4 hours ago, AMPRG said:
Take it back to the dealer for software update.
Did that. Nothing different on my end. Did it work for you?
so o have a 2019 silverado 1500 LT and am having this same issue I have had the issue since day 1 aswell. Dealer replaced the camera still have the issue. Dealer advised me GM is working on a fix and to contact them to ensure even if i am out of warrenty it would be fixed. GM has given me the run around no answer nothing assuring me they will fix it when one becomes avilable to the point my issue was escalated after speaking several times to the senior advisor 2 days ago I recive a email stateing they cant reach me at my contact number proived... the same number i have spoken to them on multiple times so i called and left a voicemail with my number again haven't heard a word. From the start GM has given me the run around i owned a 2015 camaro. And now currently own a 2019 silverado and a 2018 traverse and im done with GM after this im so pissed they have been giving me the run around for over a month and no resolution they actually deny and claim there are no bullito  on the issue even when i give them the bulliton id the dealer gave me they actually told me he isn't supposed to have given me that. So GM has lost a customer after this oh and now today my Brakes say service brake system. 16,500 miles on my truck and nothing but problems **** you GM I'm hiring a attorney and filing for a lemon law
good luck on the lemon law i went to see an attorney he said would take 2 years to settle the case.. told him forget it i would trade the truck in before that.....i am have the same issue with the camera, but i have a intermittent   miss fire that comes and goes had truck 8 months only 4500 miles on it. its been at the dealer for 2 weeks now cause they need it to happen while they have it so god only knows when ill get it back..  GM is no help ..
Just got a 2019 RST and having the issue.  Strange thing is it didn't happen when I test drove it.  Kinda bizzare.
Hey guys, wanted to share that mine 2019 LT with 8in screen has a poor grainy camera, even flickers like a 80s tv. I am considering looking into the wiring to see if it can be tapped into using an aftermarket camera.
Having the same problem with my truck too. Sucks to have purchased a brand new truck that comes with issues. Also sucks to have GM say that because you didn't spend more on a higher package, your camera/screen is gonna suck, sorry, not sorry. However, besides that, I do love the truck.
Got the service camera system message last week.
Horrible picture, grainy at all times, and it flickers with the touch of the brake or any other power draw.
Still "working" though.
Same result.  Truck to dealer w/ screen going out in reverse and lines while braking.  Radio replaced but did not resolve.  Dealer contacted GM, stated they recognize the issue and do not currently have a fix.  Just piling on my experience.
Edited by 2019SilvRST
I have a 2018 Sierra Duramax with SLT package and I get blue screen with “service rear camera” on screen. Happens often and always when truck is cold first thing in the morning. I’ll be call GM and NHTSA
OK I have a 2019 Chevy Z71 RST model I purchased and took home December 27th 2019 with 176 miles on the truck.  At night time sure enough, I pet the truck in revers to back in my driveway and I have this HORRIBLE grainey / Pixelated display and on one occasion the camera cut out and went back to the normal display screen.  I took it to the dealer on January 27th 2020 with 865 miles on the truck. They had the truck for three days to inform me that they could not reproduce the problem and that they compared it to other similar vehicles and it is operating as normal.  They also told me that I DO NOT HAVE THE HD Camera. (I though the RST had an HD Camera) They also told me there was no FACTORY HD Camera I could add to my truck.  Because the rear camera's picture quality is so BAD it is useless and when I went to just turn off the screen so I couls see out the mirrors with out the interfearance of the bright screen light, it appears that Chevy neglected to provide the ability to turn OFF the screen...... It's hard to believe that Chevy does not have access to the same camera technologey as other vehicle manaufactures or a too cheap to provide all of thier vehicles with a quality camera in light and dark conditions, especialy in a $46,000 truck. I want this issue resolved!
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
