5 hours ago, Jrodpic said:
Update on the rubber cord idea. The gap is not consistent all the way across and the rubber cord is firmer than I expected. I haven’t had a chance to try and soften the rubber up to get it to fit all the way across. Maybe someone else has some ideas on a softer weather stripping/ cord to fit in the gap???
I wonder if plumbers putty or silicone caulking would work?
22 hours ago, LSUAT4 said:
Update got the window sealed and it turned out Sh.t, big blobs on both sides. Dealer tried to cut it out, made it worse. They are ordering a new rear window and having it replaced at Safelite, hopefully they  do a better job. Rear seats and head liner have to removed, so excited to have a brand new truck tore apart again!
Totally feel you pain.  I am a 8/20 build too, so far my valve springs are good (1700 miles) but my rear window leaks as well, and my battery has had to be replaced.
This is the exact reason I haven't had my local dealer attempt to fix this.  I really don't get why these windows all leak lol Its just so unacceptable  IMHO
I live in western Washington and it rains here a lot. I had a trans leak and when at the dealer I asked about this. He said they had never had one come in for that. He didn't even know about the problem.
Just rained in San Diego for the first time since April, or so I've been told since I moved here in December. Decided to take the opportunity to see if I had a leak. None so far, but will check again tomorrow since it'll be raining through tomorrow night.
Why would you think he's talking about a truck frame crack?
I'm fairly certain he was obvious with "a crack in the frame of the sliding window".
Maybe he should just replace the cam instead.[emoji1787][emoji1787]
It's apparent some people are not here to be constructive contributors.
Maybe some of us can actually comprehend what we read. This isn't the first time you've ran off in left field when the ball went right down the middle.
According to the rules of this forum, you have 2 options:
1) Add me to your ignore list, or
2) Report any post of mine you feel violates the rules of this forum.
Having read the rules myself, I know your comments towards me violate the forum rules. Please stop, or I will report your posts.
https://www.gm-trucks.com/forums/guidelines/
It's not a personal attack. Simply stating my opinion. Do as you wish. You're free to use that ignore feature as well.
Edited by polarys425
Took my 2020 to the dealer on Friday for the leak on the passenger side.  Its supposedly their first.  No cracks were found on the slider frame.  Having the headliner, spoiler removed to apply sealant.  Will see if it works.
Let's us know if you can where the dealer put sealant on the spoiler?  Straight across the top gap or around each bolt hole?
Leak is only at the window frame.  Spoiler has to come off to get to the window for sealant application.  I'll ask though on what they did exactly, hopefully tomorrow and let you know.
I'd wager good money that it is cracked just like all the others in this thread.
Welcome to the leakers club.
I'm lucky, If you can call it that, I live in a dry place.  Such a shame that these vehicles are leaking.  Seems like such an avoidable problem.  You can watch the robots sealing seams and installing glass at the factory online.  Somehow there's a glitch in the assembly line that GM isn't addressing.  My $250 GMC that was my first vehicle had holes in the floor but was still water tight, unless you ran over a puddle.
Well I have been waiting a month for the replacement window to come in. I'm losing faith in GMC. I will let you know how it turns out. I have a bad feeling there will not be a happy ending to this story...
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
