All Terrain tire poll for '17 Sierra 4x4
11 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I understand the tire subject has been beaten to death but please hear me out. I currently have the Nitto Ridge Grapplers in 295/55/20. They are E rated tires.  I really like how they look but after running them for 2 years, they are loud and harsh in my 2017 crew cab sierra denali 4x4 6.2L .  I'm looking for a quiet tire with a SL load rating, comfortable ride but aggressive look.
I'll probably be going with 275/60/20 for the new tire size but also considering 285/55/20.  I've been doing tons of research, reading reviews and forums but since I have no experience with the 3 tires in the poll, I'm specifically looking for people with first hand experience switching from an E rated tire to a SL / XL / P rated tire.  I have also owned the Nitto TerraGrapplers and did like them ok but looking for something different.
My truck is mainly driven in the city 85%, highway 10% and about 5% in the country (gravel, muddy fields, etc) while hunting a couple times a year.  I also live in Missouri, so we do see some snow from time to time but that is not much of a concern with 4x4 already.
Price is less of a concern but since it is relevant:
Falken Wildpeak               275/60/20 - $238 each or $952 for 4
Toyo OpenCountry AT3   285/55/20 - $234 each or $936 for 4
Toyo OpenCountry AT3   275/60/20 - $266 each or $1064 for 4
Goodyear TrailRunner     275/60/20 - $156 each or $623 for 4
I'm getting old and want a smoother ride=lame.   I know the magnaride is not the smoothest, I plan to see if the tires do the trick for me and if not, suspension is next.
Many thanks!!
Edited by 17Sierra1500
typo
I have only tried the Falkens but like them so far. Same size, 275/60R20. I just had them installed back in Dec. I chose them after reading up on the same ones you have as choices. They have a great look and so far not loud.
Edited by mikeyk101
I have the falkens, 295/60r20, I like them alot.
They aren't as stiff as I thought they would be for E rated so I'm happy. They ride good, have great traction in the snow, ice, water, mud and dry. I have been very happy. They aren't really noisy either. Granted I have exhaust so I don't hear them over that.
You won't find a quieter, smoother riding, better handling, longer lasting, all weather traction tire than the Michelin Defender LTX M/S. Looks good too.
Edited by Diamond817
That quote is spot on ^^^^^^
Put them on our Tahoe with MR suspension, 22" wheels and the ride is great.
I voted in the "something else" category.
- Continental Terrain Contact AT
- General Grabber APT
- Firestone Destination AT2
I had a set of the Grabber APT for about a year on my summer wheels.  I liked the look of them and noise was very low.  Good ride too.  Ended up switching to the Continental Terrain Contact HT as it was (per Tire Rack testing) a top handling, skid pad and breaking (dry and wet) HT tire for my stock 18" wheels.  I don't have any test data but concur with Tire Rack's results as the handling when pushed on winding roads is quite good.
Firestone Destination AT2 as @newdude mentioned are good ( a friend of mine loves 'em) but I stick with the tried and true BFG All-Terrain KO2s for on road and off while still having a bit of compliance on 35 PSI even on the E rating.
I've had great luck with the General Grabber ATX's in the past. I was searching a few months back and ended up finding great reviews on the Falken Wildpeak AT3W's which I pulled the trigger on in 275/60/20 (33"). Absolutely blew me away how they handled in the snow and rain, offroad and are very quiet. 10/10 would recommend for a "budget" A/T tire as they are cheaper than most.
Edited by boettcher40
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
