IMG_20180822_0857159.thumb.jpg.415db7859f874f7d834608876067e884.jpgIMG_20180822_0857494.thumb.jpg.d4be2f0dc139270b39d6fb1bba09648f.jpg
Edited by Avolution03
20 minutes ago, contenderv07 said:
just reading from TireRack, will this not work with the GMC All-terrain package???? Thats the one lift I had everything narrowed down to
That's what I read too and that's why I created the thread. But looking at the success rate at others on this thread like MallCrawl's Z71 package and Avolution's Denali, I think we're safe.
The hardest part for me is finding tires that fit... but I think I'm going with the 305s. They have the best look of them all.
awesome thanks!! I want to get a little bit taller tire (275/65r20) so maybe that helps out some?? Hell I don't know anymore lol
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
