I have aftermarket exhaust and afm disabled and it still vibrates.
Tech at the dealer said my exhaust was probably causing the vibration [emoji34] .....It vibrated with the stock exhaust also.
Sent from my VS990 using Tapatalk
F-ing GM will try to blame everything under the sun other than their piss poor engineering.
Hub flange turns true. Bolt circle for the studs is completely off center shouldn't be an issue for hub centric wheels except the wheels are drilled for cone seat nuts which inevitably tries to center the studs in the holes, and since the center portion of the wheel is oversized by about .040" to allow a free fit on the hub pilot flange the wheel is allowed to be mounted with it's axis off center from the hub center and aligns itself with the bolt circle. I have one tire with a little bit of runout in the tire itself I'm going to try and mount the high spot of the tire 180 degrees out from the high spot on the stud bolt circle and see if that offers any improvement might alleviate the up and down during rotation but the center that the balance was used for will still be off by .015".
I remember reading, either in this thread or the suv thread, that this had positive results for somebody. Could the randomness of this problem be related to the randomness of how wheels are mounted? Are you going to rotate one at a time or both?
I'm told my truck was successfully repaired!
Do I believe it? No. But I do have a glimmer of hope as I sent one of my guys (who isn't as in tune with these things as I am) to pick it up and he said it's good as well as the head service mgr who I've delt with since day one and has drove it with me 4xs.
So now the "explanation"...
So they started where they all start. The tires. Road Force revealed some abnormalities, exact readings I'm unaware of, but adjustments were made. They drove the truck and still detected vibration with the GM vibration detector and their butts. They went to the rear tires and re balanced them on the "NEW" laser balancer and found nothing out. Remounted the wheels, drove it, was worse. The tech simply rotated the rims on the studs 180 degrees and drove it again. NO VIBRATION!
What the hell? So now the theory is the hub centric wheels don't mount perfectly everytime or could be sensitive to even torque during installation. The dealer believes the wheels them selves could be the problem. Being the second set, it could be a manufacturing issue.
Thoughts?
I'll be to it in an hour or so to give it my full assesment.
2015 Denali 3500 DRW, Michelin ltx, 4x4
I found it! It was post #4293 in this thread.
@abominable z71: Does this support your findings?
So now the stud holes on the axle flanges are not drilled equidistant from the center of the axle?
Edited by pm26
Cats out of the bag. Wonder how much attention it will grab?
http://www.autoguide.com/auto-news/2015/12/there-s-a-big-issue-with-gm-s-suvs-and-no-one-seems-to-have-a-solution.html
Thanks for passing on this link ;)
I'll be passing this on, they will really flip when they find out that there are more trucks and it dates back to 2013 !
Edited by Enforcer
I recall that 14silverado 4.3 said his vibs changed when they r+r his wheels and tires. Where are these wheels made and how good of quality control?
So now the stud holes on the axle flanges are not drilled equidistant from the center of the axle?How can this be checked?
I just added this link to dontbuyasilverado.com :) Thanks for sharing. I'm guessing most of the industry magazines won't say/do anything as GM spends a fortune with them. JD Power's Initial Quality award is the perfect indicator of marketing at it's best!
Update on my truck - My 2016 is on it's third set of tires. Dealer is blaming the tires that I had installed and won't do anything. The tire specialty shop I went to, only does tires and has only done tires for 80 years. They offer no other services other than tire replacement. They Road Force Balanced the tires twice. The vibration is exactly the same as the stock tires and a set of aftermarket wheels/tires that I tried.
The battle continues. Off to look at a new Ford or Toyota tomorrow evening. Seems like the best solution for the GM vibration issue is really another brand.
Can't you eliminate the suspected hub runout issue by measuring the lateral and radial runout with a good dial indicator gauge?
When they Road Force Balance the tires/wheels, they should be checking this.
