I bought a Tundra after 3 sets of tires going to my 4th set on my 14 Silverado. I love it...... Especially since gas is less than 2 bucks. But even if it wasn't I'm loving not having issues or recalls with my truck. Had a Ram before I bought my Silverado and Transmission went out after 3000 miles. I dared not give Ford a chance. I'm happy for those owners with no issues....just not my experience. Good luck!
What year RAM did you have? Im off to test drive some trucks tomorrow and will be driving a 2016 RAM. I love the Tundra but they dont have a crew cab with a standard bed available which could be a deal breaker.
My 14 will shake itself apart soon. Its amazing how no one will tell you that these truck are garbage when it comes to ride quality. I know it all about making billions for GM. Who care is some customers complain.
Time for the BBB.
Time for the BBB.
Dont waste your time with the BBB, hire a lawyer. Myself and a few others were recently denied a replacement/repurchase from the BBB. I think they are in bed with GM and being paid off to deny the customer.
I buy a new truck every year or two after about 25K miles. I got annoyed with a duramax fiasco in '08 and swore off GM trucks. I've had an '10, '12, '14 Laramie CC 4x4 Ram and I never had any issues with them except a leaking third brake light (common, easy fix) and the '12 had a mild low speed vibration in 4wd (common, CV angle). They ride great, nice seats and can easily buy a 50K msrp Laramie for 10 grand off. Downside was the fuel mileage, sucks, especially with the 3.92 'towing' gear. The 6 speed (5 really) and 8 speed transmissions work great - unlike the A6/5.3 mess in the '15 Silverado.
I also had a '13 fecalboost Ford for a few months, was able to gte a dealer to buy it back after it almost killed me and my family on a damp rainy day. Be a while before I try another Ford.
Nothing is perfect, only reason I tried the Silverado was the recent discounts and it was 'new' in 2014, got a little bored with the Rams where except for the transmission and radio nothing really changed. I wont be buying another, if I was to trade today it would be on another Ram. If you tow watch the max payload on the rams, it gets pretty low on high option trucks and they dont have a HD tow option.
FWIW I recently rotated the tires on my '15 Silverado and the 75-80mph vibration that appeared at 7000 miles in now gone. I'm sure it will return but at its worse it wasnt enough for me to get rid of the truck - I've had worse.
Thanks for the advice. Just drove a '16 F150 3.5 ECO and it didnt vibrate at 75mph like my silverado lol. It was a really nice truck just a bit expensive. They offered me $27k for my '14 silverado. Heading to the RAM dealer now, ill let you know what I think. I hope to be out of this silverado by the end of the weekend.
Keep us posted, here in the next few weeks I will be truck shopping as well and curious to see what truck you like the most. Are you planning on driving a Tundra?
I decided to skip the Tundra because they dont offer a crew cab with a 6-1/2' bed.....the crew cab is only available with a 5-1/2' bed and I really need the extra bed space. Ill let you know how I make out.
I bought the Tunrda hotrodz, I love it. Kicking myself for waiting so long to do it. Only one thing I really wish I could change is the MultiInfo display, it is just short of useless, no spedo in it. I thought the single USB port would be an issue but the Bluetooth streaming works great. And I just put a usb adapter in the center console so i can charge two devices if needed. But the truck drives great, i'm getting 16 MPG around town.
I'm begging to think this may be related to the brake rotors not being seated 100% properly and making the wheel be off enough to cause a vibration. My dealer got rid of my vibration on stock wheels, had 22" replicas put on and the vibration is back EXACTLY the same as it was before the dealer corrected it. Could it be the brake disc faces are not being machined/cast 100% flat?
Edited by ekimsinnigcm
This is the exact testing protocol document I mentioned earlier, as long as the dealer will follow it they can figure out the cause of the vibration. Personally I think a lot of this is being caused from how stiff the new trucks are, manufactures are always striving to take the flex out of the frames and make the trucks as stiff as possible before the suspension comes into play. While this is good, it is bad for harmonics as minor harmonics that used to be absorbed by the chassis are now making it thru and being felt by the people in the vehicle.
Edited by TJay74
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
