7 minutes ago, M1ck3y said:
So your expensive shocks failed and you bought the same one's again?
Did you know those shocks are fully serviceable? I think they actually recommend a full service on a yearly basis.
I got about 150k out of them, and yes, I know, thanks.
Had the Putco lightbar installed today....too bad its the wrong one. I ordered the two color but apparently it showed up broken and the tech didnt realize that it was only two color instead of three. So he installed the three color without saying anything. Imagine my surprise with the lights didnt match. Man it sucks being OCD. Now I have to wait til they get a new one in to get it fixed.
  • Sad 1
Took her in for an oil change and tire rotation (which i normally do myself but) had them check out a funky brake pedal noise (sounded like under the truck at drive thru's, not the pedal, plus my fluid has looked slightly low.)
So need rotors and pads all around, (not a shocker or a huge deal) but turns out the noise is the rear calipers are freezing so i guess thats making the noise when the system releases but the calipers don't? idk.  anyways i'm doing the rotors and pads myself and then i'll have the dealer do the calipers and a proper line flush.
Question tho... can i tell whether i have the regular 6-piston or the "big brake 6-piston" brakes just by looking at them?  or by RPO code?  truck is an '18 All-Terrain SLT Premium Plus.  Thanks for any info, peeps, in advance!
Edit: it looks like if it's NOT the "Big Brake" kit then its only a 4-piston caliper... is that right?  and then in that case i WOULD be able to tell just by looking. haha.  sorry for the possible false alarm haha.
Edited by slide187
If you have a K2, it’s a 2 pistons floating calipers in the front and single floating rear. Only the 19+ have 4 pistons fixed front calipers.
you’ll know if you have a BBK… they are BIG. It will fill up 20” wheels pretty much all the way.
If you’re already gonna change the front calipers, swap them to the 19+ Cheap and easy upgrade.
I would do the brake job, clean everything, new metal tins etc etc and grease all the slide pins. Then see if the noise is still there.
Yeah I took their numbers and compared it to the place I normally use for brake parts and I can save $300 doin it myself amd that’s with some nice slotted/dimpled rotors and premium pads. so I’m def doin that. And as for the rear calipers while they’re off I was gonna clean em better than I typically do, give em new hardware and check the pins etc. for just that reason. good point tho. That could get rid of the noise. 👍🏼
and thx cajunfries. Haha seems like a dum question now, but when ordering my parts with my year it asked me to choose “with BBK or w/o BBK” but they phrased it weird. Haha
thanks again guys!
Edited by slide187
*From #5752 Chrome 20" wheels to #5916 Gun Metal 20" wheels.  If anyone is interested, the #5752's are for sale in good condition.  One has some curb rash, two have very minor blemishes, and one in almost perfect condition.
*From Michelin 275/60 R20 tires to BFG KO2 AT 33x12.5 20 tires. The BFG's are DEFINITELY not Michelins.  Gave up comfort, ride, & quietness for a more aggressive look.  Wish the Michelin AT2's had a more aggressive look on the side of the tire.
*From OEM step rails to N-fab Epyx step rails (didn't get a "before" on the step rails)
*From Rancho rear shocks to Bilstein 5100's - MUCH improved ride/stability and from just replacing the rears. My front Bilstein 5100 ride height adjustable shocks have been on (back) order since MARCH!!!! Need to get the front up about 1.5" to lever it up.
BEFORE 5916 GMC Wheels.jpg.HEIC
Edited by Cujo
more info
Spent 9 hours cleaning the truck and getting it ceramic coated today. It haven’t been properly washed in MONTHS…. I’ve been just rinsing it off in the morning after I get off work and the dust and concrete powder mix was just CAKED on. Got couple more hours left for tomorrow to finish the passenger side.
FullSizeRender.mov
Not sure what I was supposed to be looking at in the video, but thought it was funny that you have a big American V8 truck and your neighbors have two Prius' in their driveway😬
  • Haha 1
Oh sorry. I thought I added the picture of the hood before I started. But it’s now mirrored like on any surface. It was really bad before. CAKED on with concrete powder and dust. It felt like a 200 grit sandpaper.
Haha yeahhhhhh all of my vehicles are….. farrrrrr from being green. 5 dedicated track motorcycles and this E85/meth fed boosted 5.3.
  • Like 5
Well, where do I start. Put the house up for sale in Illinois, sold in two days. Couldn't find a place to rent until we figured out what we were gonna do. So, bit the bullet and moved to Florida. Was always in the cards, just not this soon. Renting till our house is complete. Truck is sitting outside till house is complete in December. B&M trans pan install and Amsoil fluid change out on hold till December (no garage). Good news is Cab Over America lights get charged constantly. Still not happy with the fit and finish. At least I'll have shorts on this December 😀
Dragging my station car 200 miles to use when down on LI for work. I’d dropped the engine in April due to a slight overheat, wound up installing larger pistons, cylinders (1584-1660 CC) and generally rebuilding/replacing everything from the case-out. First oil change after 5-7 miles of ring break-in, adjust valves, carb and timing. Good to go.  👍
  • Like 5
2 hours ago, CajunFries said:
Swapped out the G80 for a truetrac. The G80 had a rough life but it will now rest in pieces…..
Wow! I have a G80, what do you think caused it to rest in pieces?
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
