On 7/9/2020 at 3:28 PM, Michael Huddleson said:
There is a new update out for the navtv, supposed to cure our issues
posted 2 days ago
Did you install it?  If so, did it solve the problems?
Has anyone had any luck with 100% drop-in replacement speakers for the 8" non-bose setup? I'm doing a subwoofer soon and for an extra couple hundred bucks it probably wouldn't hurt to replace the 6 speakers and run it off the stock amp
For those that are using navtv, are you using rca out of the navtv or tos link?   Supposedly the tosslink is causing problems and they recommend rca
Nav Tv is the biggest piece of ******. I’m having to go back to the stock Bose amp because they sold us something that doesn’t work no matter what you do. I switched fromToslink to RCA. Worked for a few days and now I have nothing. I’m over it. We’ve done all their updates. They don’t work. Do Not Use NAV TV
On 8/14/2020 at 6:59 AM, Mike Borowski said:
Anyone replace the BOSE speakers only?  It's a weird OHM right?  So if you use 3-4OHM you're going to lose power right?
Yes I suggest components in the rear.
I think the Bose speakers are 8 ohm.  You may damage the Bose amp with lower ohm rated speakers.  Can someone verify the ohm rating of the factory Bose speakers?
On 8/18/2020 at 7:17 AM, Mojonito said:
Apparently  you can lower them via the truck menu
I found the setting for this but it wont let me adjust it any lower, just higher and is set to the middle.
Were do you guys ground the wire to? The installers drilled mines to the seat post of the chassis but didnt brush off any paint.
So are the issues still persisting with the NavTV units? I'd prefer to go with before the amp solution, but right now they're the only game in town. I just talked with Pac Audio, and they don't have anything yet for the 2019-20 GM trucks and had no idea if they'd even have anything this year. None of the other similar oems like Maestro or Metra have anything for the amplified applications.
If NavTV is still having issues my only options are after amp solutions like the JL Audio Fix 86 or Audison Bit Ten.
They work. Some minor issues remain but it’s way better than the other options and sound 10x better than them.
I’m calling mine quirks rather than issues. [emoji23]
The reason I ask is the last person to talk about the NavTV system, Ecroofing01, essentially said don't buy them because they can't keep up with their issues. From what he's describing, it's sounds more like issues than quirks, when the unit outputs no sound. My installer suggested the ampPRO from Pac Audio, but they don't seem to be in a hurry to put out a similar product.
The reason I want to get it right the first time is that I don't live in a city that I can just pop over to a shop if I'm having issues. I live about 80 miles from the nearest stereo installer and they're the only stereo shop in that city, which is the case for most of my state. There's only about 3 cities that have more than one installer, but they're about 130-200 miles away. And being without sound isn't an option.
I've already replaced all the speakers except for the sub (Hertz Audio in the doors and Pioneer tweeters in the dash), and right now it sounds worse than it was stock. They're better speakers, but they're running off a signal processing that Bose did for their own speakers. So right now I have to turn the bass to about -7 just to not have it sound boomy. I had almost the exact same setup in my 2016 Silverado, and all we did was put LOC's in to feed amps with those same speakers. After I took out the sub to trade it in, the system sounded better without a sub than this one does with it. I believe that's due to Bose's signal processing.
I wish GM would get away from this mindset that you shouldn't try to upgrade the sound system, or at the very least give you the option of deleting the Bose system from the package it's bundled in. There were other things in the package I wanted, just not the Bose because I knew it was going to be a headache to deal with installing an aftermarket stereo in it's place.
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
