I was thinking about the front suspension again, there is aluminum a arms and there are steel a arms randomly installed in these vehicles why?
My truck has steel a arms installed with 40mph - 55mph vibration.
3.42 gear crew cab All terrain 6' 5" box
This isnt what is causing it because some vibrate and some dont, but i was just under my CEO's 2014 Ram 1500 Crew and notice that it has vibration damper on the outside of each frame rail under the drives and passenger front doors and also a damper built onto the drive shaft front yoke just off the transfer case, also have heat reflective sound deadening mat above the transfer case, transmission, and under both the driver/passenger floor board. Just some thought
Just some advice, take it for what is worth which may not be much. If they are still willing to work on it and think it is the drive line, let them keep trying and complain here. Maybe they will get it fixed before they give up. At least he didn't get out of the truck and say they were done. That day may come.
Oh it's the text language barrier here. I'm not agitated so much at the service guys (yet, until they give up or say it's fixed when it's not) just the fact that we spend good money on a vehicle to have crap like this. This is my first brand new vehicle and may be my last depending on how this situation and the next few years roll on.
As far as driveshafts, I know my factory one is aluminum but not sure if it had a pn on it. I was under the truck this morning and don't remember seeing a tag or anything. Anyways, I'll keep an eye on recent posts in here and will update when the new shaft gets installed.
Was hoping to not have to post on this one but it has happened. When I bought mine in August it had a slight vibration in the front that was fixed by a quick balance. I now have 4000 miles on it and just took a 450 mile trip to the keys and on the way down it started to vibrate the back seat around 72 mph and by the time we got there it was worse. The vibration on the way back home was worse from 70 to 86mph. Just left the truck at the dealer for RF Balance and they said that 3 of the 4 tires are defective and the 4th is borderline. They are replacing all 4 with new ones so I will post back the results. Did ask them about the Michelin upgrades and they said they would if I pay the $350 difference which I am not willing to do yet. It appears as if these tires may start out ok then go bad??
Anyone know if the Michelin LTX M/S ride as quiet as the OE Goodyear's?
A coworker just put some on his Toyota 4Runner and loves them. They look less aggressive than my Goodyear SRA's so I assume they will ride just as well, if not better.
My truck is also in the shop today for vibrations. I'm like you I think it's a tire problem since the truck was great in February but after 2700 miles the vibration started to creep up. If they balance everything today and the ride improves, I think I'm going to definitely get an alignment done at an independent tire shop at my expense to make sure that's not causing bad tire wear. I've stated this before but I have a side mechanic I use who is a former GM dealership mechanic and when I told him I bought a new truck he told me to immediately go get an alignment done. He said GM doesn't align their trucks when they build them they use plastic tabs to set the alignment to predetermined calculated points and it causes uneven tire wear not having a true alignment done.
I certainly think this is a possibility. I remember reading about a forum member who would have the truck ride fine for a few thousand miles and then would start vibrating again. He had the OE Goodyears and he did a test. He grease penciled a spot on the tire and rim in the same place. A few hundred miles later, the two marks were not in the same spot, indicating the tire actually rotated on the rim some and threw off the balance.
I wish my problem was tires but I got rid of the OE GY's and have some coopers on, all road force to lower than 12#, and a few other members have aftermarket tires with low road force and their truck still vibrates.
I hope for your sake its only tires, but there are a couple of different issues we are all chasing down.
Mine came with Continental Crosscontact LX20 tires. No vibration, but they did "flat spot" in the cold if the truck sat for a while. I have always liked the Michelin LTX M/S 2, so I changed them. Smooth and quiet. I love 'em. These are a touring type vs AT, just as the Continentals.
Thanks for the info guys on the alignment and the Michelins. Just got a call from the Dealer and they said they have found that two of the four new ones they mounted are defective also so they have to order two more and wont be in until tomorrow. I asked them how many times they want to remount new tires just to find that they are no good and waste countless hours rather than just giving me a decent set of tires and being done with it. They said if they get these other two and they are bad, then they may be able to get the Michelin swap approved. Hard to believe that these tires have been an issue for so long and they still try to use them. Does Goodyear pay the Dealer for all of the time the techs put into these issues?
I wish I had found this site 2 years ago.. I have owned 4 new Chevy trucks in the last 18 years and I recently just bought my wife a new 2013 Equinox's. So I am a Chevy man. Only on one occasion have I ever had to take my truck to be serviced, and that was my 1994 short bed. The clutch went out at 6,000 miles.. Other than that I have never had a problem with my prior trucks.. I now own a 2012 Chevy 2500HD and it is the worst truck I have ever owned. I am posting this because I am having the same problems that the original guy and others are having and for 2 years I have been trying to get the problem solved.
