Tailgate cables different lengths
Bbowen826
Has anyone else noticed their tailgate cables are difference lengths? I just noticed yesterday when I open my tailgate only one cable has tension on it. The other has a lot of play to it. I can even stand on my tailgate and it doesn't pull tight. I went by the dealership today and at first they tried to tell me this is normal. They showed me other trucks on the lot that had some play with one cable. The difference was those cables would tighten when I put weight on the tail gate. I was concerned my tail gate would twist causing damage or having that much weight on one cable could cause it to fail. The dealer finally agreed to swap them with a different truck. When they removed the old ones their was almost a quarter inch difference in length. At least I got the problem resolved. I was surprised how many trucks they showed me with this problem and they don't have a service bulletin at least.
  • Replies 62
It does seem a bit trivial but I bet the tolerances for the cables was not met by the suppliers and no one had caught this until this sharp eyed consumer Bblowen826 spotted it.
Dear GM rep person please have the factory QC check the cable lengths and have the supplier replace all previously distributed cables and make sure all future units are within tolerance..... I will have to check mine tomorrow. What was the build date for your truck Bblowen826?
I just noticed there is indeed a bulletin on this today. It indicates it is normal for only one side to be tensioned with no load on the gate due to normal build variance. It did indicate they should both have tension with a load on the gate. Sounds like the OP had one a bit further out than what is normal.
Factory who?
You know, if these trucks cost $ 11k to buy new, maybe stuff like this would be amusing.
With $ 50k+ sticker prices, not so much.
My truck date is 08/13. I can understand it being acceptable when you put weight on your tail gate and it holds the load. But mine would not even come close to being tight without twisting the tail gate. Makes it even worse when their is a TSB on the issue and the dealer didn't even bother looking. They place all this new technology on these trucks and it cost 50k but can't make cables the same length.
I have the same problem with only one side having tension when under load (my 200+ lb fat ass standing on it) but I haven't mentioned it to the dealer. I guess I didn't really figure it a problem, just a little strange.
where do you find the build date at on these 2014 GM trucks? I do not even know when mine was built and would like to check that, it might be a real OLD one and have to be junked out or traded soon...........
What should we expect from the lowest bidder? Lol
This is deja vu, guys. Read my link in the post # 11 on this page. These posts go back to 2004 when this problem surfaced. About 4 million GM trucks were recalled for this problem back then. Apparently GM did not take any steps to prevent reoccurrence.
BTW, this is a safety issue as the single cable holding the weight of the tailgate plus the load can fail under heavy load such as moving an ATV over the tailgate, then the load is transferred to the slack cable, which is then shock loaded and can fail. This can have ugly consequences and result in damage to the tailgate, personal injury, or worse. Do not ignore this issue. There is no excuse for this.
The QC manager Sum Ting Wong must have had the day off when those cables were made.
Now that is funny. I'll check mine tomorrow, and if they are jacked up it won't be so funny.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
