Tailgate cables different lengths
Bbowen826
Just checked mine and the passenger side has a slight slack to it but as soon as I put a little pressure on my tailgate it tightened right up.
  • Replies 62
I wasted two hours taking mine back to the dealer to get the cables replaced. The new cables are worse and have the big MADE IN CHINA tags. They also stick out between the tailgate and tail lights.
I wish I would have searched here first.
Did anybody notice the tail gate does not go down flush with the bed?
It's not just the cables, if you swap the cables side to side, if it was loose on the left side and tight on the right it may still be loose on the left and tight on the right. This indicates the mounting points are to blame even more than the cable length.
The design of this tailgate makes for very short cables. Very short cables mean any tiny variation in length/mounting point distance will cause this condition much more noticably than prior designs. Build variation vehicle to vehicle simply isn't going to allow both cables to fit the same on every vehicle.
If you want the problem fixed, take a few minutes with a die grinder and lengthen the slots on the "short" cable very slightly. It only takes a tiny bit to even them out. You can have the dealer replace cables until the end of time and it won't likely ever fix the problem.
Also, as noted above, the tailgate doesn't sit parallel with the bed, even once you've evened out the cables. I really wish they made the cables slightly longer but they don't. Hopefully they'll change that soon. Anyway, I took a little material off both of mine to lower the tailgate as it interfered with my Cargo Glide. People will need to individually evaluate how much material they'd need to take off on their individual truck and decide for themselves, but as I said just a little bit of material removed can make a noticeable improvement.
good insight... but in the end there is no way I'm taking a die grinder to my new 45K truck....for anything.
It is not the cables.
The dealer took mine off and checked that they are the same length...then proceeded to put them on the wrong sides from what they were labelled. When they do this, the cables stick out the sides of the gate when closed.
I took another look at mine this weekend and all of the mounting points seem to measure out the same, but when you step back a good 50 feet and look at the tailgate when closed, it appears that the bottom left of the tailgate is a little bit lower than the right, thus creating the slack. The funny thing is, the top of the tailgate appears to be level to the naked eye...go figure.
Anyhow, mine has quite a bit of slack, enough that you cannot tighten it up with weight.
This is deja vu, guys. Read my link in the post # 11 on this page. These posts go back to 2004 when this problem surfaced. About 4 million GM trucks were recalled for this problem back then. Apparently GM did not take any steps to prevent reoccurrence.
BTW, this is a safety issue as the single cable holding the weight of the tailgate plus the load can fail under heavy load such as moving an ATV over the tailgate, then the load is transferred to the slack cable, which is then shock loaded and can fail. This can have ugly consequences and result in damage to the tailgate, personal injury, or worse. Do not ignore this issue. There is no excuse for this.
I remember a recall for these cables on a 2000 Siverado I had, but I don't remember it being for uneven lengths, as I recall then it was just that the cables were deteriorating and subject to breaking under any kind of load. Seems to me the originals were made in Mexico, I remember the "Made in China" tag on the new ones.
I do understand that sentiment. However, many times in life if you want something "done right" your only option is to ____________. It become a question of, "do you want the problem fixed or not?"
And of course the cables are only about a $35 part.
Noticed yesterday when I made a trash run to the dump that I have a ton of slack in the cable on my driver side. When I stood on the tailgate, it tightened a little but still had tiny bit of slack meaning the cable on the passenger side is carrying all of the load on the tailgate.
I've had the same problem on my F350 work truck.
Depending on the load and whether the truck was sitting on a level surface the cables were tight or sluggish on either side.
There is no reason to fabricate two different lengths of those cables. I mean we live in the 21 century...
But even the stiffest frame or truck bed will twist just a little.
And that's enough to make one of the cables appear lose.
Remember a worn out drive belt. It seems like the new one has to be at least 1" shorter to fit.
In reality it is only 1/4 or 1/2 of an inch to sit tight again.
so long
j-ten-ner
Soo...no fix in sight then?
Sent from my SM-G900V using Tapatalk
I just noticed there is indeed a bulletin on this today. It indicates it is normal for only one side to be tensioned with no load on the gate due to normal build variance. It did indicate they should both have tension with a load on the gate. Sounds like the OP had one a bit further out than what is normal.
Can you please post or pm me the bulletin number. Mine do not both have tension with a load on the gate.
#PIT3227J: Tailgate Cable Slack - (Jan 28, 2014)
Subject: Tailgate Cable Slack
999999995.gif Models: 2002 - 2013 Cadillac Escalade EXT 2002 - 2013 Chevrolet Avalanche 1998 - 2000 Chevrolet C/K Classic 2004 - 2012 Chevrolet Colorado 1999 - 2007 Chevrolet Silverado Classic 2007 - 2015 Chevrolet Silverado 1998 - 2004 Chevrolet S10 1999 - 2007 GMC Sierra Classic 1998 - 2000 GMC C/K Classic 2007 - 2015 GMC Sierra 1998 - 2004 GMC Sonoma 2004 - 2012 GMC Canyon
This PI was superseded to update model years. Please discard PIT3227H.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment that with the tailgate down, one of the tailgate cables may have slack in it.
Recommendation/Instructions
No repair attempts should be made - as this is normal due to build variation. In most cases, when weight is put on the tailgate the slack comes out of the cable
Don't shoot the messenger LOL
Craig
Thanks fella...good start for me.
He's talking about removing the cable from the truck and lengthening the slot on the Chinexico cable end. I had to do this with both cables on my 2008 to allow my tailgate to drop far enough to allow the bed drawers I have for my guns, to open. A tiny amount goes a long way.
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
