bad bounce while towing
rusty01
I have been noticing a bad bounce when going over bumps when towing the TT. I had new shocks installed on the rear but that did nothing to remedy the issue. I did not replace the front shocks yet. Could those be the culprit? It almost feels like the camper is "pushing" down and forward while going over bumps. Truck and camper are in my sig. Any other info to help rememdy this would be helpful! Thanks!
  • Replies 76
Definitely get your front shocks done so you can hopefully discount that possible problem. Double check your trailer brakes to ensure they are both working the are providing enough stopping power. Also make sure you have the trailer loaded so that you have approx. 10-15% weight on the tongue. This will help prevent sway and provides better control of the trailer while driving. Lastly take a look at your equilizer bars, making sure you are putting too much/little weight distribution between your truck and trailer. If this all sounds like Greek take your truck/trailer combo, while loaded as you would be going camping, to a camper/travel trailer dealer and have them go over your rig to double check all settings and adjustments.
Sounds like you may not have heavy enough hitch bars. Weigh the tongue then make sure your bars are rated heigher than that. With the correct bars and hitch setting, the steer axle should have 5 to 10% of the tongue weight on it.
Mike
Did you try changing your speed while you were feeling the truck/trailer "bounce"? While it sounds like you may need higher rated bars, it is possible you were feeling "porpoising" due to road conditions.
As for how much weight to transfer to the trucks front axle, some now say to only transfer enough so the the front tow vehicle (tv) wheels weigh the same unhooked (no trailer at all) and hooked up, bars latched ready to go.
BUT... others, like Mike, like to transfer a little more weight to the front than when unhooked.
Which way is correct is the million $ question!
When I set up my 2k Chevy ECSB 4x4 I transfered almost enough weight to the front so there was almost equal drop front & rear. This was before I learned about actually weighing the truck/trailer combo at the CAT scales. I set up my new truck by transfering enough weight so the front axle weighs almost the same as unhooked. I am still trying to fine tune it though!
Good luck!!!! & keep us posted!!!
Chris
Chris
Well said, as other input.
Porpoising was my first thought, especially if you were experiencing this on a concrete highway. Seems that many times the sections of concrete match the resonant frequency of the combo. If you are going just the right speed, it will jar your liver. In those cases, there is often nothing wrong with the setup; you'll just need to vary your speed.
I tinkered with my setup so much that I tired of it. I even went to both extremes. Once I even had so much weight shifted forward, off the rear tires, that a simple, slow launch resulted in spinning tires on dry pavement!
Ultimately, IIRC, I got just a little more weight on steer axle than empty. Works well. I've got my Cat Scale sheet scanned. I'll try to post it tomorrow.
Your rear springs are not up to the job, too much weight. And like was said, you are pushing the limits of a 1500 with that size trailer IMO.
OK, I understand that the trailer is almost too much for my 1500, I get that. I knew that before I bought the trailer. I did install some Monroe Sensatrac coil overs in the rear. Didn't seem to help any. I did try and vary my speed but didn't seem to help. I wonder if maybe I do have too much WD to the front. I guess I will have to mess around with bar placement and see what happens. I am getting new shocks installed on the front, Monroe Reflex monos. I do hope it's just due to bad front shocks but the way it acts I am guessing that will not totally fix it. Might help a little though guess I'll find out.
Get a bigger truck
You gonna buy it for me?? Duh, of course that would be the best option but since I am a poor Michigan worker, I gotta use my ol rusty pickup! lol
Just to back up a bit, what are your official weights on this trailer? Take it to a certified weight scale and get your true empty (dry) weight, tongue weight and rear axle(s) weight. Then do the same for loaded. Then with loaded with the truck (also loaded). I am a curious type person and would like to see what your actual numbers on this truck/trailer combo. Yeah you "might" be overloading but then again maybe not, after all trailer size isn't the real issue as trailer weight is what is going to be the problem here.
Looking at a website for the trailer, it's listed at 6890lbs dry, so the GVWR is most likely close to 9000lbs.
What I see on the website is that they're listing the hitch weight at 3010lbs, that can't be right. I would suggest to get the trailer weighed, and have the tongue weight weighed as well. Then you'll be able to make a more of an informed decision on what might need to be done to your tow vehicle to support it.
What is the exact model you have ?
Yellow sticker on door of trailer list 6298# dry. Listed dry weight online lists base weight of 5590# and hitch weight of 740#. GVWR on trailer is 7600#. I do not have a convient way to weigh the trailer as there are no cat scales close to me. Just going off what is listed on the trailer itself and my onwers manual of my truck. I do know we pack rather light with just minimal things needed for camping.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
