Tailgate release handle (button) has two small lenses on either side.........the driver's side is the camera but couldn't figure out the passenger side.....until I turned on the bed lamps with the tailgate closed........it is an LED lamp that lights up the button and the whole rear of the tailgate. Don't know if standard or only with optional inside bed lamps or remote drop gate........but it is impressive and a nice touch because the cab lamps don't light the rear handle of the gate..
well great, now I have to go out to the truck and check this out,   I thought it was a second camera for the close up view of the hitch...
Makes me crazy and manual is no help. Standard backup camera with normal wide angle view of rear. Camera icon contains only two option one with tire track lines and the other with a straight line for the hitch. no surround system. Every now and then when playing, has something to do with being in Park or pressing the touch button to display the line for the hitch, but every so often I get a top down view of the hitch from the single camera in the tailgate (other dome is an LED light) and don't know how I did it, or if a software defect.....also happened under the previous rev before Nav software update..
Seems the top down on the hitch view has something to do with sequencing of button presses, ignition position shift lever position and gear the shiftier is in. As I said manual is no help and neither are salesmen.
I'm curious about this too, as I have no clue how to access this feature.  It's annoying that such a useful feature is not detailed anywhere.
I thought the LED light on the tailgate was a camera, but slowly figured out that it was a light that comes on with the cargo light/bed LEDs.  For future reference, when you turn on the cargo lights they automatically go off when truck is put in drive but come on the next time truck is parked.
I'm going from memory here & I've not got it 100% memorized because it is a bit oddly set up.  I believe once you put the vehicle into reverse to activate all POV, each icon is a different camera POV.  On each icon, there are 2 dots, representing "options" for those views (try pressing the same icon twice).  The last page seems to be the "main" viewpoint choice - or something to that effect.  Play around with it a bit more - I might be completely off with my descriptions.
Sounds like a glitch in your case if you don’t have the advanced trailering package (optional on LT/RST, standard on LTZ and up). Because otherwise it’s quite easy to access the hitch view.
Trucks without the advanced package, and only the standard trailering package will only have only have two icons on the backup camera mode to toggle between single guide line for trailer alignment, or the normal grid lines.
Trucks with the advanced trailering package will have a third icon of a hitch in the backup camera mode for a “top down” view. It can also be accessed for 8 seconds while underway to check up on things as shown.
Obviously, trucks with the tech package or trailer camera package will have more views available than the three, but in the case of an LT or RST, you’d be looking at either two icons or three in the backup camera mode.
Edited by OnTheReel
2 things discovered today -
--1: The trailer light check in the MyGMC app is pretty cool. Finally got around to rewiring my boat trailer and wanted to test it out - the app fires up all the lights in sequence so nobody has to sit in the truck pushing pedals and flicking levers :)
--2: ok, probably not a big deal, but finally figured out what the round cover thing is to the right side of my license plate....  having never owned a truck before, didn't realize that is where you get access to the spare :)
Another one....  This one discovered by my 10 year old...    Always wondered why there's no steering wheel audio controls.... Turns out there are!  Buttons on the back side of both sides of the steering wheel......  Amazing.   Nothing mentioned in the user manual.. (it's in the separate infotainment manual)
Lol...how old was your last truck?! My 03' Silverado SS had them.
First Pick-Up truck :)  I just retired (well, forced retirement) my 1999 Isuzu Trooper :)
Most other vehicles I've seen have the audio controls on the front of the steering wheel....
You were overdue for a new truck!  ? Congrats on retirement (forced) I also was forced into early retirement.
To be clear, the Isuzu was forced into retirement...not me :)
  • Haha 4
Is there a way to use the camera on the third brake light to view the inside of the bed?
Sent via Morse code
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
