My trucks going in for open heart surgery in a month. DOD delete, tsp stage 2 L83/5.3 cam in my L86/6.2. I eventually would love to put a blower on it. I drive the truck frequently and don’t want to do too big of a cam where I’ll have to change my torque converter. Will I get away with a L83 stage 3 cam with my stock converter or should I stick to the stage 2. Specs are 5.3L Stage 2 Camshaft w/ +32% Fuel Lobe: 218/226, 635", 113 LSA, 109 ICL
All my mods will be intake, portable TB, (hopefully have my heads ported when it goes in for dod delete and cam) LT4 injectors, 1-7/8 long tube hears, off-road y-pipe. I’ll have a 3.5” electric cut out followed by stock exhaust for now.
Trucks reverse level and blocks removed. 22x12 -51 285/35r22 no trimming or cutting
That's kinda on the edge for size, likely would be okay.
The 218/226 would be large for a 5.3 in my opinion on a stock converter, usually a 212/218 is about the biggest people go on a stock converter. The added cubic inches of the 6.2 should make it alright.
You also have an 8 speed so the drop in rpm between shifts is less than the 6 speed, so it helps to stay higher in the rpm.
I ended up changing it up for the vvt-2 231/235 .645/.635 116 LSA +32% fuel lobe. I can’t justify doing that much work and end up regretting it by not being aggressive enough. With the stock converter I’ve been hearing it’s less noticeable with it wanting to push through the breaks/stall on the 8-speed trans.
It's not that it will push through or stall but it's going to have nothing down low. The idea of the higher stall converter is to like a light switch snap the rpm in the correct range for that camshaft as well as not allowing the rpms to fall a lot during gear changes.
That's a big camshaft for a stock stall and I'd suggest getting a new converter.
Probably a 2500-2800rpm stall. You can contact a torque converter company and tell them the mods you are doing and they will help spec a stall converter.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
