This has happened to my A8 2x now. The first time - as others have reported here - was when I was in reverse, then went to D and applied a steady bit of gas.
The second time was today. Since it happened the first time, I've learned something... whenever I reverse out of a parking spot, I bring the truck to a complete stop, put it in D, then slowly accelerate for the first 10-15 yards. Today, I could sense the truck was going to "clunk" as I was backing out of a parking spot, but then putting it back into D to pull in more straight to park. I let off the gas and it did not clunk as hard at all. I could actually FEEL the transmission slipping a bit, so I didn't apply the gas, then it found the gear.
Conclusion... the more I come to complete stops before shifting, then letting the truck sit for 1-2 seconds in D before moving forward, the less of these occurrences I have.
My company has 3 at4's and an slt and they all do this.  I got the same run around from dealer, "couldn't duplicate it, here is a bulletin saying it's normal".  Pretty disappointing.
Glad to find this post, describes very well the same issues i’m experiencing. What is very disappointing is there is no fix.  GM engineers need to get their thinking hats on and find a solution.
Good info and all, but we shouldn't have to do this. With the delay mine has, if i floored it without giveing it 2 secs fully stopped in drive the trans would prob drop out. You could put my ram in drive with it still rolling back ever so slightly and it would go just fine. I just cant understand why GM cant fix this.
On 7/22/2019 at 9:50 PM, Walter Gill said:
I am having the same issue.
The dealer keeps telling me it is operating as designed
it clearly isn’t. Hesitation, hard shift, surge forward, sometimes almost dies at idle and sounds like it misses in the exhaust on occasional start up.
I stomp it when coming from reverse to forward.  Might as well rip the rear end out before warranty runs out.....lol
On 3/17/2019 at 9:40 PM, Drew Bellucci said:
Anyone else experiencing a hard shift or hesitation of the engine when you first hit the gas. For example, I start the truck, reverse out of the driveway, put the car in drive and when I hit the gas, the truck goes toward and then i feel the truck completely stop for a second (hesitation) and then it continues forward, I only expierence this when I’m going from reverse to forward.  I come to a complete stop and do not shift to drive when moving backwards still. ?
Mine just did the same thing today and has done it before. just add it to the list of issues with this thing. I'm just happy when it starts up the first time I push the button.
Same issue with my 19 SLT, 5.3 8 speed, about 3-4 times weekly on first driving off...dealer kept over night and guess what... couldn't duplicate customers issue, operating normal, sucks, mine also does it after reversing and going to drive sometimes, after its been driven all day,GM has a fix, they will probably shitcan the8 speed and go to 10  speed in most all. the only fix I know is trade it for a ram or ford, or a 6.2, with 10 speed gm but they might have other issues.
Edited by DaveHC
Same issue... so close to making my way to the Ram dealership.
Reminds me of a Hurst slam shift. She’ll shift or she’ll blow! Drive it like you stole it.
  • Haha 1
Not sure if this is the same issue but mine last night I put it in reveres and it kinda slammed I backed up 15 feet put it in drive started to slowly accelerate only made it 10 feet or so forward and it felt like the transmission popped out of gear and my back tires locked up, but it put it back into reverse and was able to move the truck, I tried several more times it did the same thing. Left me stranded, I hopped In it today and is working just fine. Anyone know what this may be?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