This truck vibrates as it roles down the road since it was new. I have felt it in the peddle the accelerator and throughout the truck. It cups the tires on the inside and the out sides. The center of the tire has 1/8 inch high and low spots after 6,000 miles. I had taken the truck in numerous times only to be told they cant find the problem. I purchased new tires. They took my tires off and were going to put the new ones on but they later found out that they couldn't get then in so the put my old ones back on. I sat there for 2 hours after they had been put on, no one told me the job was done. I had to ask if the job was done.. That was an accident or so I told myself... I brought my truck back a few day later I didn't have time to get back I had work to get done which I told the service man. I can back to have the tires put on and I waited.. Again the tires were finished and I sat there and sat there. I had to ask one of the service men if it was done again I found out it had been done for 2 hours.. To me this was there ploy to keep me from coming back. I work out of my Truck so my time is valuable as is my truck.
I came back a few months later to have 2 armrest replaced because the cracked out (only one was replaced) so while I was there I showed the cupping to the service man and told him that it still vibrates when I drive the truck and I was kind of blown off. At that point I was feed up. I called GM who then called the dealer which then got the ball rolling. I brought the truck in again and they brought in the manager which I then showed him the cupping. He tells me that since I only had one paper showing rotation (I rotate them at my shop most times) that he couldn't do that much. That if I wanted to buy 2 more tires that he would pay for the rotations. I said bullcrap I just paid over $1,000's for tires, that I wouldn't buy another tire. He came back and said he would buy them but I would have to pay for the rotation. I really didn't even want to come back remember I was left hang on two different occasions for hours.
I agreed and when they went to put the tires on they realized that they put C tires on and E's were suppose to be put on. sS they replaced all 4. At first the problem seemed better but after a week or two the problem was there again I am sick of it.. If I have a 44oz drink in the console it shakes like crazy. My mirrors have wobbled for so long that everything is blurry when in use..
I now have Googled the problem and the vibration problem seems to a common problem, But I haven't heard of to many people complain about high/low spots and cupping of the tires..
I now have called GM and set another claim and I have switched dealers hoping for some resolution. The problem I have, is I now have 67,000 miles on the truck. My first phone call about the problem was when the truck had less 15,000. I am so disappointed with GM. If this problem isn't solved I will never own another GM vehicle again..
Sorry for the rant but I just found a site where others are having the same problem I have.
The trucks arm rest on both sides are cracked out. I tried to check the tranny fluid for the first time and the dipstick holder is cracked in half at the mount (For how long is the question) When I start the truck 1 out of 4 times it turns over 8 to 10 times before it starts. I own a lemon!
Ok so I just picked up the truck with 4 new Goodyear tires that were RF Balanced and have zero vibrations from 0 to 100 MPH. We will see if they last or just go bad after a few thousand miles like the last ones. They did agree to put Michelins on if the problem happens again.
That's BS that the tech couldn't feel it. He's flat rate. He makes crap working on a vibration issue.
When I went for a ride with the tech, he tried to say it was normal. He also let out an audible sigh indicating he's not interested in a vibration. If there's no vibration , why do these dealerships keep throwing all kinds of parts at them. Don't let GM brush you aside!!
That's hilarious my tech guy did the same thing... They get paid a % for the work they do. They don't want problems like these, they want the easy pull out the bad put the new in.. I really don't blame them.. But on the other hand people like us get the shaft due to the way these dealers pay there mechanics.. The service rep told me that they want to find the problem which I am sure they do but there is a certain point where they realize that it is more than they want to get into due to what they can make.
Edited by Wildman18
Has anybody thought about putting it on a lift and running it up to the speed it shakes at and looking/feeling around the underside?
You don't even need a lift, putting the rear end on 2 jack stands will work. You can also eliminate all the constant "it's the tires" comments if it still vibrates.
Well I'm happy to report that I think it was my tires. I picked up my truck this evening and the rep told me they had to road force balance my tires and found one that needed adjusting. On the ride home I noticed a major improvement. And this is after I adjusted the psi a couple weeks ago and that helped then which initially had me thinking it was the tires. So I'm definitely going to a specialist next week to get a proper alignment done. Other than that I'll just keep the tires balanced and rotated and run these for a while to save some money until I can put Michelins on.
They were unable to fix my shifting driver seat so I'll probably go to another dealer on that. And the MyLink display is flickering again after over 2 months of working fine and thinking they had fixed it. This truck.....one day at a time. It's a love-hate relationship.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
