14 hours ago, Cmillerjr said:
So far so good. Picked it up on Friday. Comfortable ride, drives nice. There is more leg room in the back seat than my ‘14 crew cab LTZ 1500 or ‘15 crew cab High Country 2500. Truck is 3 inches wider than the previous model too. Sunroof is also wider in proportion to the cab width. I have a few hundred miles on it and am seeing pretty good numbers. I’ve got nothing but compliments everywhere I’ve gone.
2019 Chevy TrailBoss
5.3 Motor
16.5 around town, 21 on the highway @ 70 mph. Not bad considering the OEM 2” lift and off road tires.
Nice truck, I'll probably be getting one like this in a few months... I have a question for you, In the row of switches under your HVAC controls ( auto stop start, bed light, parking sensors, hazards, ect,) do you know if the 2 black buttons with no markings on the left and right sides have a purpose?
This is the first time in awhile that I've prefered the look of a Chevy over a GMC. Outside of the AT4 the 2019 GMC's haven't done much for me. It will be nice to see a volume of GMC models and colors now that the Chevy cat is out of the bag.
The black Trailboss is probably my favorite looking pickup right now with the High Country in any color a close 2nd or 3rd.
Yes, that is actually where the trailer brake controls are now.
30 minutes ago, newdude said:
I'm not OP but the Duratrac is LT275/65/18 C load.
Correct, LT 275/65/18. They could be a bit bigger in my opinion.
4 hours ago, SkiDooNick700 said:
wow that looks pretty sharp. Does Trail Boss come with the 6 or 8 speed?
How is the trans? Clunky or smooth lol.
8 speed I believe, it’s very smooth. Nice acceleration.
Agree I think a 275/70 would be a bit better and would be a way more true 33" tire.
4 hours ago, Sierra Dan said:
Congrats!  :thumbs:
Are your Mirrors Power folding?
No, power mirrors, leather seats and park assist are the only options this does not have that my High County did.
GM said it was set up to fit a 33" tire stock. I and a lot of others assumed they would come from the factory with 33's but it looks like that's something you have to do on your own. I'm guessing they stuck with the slightly smaller tires for fuel economy reasons since the truck has an EPA fuel economy rating separate from the rest of the 2019 lineup.
4 hours ago, f8l vnm said:
Just wish the 6.2 was an option on the TB
The 6.2 is an option on the Sierra AT4
That is the first Trail Boss I have seen in Black, and it looks really good. Good thing it is lifted a little bit considering you live near Pittsburgh. I know I certainly don't miss driving on those roads.
5.3 Motor
Edited by Jetmek
Oh ok I will check when I get home and let you know if mine are blanks or not.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
