So what's the consensus are you guys having success with a dealer fix? I'm about to take my truck in to get the bumper aligned and I will bring this up too if there's a fix that's working.
Cool I guess I'll give them one more shot before resorting to the hose clamps
Edited by Silverado-Hareek
make sure you check afterwards for the dark grey bar that now locks onto the white clips. mine has it, and didnt before.
Can you post a picture please?
they are posted on this forum. theres a new seat bulletin that puts clamps on the white clips now. its on sandyblogs also.
Had mine fixed about a month ago. Knock on wood... solid as a rock since then. Im really starting to like this truck again. All the other attempts to fix on my other 14s only lasted about a week and still did not feel as solid as this time. My ass is finally not clinching up every time I make a turn or go over a speed hump. lol
Is this the fix your talking about? I see its noted for ATS, but not silverado/sierra.
He is talking about PI1376. The file is listed in the previous posts. It lists 2015 Escalade, Silverado, Suburban, Tahoe, Sierra, and Yukon. I have a 2014 and had it done no problem.
Had the update done yesterday and the seat feels very solid now. The tech that did the work said the new laterial supports should work well.
Dropped by the dealer this morning. Finally got the service manager to pull the bulletin and my parts are now on order. May be I get this fixed before we hit 40K miles.
You guys that have had the most recent seat fix, do you just tell the service rep what the PI# is that you want done or do you tell them your seat moves and bla, bla, bla? I just want to make sure when I go in for an oil change soon and I address this, it gets fixed correctly. Especially since I have the PI.
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
