Vibration in Floorboard, Not Speed/Tire Related
TxTruckMan
Any body figure this out yet? Starting to drive me nuts, mainly since mine is in the 40mph-50mph range which is what all the roads I drive are. I experimented with double stick tape and it didn't help. It also used to only be in my pedal and now its made its way to the floorboard.
Maybe try this; take the pedal off and slide rubber standoffs, spacers, or bushings onto the bolts so that they are between the pedal and its backing. The spacers need to be just thick enough to prevent the pedal from contacting the backing. Maybe 1/4" tall and 1/2" diameter. Made out of material that's pliable in colder temps.
Something similar to these.
http://www.fastenersplus.com/3-8-id-x-3-4-od-rubber-bushing-pkg-12.html
  • Replies 95
From what I'm reading there is not much of a solution for the vibration problem. I have 2014 6.2l with the max trailering package as I tow a 8000lb toy hauler. Truck tows great but the vibration when towing is getting worse. I'm not sure if this is the same problem as mentioned in this thread but as you can imagine when towing you put a big load on the truck - this is making the vibration bad.
I've already brought the truck in three times to fix problems and with only 6000 miles on it I'm disappointed to have to bring it in another time.
I installed an RX catch can yesterday on my 6.2L. Now I have a floor board/pedal vibration that was not there prior to installing the catch can. Nothing else has changed any ideas?
I too have this issue. It started a little bit here and there, and now does it every time the truck is running at 1100-1400 RPMs. It is driving me nuts. It actually got worse after I had the GM/Borla Exhaust installed. I have an appointment to take a service director for a ride on Friday.
Let us know what you find out, mine is driving me bat shit crazy too but I know if I take it in I will get the standard "operating as designed"
Let us know what you find out, mine is driving me bat shit crazy too but I know if I take it in I will get the standard "operating as normal"
Less than 1000 miles on mine and only 3 weeks old....... I already had to bring it back to the dealer after they installed the exhaust because the driverside pipe could be moved up and down by hand. They are already not happy with me, and are trying blame it on the pipe without even seeing it.
  • 3 weeks later...
^that is very common if you put the RX can on the brake booster...
I did not know this, thank you for the insight! Relocated my catch can, vibration gone.
You relocated your RX? Where did you end up mounting it?
Where the spare battery would go. There are a few ways to fabricate up a mount for that location.
Gotcha so you made a new mount and did not use the one supplied with the RX can?
Different can, but similar mount style. I used the bolting point that holds the top of the windshield washer fluid reservoir, longer bolt, with a spacer. Not my optimum mount but it will do until I can come up with a better solution. That being said, it is holding fine for now. I had to get rid of that vibration. Was killing an otherwise exceptional ride!
Never knew I had a vibration problem until I drove 80 mph ( speed limit was 70 mph ),any one with vibration issues should try driving your truck in different situation to see if vibration change ,
I had a vibration that was noticeable all of the time and had what seemed like an exhaust drone as well. After 65 mph if I accelerated at all it was worse. I took it to the dealership and it ended up being the 4 wheel drive not fully disengaging. Problem is fixed and truck drives like its brand new again! Just thought I would share the experience.
  • 10 months later...
I was passing a vehicle yesterday and noticed from 80MPH -100MPH (it was a long line of cars lol) but it seemed to go away or lessen when i let off the pedal. Any ideas, gear, drive shaft, motor mounts. Any experience with fixes before i go to the dealer would be helpful. Thanks
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
