Hey everyone first time posting but been reading alot on here and i took my 2014 silverado to dealer and like many they never heard of this issue but i took copy of tsb and the number so they are going to get my truck and strip the frame and redo it all they said be about a week to do it. Just wanted to let everyone know.
Sent from my SM-G920P using Tapatalk
Jumping on the bandwagon here. I have a 2014 Sierra SLT Crew Cab that also has some terrible rust. Waiting for 4 months to get in to my dealer to have the TSB work performed. Pics in my gallery. This is unacceptable. Any class-action lawsuits out there? Emails to Mary Barra? or Jeff Luke the lead engineer on these trucks. What a joke. I was torn between Ford and GM. Should have went Ford.
For those that have had the repairs done - are you happy with it? any further rusting?
I purchased a certified 2014 Sierra CCSB about 2 months ago and discovered flaking-off frame coating with extensive frame rust the next day. My dealer worked with me and helped me fully understand what a repair per the tsb would look like and also gave me an option to get into a new truck. I am now in a new 2015 truck that has a much thicker and more durable looking frame coating.
Edited by olddutchfarm
Had mine done. Two months later it all peeled off of the welds on the frame, it is rusting by the rear wheels and all the cross member holes are rusting. It is back at the dealer hopefully getting fixed again.
Any of you guys use Fluid Film for rust prevention? It's big in the farming industry for protecting tractor parts. I believe the primary ingredient is lanolin. I just picked up a brand new Silverado LTZ tonight and plan on using Fluid Film to help protect my frame. It worked great on my Jeep. Can be found on Amazon.
I unfortunately didn't learn about fluid film til the truck was a year or 2 old. However, I've done the wife's Sorento and mom's lacrosse since new and both still look spotless on the bottom.
Definitely won't hurt to start using it. It's supposed to stop rust from spreading as well as prevent it. It worked wonders on 1992 craftsman lawn mower I bought, as well as kept my jeep looking pretty good for the three years I had it. I'll be spraying the frame on my new Silverado once or month or so.
14-day old truck is in now for the tsb. I'll let everyone know how it goes. Went in Monday morning, and I was told to expect 4-5 day turn-around. This is actually the 4th or 5th one they've done and they have found that a professional body shop will do the best job. Makes sense. We shall see.
I've been using Fluid Film on my vehicles for a few years now. I've sprayed the frame of my 2014 a few times now. Works great. It's very popular with the Tacoma guys and if it works on a Tacoma it'll work on any vehicle lol.
Here's pics of my tsb fix on my 2015 Sierra. I thought the job was fair....missed a few spots. You can see where the lift was how it took the coating off...they should have touched that ip. It did show me primer, though, which I was glad to see. Now well see how long it lasts. Saw a Ford today and made me remorseful that I didn't buy one.
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
