Radio Reception Issues
ace ventura
Well, I finally convinced my dealer to replace the radio...which they did and I have noticed a significant difference in the reception. They told me that they had an update on the model and that there was a bulletin out regarding this issue. I asked to see the bulletin but they didn't want to disclose it.
Anyway, I'm very satisfied now.
  • Replies 1.4k
Didn't want to disclose it, BS. I would speak with the service manager and ask him for the info. It is your vehicle and if asked they need to provide the service info to you. I would remind them if they don't want to share the info with you then when your GM survey comes in the mail you will make sure to mark the survey accordingly.
I mentioned in an early November post that my reception hadn't changed after the hardware/software update. Well, for the heck of it, I enabled HD a few days ago, and surprisingly it is actually pretty good. Good enough that I'm leaving it enabled.
Maybe after the update, I already had a mindset that it was going to suck as usual. Well, I was wrong. Nice that there was something positive with the update.
I am still hopeful from the email I got from the Chief Engineer that another software update will come out that will fix the system fully. I have made some suggestions as well as to how the operation of the infotainment system works along with the HVAC and seats operate while under remote start.
Still bugs me that the darn radio won't consistently turn off either (in addition to reception as good as other GM vehicles I've rented). Sometimes it is on the clock screen when Imstart the truck, but mostly it is on the radio muted. It is just an irritant, but I can't understand why they put a radio in these trucks that isn't close to normal operation in any normal vehicle. Oh well....
any idea on a time frame for this fix. The radio is truly my only complaint about my truck. Well that and the poor service at the dealer.
Nope, last email was 11/14/2014 from him. Plan is to touch base with him again after the new year.
.........and much appreciation to you TJay! :thumbs: Without your input, I doubt any of this would have happened!
Finally got the fm module replaced two days ago. Yesterday my xm quit working. Had xm reflash 5 times. So I have been using the HD till it goes back to the dealer again. It holds HD a little better but it still goes in and out sometimes.
How did you switch to HD? I looked in the manual and it doesn't say much on it. Is this done on voice command only?
Enable auto switching in the radio settings and then when searching for stations it will pick up HD stations in addition to normal stations.
For all that have there radio replaced and new software. Your xm radio has a new id because it is a different radio, it will work for a day or two and then it will mysteriously quit working. You'll have to call XM and give them the new radio id number and ad it to your account.
They will re-provision your radio to your account and it should work just fine.
I wonder if that means you can get the XM trial for free again..lol
Hmmm! I didn't have to do anything.
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