The wheels are made in China. My Yukon Denali wheels are and my Sierra AT wheels are, at least. I believe the country of origin is stamped (or cast) on the inside of the wheel.
Can't comment about quality.
Sorry you are going through this with a 2016 - you can use some of my experiences on your site if you want. Just look though my posts. I'm on my second truck a GMC, first one was replaced by GM. We just got this one back after its final repair attempt with the engineers and it's worse than ever - maybe as bad as our first Silverado. I keep forgetting to post the video of the day we picked it up. I have posted a few other videos on the thread also. What state are you in?
So the flange holes need to run true to the center of the axle shaft? How far off can they be before you feel it?
When you mount the tire to the hub the nuts center to rim on the stud bolts?
Are we thinking that the bolt circle is shifted off center to the axle center? Someone can lay this out in CAD program? Cut out the bolt holes and place it over the flange? It should at least give an idea how far off center?
When does the vibration happen on your 2016 truck?
70+mph
Crazy. Had my Silverado over 70 a few times looking for vibes. Nothing, it's smooth everywhere. Sucks you guys are having these issues.
Going to focus on the drivers rear first and see what the results are. I did clamp the rear springs last night like buster12 had posted and it made a significant improvement. Cheap thing for anyone else to try and takes about 10 minutes to install. Most autoparts places have them in stock for about 15 bucks.
    • Unless you are using a bypass filer system with a Beta of 1000 at 2 micron the commercial filters we have access to, even the very best of them, are poor at the 5 to 10 micron range the typical UOA test can 'see'. Point is there are some truly awful filters being sold A 45 micron Beta 75 filter is what Dyson used to call a screen door on a submarine. That leaves wear metals disconnected from filtration unless particulates are larger than the test can 'see' and yet captured by the filter...which is its job. If that is true then you have a major issue screaming at you.    The graph isn't mine. It belongs to GM and their study on this area. I looked up those studies and provided those SAE tech paper addresses multiple times. Machinery Lubrication displayed it and confirmed it. So if you have doubts about the study you'll have to take it up with GM Engineering. Just like you would have to take up a difference in opinion about the meaning a word with Webster or the length of on inch with the National Institute of Standards and Technology.      Most manuals have two schedules. "Normal Service" and "Severe Service". On it's face it tells you that oil in severe service is more highly stressed and doesn't "Last as Long". The item to bore in on is LAST...what does that mean?    It's the same question one asks about how long to toast bread. What are the inputs? Bread type? Wattage of the toaster? Distance from the elements? What is your preferred level of done?    So lets paint this with a broader brush. Oil is made up of the base and the additive package. The first is altered by heat and oxygen and later is sacrificial with a finite life subject to inputs toward that end. Resistance and supply.    It is the reason an OEM's OCI's are determined by 1.) the specifications of the recommended lubricant and 2.) risk management toward the bottom line. Those lubricants are also subject to cost effectiveness for the OEM.    There is a tendency for most people to believe that the OEM recommended oil rest on the top shelf and that anything other is lesser than. Truth is there are more oils on higher shelves than those on the lower shelf below the OEM's. They make that choice on COST TO THE OEM. Testing is incidental to the margin.    GM makes MONEY, the car/truck is a TOOL to leverage MONEY. Insert whatever car brand you like. Until you forking over a million plus COST not quality is the driver. Thus it is by DESIGN the recommended OCI's and oils fall well short of 'best practice protections'. Proof isn't hard to find. GM Ecotec I-4 2400 breather system and cold start PCM tuning has killed more motors and resulted in more litigation for those that used the 'recommended' practice than GM could bear. What was their response? SHORTEN THE OCI. TWICE.    I don't know how long to leave oil in an I don't know how the oil will respond to MY circumstances and because I don't and can't blanket statement or anecdotal evidence my way out of it.....I TEST and FIND the right OCI for the oil I CHOOSE. There is no shortcut but there is blind allegiance. I don't blindly trust anything.    People hear the word 'detergent' and believe that in the context of oil it means the same thing as laundry soap... Only in the most rudimentary way. It's the first additive to give up on you and they are putting less and less with each new API standard. Solvency can be used but it cost. Some unique undisclosed chemistries can be used. Valvoline R & P in example. OEM's haven't an interest in anything they see as limiting market participation. Whatever.
