I'm taking mine in tomorrow. They have a new bulletin posted previously that fixes this issue so I'll let everyone know. This will be the 3rd dealer fix.
You mean the 3rd ATTEMPT at fix.
they said they fixed it :) but yes it was an attempt. the newest seat bulletin actually puts black clamps on the white clips to prevent them from sliding, somewhat like the hose clamp fix. i'd rather get my hose clamps back and have a GM approved fix so I will update this thread in 30 days.
I fixed mine with the hose clamp here in this post but after 7 months is doing it again but looks like is moving from the back.
Dropped mine off at the dealership this morning with this issue on the list. Service writer was familiar with the issue and said it probably needs shimmed. He thought they carried the parts in stock so I should know if it worked later today.
Edited by sti
Holy crap!!! Is this what I have to look forward to? The dealer just installed those hose clamps on my seat after a YEAR of me complaining. It will be out of warranty in seven months, too. 2014 was a bad year for the Sierra...
Dealer ended up giving me a loaner while they ordered parts for the seat. Apparently there was an update to the TSB that added an additional part they didn't have. Part will be in tomorrow.
Does anybody have the latest TSB number on the seat movement fix?
It should be on my paperwork when I pick my truck up tomorrow. I will post the info when I get it.
Thanks bud!
Here is the information on the paperwork regarding the seat movement repair. The seat is solid now, but I guess only time will tell.
Is the TSB in that pic above? I may be blind...but don't see it and would love to have it when I go. First issue so far and it just started.
Unfortunately no. I looked everywhere and the TSB was not anywhere on the paperwork. I figured I would at least post the part numbers for reference.
Was hoping I missed it. If nothing else will print your pic. Thanks for the information
Sent from my phone using some app!
Edited by carthman
Was this supposed to be fixed on newer trucks? My truck was built in March 2015 and a few times already I felt the seat move back when I was coming to a stop? It rarely happens right now, but I assume it will get more frequent with more time.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