    • For some unexplained reason my father wanted a salvage yard. As we were getting the family business off the ground one brother ran the salvage yard. We gathered there when rained out working on pipelines in the eighties to pull parts. Perfectly good running vehicles would come to us simply because they wouldn’t pass emissions inspection. We were able to swap parts and sell some of them. I got a clean old nova with a bad engine. I pulled a perfectly good small block out a Camaro. A father and son project with a rebuilt engine. The son couldn’t get the engine running right. The problem was the spark plugs weren’t gapped. The 90s vehicles probably widened the gap of shade tree do it yourself engine repair. My do it yourself hot rod repair stopped at the 70s. After that my trusted mechanic kept them in running shape.
    • I have an old dental chair in my shop. Something I got for free and apparently it has more than scrap value? People collect them although mine isn't restored or anything. It's visually interesting (1930's Ritter) which is why I like it. And it IS decently comfortable if you kick back.   When a good buddy of mine saw it he said, let me guess, Atlas. It's a conversation piece? As in, you ask the questions, they do the talking?   Where do you hide the jar of teeth?   I would never.
    • Are we talking about the same thing, though? The 7 versus 3 wear metals was from Lakespeed's 3.0-specific oil brand comparison test between AcDelco oil and Mobil ESP. The filter remains a constant so whatever excess particles the AcDelco oil is producing aren't being filtered out.   I'm assuming there's a parallel comparison to be made; IF the filter can filter down those particles, engine life increases, and your graph makes the case that a better filter (lower micron rating) can increase engine life. Introducing fewer particles AND filtering those particles with higher efficiency is the best of all worlds. Good oil, good filter.   Where we may disagree is the "baseline relative engine life". I'm more apt to believe the base engine life value is 200k+ on very average oil and filters, "bulk oil of unknown brand and white-label generic fleet-grade filter, Jiffy Lube"   Going from a 10 micron filter to a 5 micron filter should boost a base 200k to 275k in a vacuum as a single factor alone.   Here's the whatabout: How does regularly changing the oil and filter ahead of recommended schedule influence baseline engine life? Most people aren't going to science the heck out of this stuff or ask about Micron ratings, HTHS, or wear comparison tests at Jiffy Lube. Most of the Jiffy lube techs would say they need to call their tech support line to even try to get an answer.   --   Because we love anecdotes here, when I was fishing for 4.3 parts at a local yard this weekend, ALL of the 4.3 vehicles had well over 200k. I love looking at odometers of junked vehicles. How far did THIS go before landing at the crusher? The ones that still had engines weren't seized. None of them were vehicles I'd consider were Amsoil queens, in fact most of them had some kind of service cling-sticker in the corner of the windshield indicating it probably had very average maintenance services. Even the fresh parts rigs- I'm not sure taking an S/T series to 400k has much value considering the running value of those vehicles was probably somewhere around $1,000. 25+ years is a good run on time alone.   The intake manifold I salvaged had clean and bright pool areas. As expected, I found the fuel lines in the manifold rubbed through, just like mine. I'm guessing the lines on that donor truck started leaking, the truck started running rough, and its owner said that's enough I'm unwilling or can't take it out of service for several days, or spend $1000+ to repair it at a shop, it's simply time for a newer more reliable vehicle (or, more than likely, this is the 2nd, 3rd time this has happened in the truck's lifetime). While I don't count on my Blazer for reliability, the thought of giving it away for parts at certain points during my adventure, and being mentally free from its needs has has crossed my mind. I'd be losing $1500 or so, but I can only make more money; not time.
    • still $4.00 85 oct.
